Posts posted by malachy
Super Arbeit, Johann, bin echt begeistert!
And you probably already know this painting, but I think it´s worth showing:
Épisode de l'expédition du Mexique en 1838 by Horace Vernet. It shows the Prince of Joinville on the poop of La Créole, listening to the reports of the vessel´s Lieutenant, Penaud and sees the explosion of the tower of the Fort of Saint-Jean d'Ulloa on 27 November 1838.
By the way, do we know anything about the sailing qualities of La Créole?
- Siggi52, albert, uss frolick and 11 others
14
Oh my...that´s beautiful, my compliments to the Unknown Artist™
I hope I can do the drawings justice in 3D.
- uss frolick and mtaylor
2
I´d love to see some french frigates, too. La Forte or maybe La Virginie.
Or a danish one, they built beautiful vessels like Hohlenberg´s 24-pounder frigate Perlen of 1805:
Another beauty, Schifter´s Galathea:
Launched 1833 and made the first danish circumnavigation of the globe in the years 1846/47.
I feel your pain, John. Bought a new comp one month ago and it took me 2 weeks to set things up...still have a lot of programs to install.
But the move was well worth it, boot up phase takes 5 seconds and Blender/Gimp run smooth like silk.
I´d suggest some Boccherini or Lully as background music when doing the tedious stuff. Calms me down nicely
Harris' biography about af Chapman has a very interesting appendix with Chapman´s hand-written calculations for a 70-gun ship, made in 1767.
He calculated:
- displacement volume (with two methods, integration of the cross-sectional areas at each station and integration of the areas of each waterplane)
- location of the centre of bouyancy
- centre of flotation
- location of the metacentric heigth above the load waterline
Well worth a look if one wants to know how they did things back then
She already is a beauty, John, a beautiful french lady.
And it looks like this plan is going to be an absolute joy to work with
Edit:
Looks like the original plan for La Cornélie has been found in the archives...your version is spot on, John!
Why Sané is mis-spelled Johné and it has a scale with french and british feet is still a mistery for historians, though.
- druxey, CaptArmstrong, JohnE and 2 others
5
Depends on which Triton.
This one:
http://collections.rmg.co.uk/collections/objects/66550.html
Very elegant ship
- thibaultron and mtaylor
2
Her lines must have been very sharp forward, to have done that.
Well observed, she has a pretty sharp bow and a fine run. A bit difficult to see on the pictures, though.
Frigates with 24 guns on the upper deck were pretty common in the swedish and danish navy before the 1780s, probably because they preferred shorter - thus cheaper - ships with rather fine lines combined with british construction features. Chapman´s ten ships of the Bellona-class were the first frigates in the swedish navy with a conventional 26-guns setup (they carried 24-pounders, by the way).
And the forward-most gun port at the position of the foremast was a typical design feature of Chapman, maybe comparable to earlier french frigates like La Renommée or La Belle Poule.
Her stem reminds me of the experimental HMS Triton model, an unusual 18-pounder, 32-gun frigate that drew the same draught of water forward as aft.Ha, you´re not the first to compare this ship to the Triton, got the same response on another modelling board
Triton was made of pine, right?
- thibaultron and druxey
2
Hi folks!
I started this little project as a simple study on how the body plan would translate into a 3D shape but I liked what I saw so I continued and added further details. It´s by no means finished and there are a lot of things still to do.
The draught can be found in D. Harris' highly recommendable biography about the swedish shipwright Frederik af Chapman.
It´s part of a series of drafts, ranging from a snow to a 110-gun ship, which have been made by af Chapman in 1798. Out of this series, only three ships were actually launched, a brig, a 74-gun ship and the 24-pounder frigate af Chapman.
This frigate was designed to intercept danish smugglers at the west coast of Sweden and pierced for 24 18-pounders on the upper deck plus 12 6-pounders on the quarterdeck and forecastle. But, due to lack of funds, it was never built.
