Posts posted by HIPEXEC
You have great sawing skills! Your gunports are fabulous.
Thanks Bill.
I'm still holding off so I can get up the courage to drill. I'm not painting the hull, so I'll go very, very slow!
I'm not going to enjoy drilling into my hull!
Thanks David. That would be for both holes....the rail and the gunwale. It split when I pushed the rail into the plank even though I had pre drilled the plank. I'll have to make the receiving hole bigger since the pin went into the rail with no damage. I'll practice some more until I get a good formula.
I guess you mastered that difficult Sapely! Your planks are spectacular!
I've only installed one, so I'll pin the rest. Thank you Dave, Augie & Harvey.
I built my ports by cutting the planks as I installed them. I got very square cuts and all the right size. ...And I only had to plank once. It took carefull planning, but I'm not a good hole cutter.
Moving on. I installed the first pinrail. I cut it to size and drilled the holes, but when I went to glue it on.....I couldn't do it. It would be crooked or at the wrong elevation, etc. After pondering it for a while, I got the bright idea to make a removable support that would allow me to keep the rail parallel and straight and at the same height all the way around. It think it's going to work.
- lambsbk, Blue Ensign, dgbot and 3 others
6
Now, I have to lash the boat itself to the deck.
Here's my finished long boat. I figure this being a US Navy ship, the boatswain's mate would be in charge of stowing the gear on it, so the oars are neatly arrayed head to toe and lashed. The boat's rope is neatly coiled in the stern and the rudder is stowed near the stern. All US Navy ship-shape. That's as good as I can do. I know it's not as good as the examples you all showed me, but.....I'm all thumbs.
HMS Victory by Paul0367 - Constructo - Scale 1:94 - First wooden ship build
I'm building a Constructo USS Constitution for the very same reason....the natural wood and to make me improve my woodworking skills and not rely on wood filler.
