Arthur Goulart
Posts posted by Arthur Goulart
On 11/23/2024 at 8:08 PM, bricklayer said:
Arthur,
doesn`t the free trial of Rhino expire 30 days after 1st installation on your computer?
If you learned the basics and modeled the boat`s hull within 30 days, then I really admire your skills.
Michael
It's actually 3 months of free trial, Michael. My biggest struggle was more understanding all things shipbuilding related than the program itself 🙃
Following @Waldemar's suggestion, I took to measuring. Not only I looked for proportions on our 23ft launch, but I browsed around RMG's website and found a couple more launch plans dated 25th of April 1785 by Adam Hayes, namely ZAZ7353 (21ft), ZAZ7352 (22ft), ZAZ7351 (26ft), and ZAZ7348 (30ft). I figured, if there is some proportional rule to the construction of these boats, comparing the plans would reveal it. So, I did the unthinkable, created a spreadsheet. Here are the results:
I hope the measurement descriptions make sense. Everything is in inches. The "/lenght" columns refer to the previous measurement divided by the lenght of the boat.
I was also curious if this exercise could help me with the question for the height at which the lower points for forming the sternpost and the rudder are set, if at the height of the base-line, or at the height of the keel's base. An example will make it more clear, the sternpost's outer edge is a line that passes through the aftmost edge of the sheer strake, and through a second point down below, that is either at the height of the base-line, or at the height of the keel's base, I don't know which.
Although the spreadsheet gives pretty damn similar proportions between the different boats at both the base-line's and keel's base heights, I think those at the base-line's height make more sense, that is 1/30 of the lenght = sternpost width, and 6/100 of the lenght = rudder width, at least for the three longest boats, .
What do you guys make of it? Do you see any other proportions that also make sense?
-Arthur
- Thukydides, iMustBeCrazy, mtaylor and 2 others
5
Guys, thank you a lot for the posts. This little into the project, I already got some valuable insights!
15 hours ago, iMustBeCrazy said:You might like to look at ZAZ7239, it gives some insight including dimensions down to the quarter inch and varying gaps between stations.
Sheeesh, those are really inconsistent gaps. Can you see some logic behind them?
14 hours ago, Waldemar said:Nice. And what about trying to find the lengthwise position of the master frame in a proportional rather than just dimensional way? There are several possibilities to check – as a reference length you might eventually find the length between perpendiculars, the length between posts (if different from the previous one), the length of the waterline or the length of the keel (both tread and touch).
You could also check the ratio between rakes of the stem and stern posts. And their ratio to the total length as well, both individually and as the sum of the two.I like the way that sounds, Waldemar! But, how do I know which proportions to look for? I mean, any division between two lenghts will give me a proportion, how would I know what is correct? I've had a look through The Elements and Practice, in the 'GENERAL OBSERVATIONS ON THE PROPORTIONAL DIMENSIONS' chapter, and I couldn't quite make out something aplicable. Maybe I can get somewhere by comparing different boat plans?
10 hours ago, Waldemar said:Arthur, if you decide to investigate this at all, especially the lengthwise position of the master frame and the like, I'll just hint, just to be safe, that Rhino's command ‘divide curve by number of segments’, is very handy for this purpose.
Got it!
13 hours ago, vaddoc said:Very nice drafts Arthur! Nice surfaces and offsetting.
You ve fallen down the rabbit hole of CAD - I suspect you ll never find the way out!
I think Rhino is fine for our purposes, which is basically lofting boats and getting patterns to cut frames etc and is very user friendly. But I think any CAD can do this. For advanced rendering maybe other options are better but to build a boat, this is not needed.
In the 18th century plans were not hugely accurate and thy did not to be - just shim any gap. However paper gets distorted after all these years and CAD is very unforgiving so some lofting is still needed but not too much - the wood will correct lots of tolerances.
Perhaps have a look at my longboat, maybe you ll avoid some of the mistakes I made.
Best wishes
Vaddoc
Ohhh I will not indeed, Vaddoc! And drafting in CAD is quite addicting. Hours will go by and I won't notice it. I definetely will spend some time taking a good look at your longboat!!
On 11/20/2024 at 8:37 PM, 3DShipWright said:
@Arthur Goulart - BTW, I didn't mean to seem negative on Rhino.... still a good software, and I'm excited to follow your build.