Dimensions (imperial feet):
length p/p: 145' 2''
breadth: 36' 9'
draught aft: 16' 9''
height of the middle gun port above the water: 6' 10''
length-to-breadth ratio: 3,95
I found the rather modest armament in relation to the size especially interesting. For comparison, af Chapman´s Bellona-class, which consisted of ten frigates launched between 1783 and 1785, measured 151' 11' p/p and carried 26 24-pounders and 14 6-pounders.
This may be an indication that this ship was designed primarily for speed, not firepower.
(but it´s not like that Chapman´s ship were slow, quite the contrary, the Bellonas were capable of going 14 knots and the af Chapman is described as the 'meilleure marcheuse de son temps' - the fastest ship of her time - in the french Atlas du Genie maritime, published in the mid-1830s).
But enough of the talking, here are some WIP pictures:
Never seen the Renommée model from the front or back, but wouldn´t the hull shape give the most obvious hint whether she was designed by Forfait (or one of his 'disciples' like Degay, LeTellier, Gauthier or Pestel) or not?
Edit:
Hm, here´s the model in question. In picture number four, the hull does indeed look V-shaped, but the absence of any significant tumblehome (unlike Forfait´s Seine- or Gloire-class) makes me think that either Gauthier or Pestel could have been responsible for the design, probably the latter. And Pestel usually gave his frigates bridle ports, as can be seen on his Nereide.
Edit: after some digging, I´ve found the plan for La Renommée in the 'CATALOGUE DES PLANS DE BÂTIMENTS À VOILES CONSERVÉS DANS LES ARCHIVES DE LA MARINE'. It´s the same as for Pallas, Elbe and Chlorinde, all built at Basse-Indre (Nantes) and signed by a certain Bonjean, but all three were part of Sané´s Pallas-class.
By the way, what´s 'Éch. Pl. vertical'? Is that just the body plan?
Quite an interesting and helpful line, that.
Here´s what it can look like in 3D:
Not canted the right way at all areas and too thick but it should be helpful to unterstand the concept.
[...]and these two ships exhibited such superior sailing qualities that Cornélie was subject of several sailing trials [...]Just noticed this in the first post. Are the 'superior sailing qualities' described in detail?
- druxey, mtaylor and avsjerome2003
3
- mtaylor, JohnE and avsjerome2003
3
Me likes. A lot.
I´m trying to find a nice project for a 3D model for a while now and the Pallas by Sané is in the top 4. The other are Forfait´s Seine, the Termagant (a Brit, but based on the lines of the french privateer Pomona) and L`Embuscade of 1789 (french, but the design seems to be heavily inspired by F. af Chapman).
Will follow your log with great interest, citoyen JohnE!
Sure
http://digitaltmuseum.se/search?page=6&query=Ritning,%20Chapman
I only searched for Ritning (drawing) and Chapman, you may get better results with a broader set of keywords/options (e.g. just ritning and a period setting of 1750 to 1800) as some drawings may not be tagged with 'Chapman'.
Best way to get a high resolution pic is to right-click on the download button and choose 'save target as...' and don´t forget to add the file extension.
If you click on the picture itself, you get a smaller version most of the time. For example, Chapman´s drawing of the stern/head of the Fleuron is 3000*1700 pixels when downloaded, the 'preview' picture in the slide show is only 1500*850.
The 'order image' gets you to an order form where you can obtain the full-sized image, either as a print or a digital copy.
The resolution of the scan can be seen in the Archive submenu of the museum main page (usually in the 10000 to 20000 pixel range).
A copy costs 20 Euros.
- druxey, paulsutcliffe and mtaylor
3
Frégate d'18 par Sané , la Cornélie
in CAD and 3D Modelling/Drafting Plans with Software
We´re good at nit-picking, aren´t we?
And thank you very much for the email!! Sent my request today, maybe there will be two versions of La Cornélie, one according to your plans and one as La Cybéle as a frégate rasée.
