PRS
Everything posted by PRS
  1. Not sure which railing you are referring to. The railing at the very rear is curved and only goes one way. I agree the instructions are lacking.
  2. This is fantastic news! I am going to buy the wood kit for the Cheerful this week and if I cannot cut the planks myself I sure will be putting in an order. Prices look great also.
  3. Decided to make a small carriage for 3 of the barrels and mounted them before going forward.
  4. Turning the top mast piece with a drill and files: Broke first one as I got a little heavy handed. Lets try this again. Opps broke again! OK went and did a third and went very gentle. Third times a charm.
  5. Thanks Glenn. I have a large magnetic build board I use for my RC Aircraft builds.
  6. Man these cannons are small! I used a small piece it wire sheilding to attach the cannons to the bases.
  7. Deck planked and insides painted. ( I should have taken more pictures during these steps but wasn't sure I was going to do a log)
  8. Wasn't worried about the different colors of the planking as I am painting the waterline anyway. Used Tamiya tape and Badger Styrens white for this as I had it.
  9. Second planking pictures and used the cutout I made for the gun port piece to help ben the planks.
  10. Not going to bore you with all the planking steps be here is the completed firs planking. I am happy with it so far.
  11. Ran into and issue and forgot to make the rabit line so did that and started planking.
  12. While all that was drying I made some of the deck furniture. To glue the gratings I used a 50-50 mix of modge podge and water and brushed it on. This worked real good and since it was satin and this it did hold quite well.
  13. Side pieces glued on and left to dry. This went really well except a small crack on the port side around the forward gun port at the tope but with the planking it should not be noticeable and straighten out.
  14. For the gun ports pieces I used the scrap to trace out the curve of the deck and cut the curve in a scroll saw. Wetted and clamped the pieces of this and used my iron to get them to lay with the curve and left them overnight to set.
  15. Attaching the false deck after making sure everything was perfectly square.
  16. While the frame was drying overnight is did the same with the keel.
  17. Here is the obligatory start and you will notice I used my magnetic build board to make sure I get everything straight.
