rookie
1 Follower
  • Gender
  • Location
    Brampton, Ontario
  • Interests
    Cycling , hiking , motorbike
    Occasional few hours on model ship
    Plastic models
1,258 profile views
  1. Looks great! How many spools of the plastic do you go through for these pieces?
  2. I also spent a lot of time looking for downloadable whaleboats pointed at both ends for Morgan my first one I did not realize was not for 3D printing so it did not slice well or print very well i also tried pulling apart the various pieces so I ended up just printing the bare hull with seats etc removed this can be done in blender. I think the top right window shows the separate parts and each can be deleted
  3. That is quite an upgrade from “teenage Ian” version well done!
  4. Found this video of uss iowa turret being rotated recently looks like about 90 seconds through 180 degrees from starboard to port
  5. Thanks for the printer names. I think my problem is I have a PLA printer so it cannot do fine details Should have listened to advice to buy Resin ...
  6. Hi Chris may I ask what 3D printer you use? I have tried to print whaleboats for my Morgan but they are quite rough. it could be the printer or the STL file, not sure Colin
  7. spectacular woodwork I feel like I am on the actual ship I like the fact you use wood from your property, I believe you mentioned early on
  8. yes, the green metal table. No bike yet. wait till the spring since cant ride it over the winter looking at Kawasaki Eliminator 500 or the Vulcan S 650 (not sure about that one)
  9. I had forgotten Dad made the gun barrels. I remember the fold-up picnic table in Dad's workshop[ with the keel laid out.
  10. Been a while finished the main body of the windlass moving on to the pump handle also did the tops and started to build topmasta
  11. Managed to do a bit of the mahogany layer on bottom over the summer going about it in a strange way likely but I find the flat bottom quite different to the usual ship hull 9I also had an idea to add the engine and have the compartment open spent time looking at Chris Craft engines from the late 1930’s seems to be inline 6 usually I searched for 3D inline 6 engines and found a few sinam printing sample parts to see if they will work gone back to my Morgan for a change of pace for now
  12. Beautifully done Glen on my brother Ian’s ‘twigged’ it apparently is an informal British word meaning ‘to realize ‘ I did not realize it was not a common term either….. 🤔
  13. I finished the balsa layer of planking. still some shaping to do then I move on to mahogany layer. i also put together the seats. I have been thinking of ordering faux leather or real thin leather for the seat cushions to make it look more interesting.
  14. Well, after many attempts at 3D print I managed to make progress on the windlass and the foremast mast band i realized during this how far out if scale the belaying pins are on my model These would be baseball bats if not belaying ropes on my Morgan i may sand them smaller but then the pin rails would have giant holes ah well…