By no means! You guys just gave me something new to fiddle with 🤣. I went with Rhino because I thought it was the best out there for our purposes, but nop. I'm sure glad I'm still just using a free trial, because Rhino is quite expensive. A free and better alternative? Count me in. By the way, those boats look awesome.
A little disclaimer at first, when measuring distances off of the plans, I'm looking for the most logical values. That means, I don't think that when setting a line someone would go with the "7/64th of an inch" option, specially because, keep in mind, these plans were drawn at scale. When two possible values get close to the lenght of a given line, I'm picking the rounder one. As a general rule for this project, 1/2 is as far as I am going when dividing inches, unless there is good reason to think a more specific value is correct.
Onto the first steps.
The first view of the ship to be drawn is the sheer plan, that is, the side view. We start off with the base-line, which coincides with the upper edge of the rabbet of the keel, on ships, it ends perpendicular to the fore and aftmost edges of the lower deck. On boats, however, it stretches from the aftmost edge of the sheer strake to the foremost edge of the stem, and represents the lenght of the vessel, so, in our specific case, 23ft. From both ends of the lines, two perpendiculars are drawn, these are important references for other lines to be set.
Next up, to set the midship perpendicular, which not always is precisely amidships. Here it is 10'10-1/2" from the foremost perpendicular. From it, the other, evenly spaced, perpendiculars are drawn. For our launch, they are a weird 1'2-3/8" of one another. I came up with that for two reasons: that value aligns much better with the H and 9 perpendiculars (the outmost ones) of the original plans than a 1'2-1/2" spacing; and, because the plans for a 30ft launch (ZAZ7348), by the same author and date, show, again, the same 3/8" spacing, 1'3-3/8", in this latter case. I wonder the reason behind the odd choice.
The stem is mostly formed by arcs centered 3'4" up from the base-line and 3'10" aft from the foremost perpendicular. That point is reassured by its correspondence with a little dark spot on the original plans, that I assume is where the point of the draftsman's compass laid. From it, with a 3'5" radius the outer edge of the rabbet is set; with a 3'4" radius, the inner edge of the rabbet; and, 3'2-1/2", the inner edge of the stem. These latter two arcs, however, are fictional, they do not correspond with how the finished boat might've looked in the past, and will not stay this way on the finished 3D model. More on that later, they are good enough for now.
To the keel and outer edge of the stem. I previously thought that the base of the keel was a little too wide on the sheer plan: the body plan shows a narrower version (more like 6" from the base-line instead of the 6-1/2" shown in the sheer view), and that means that a 3'10" radius from the same center already discussed would intersect perfectly with both the foremost perpendicular and the bottom of the 6" keel. But, the neat result was a bit too off in relation to the plans to my likeing. One particular detail came to my attention, 3'3" from the foremost perpendicular there is a sharp edge, that suggests a not too perfect junction between the stem's outer edge and the keel's base, a bug or a feature? I came to the conclusion that it is, indeed, a feature. Many plans and models show such an edge (the Medway longboat for example), and notably, that 30ft launch (ZAZ7348) by the same author and date also features that edge, and there it looks even more intentional. So, I now have adopted a 6-1/2" keel width, the outer edge of the stem is made by an arc that is centered on the same height as the center of the other radii that form the stem - so they end at the same height too -, but that intersects the base of the keel 3'3" aft off the foremost perpendicular. That solution is much more in line with the plans.
- Arthur
- Waldemar and Thukydides
2
On 11/19/2024 at 5:15 PM, Loracs said:
On this topic, any good reference on modeling ship with CAD software. I'm an utterly beginner planning to try using FreeCAD/blender, both of which I never really used. They are freeware and quite comprehensive though.
Loracs, I'm using Rhinoceros, I found it to be rather intuitive, messing around with it a little and some quick google searchs have gone a long way for me. I have not tried something different, so I can't compare. Rhino seems to be what most folks use here too. And, part of the reason I started this topic is that I haven't found one that adresses my questions regarding redrawing plans, so I hope to crowd source some knowledge through here.
So, I wanted a not too complicated to learn both 3D modelling and ship construction. I decided to go with a ship's boat, because you can't get much simpler than that for a first scratch project, and because the result might come in handy in the future for ships that, well, will be fitted with boats. Imagine the designer behind the plans had access to a CAD program, that is what I'm aiming to achieve. Thus, I'm looking at understanding how ship's lines were formed, so I can reconstruct this little launch from principle, not from merely tracing all the plan's lines. With that, I hope to get a more accurate model to the original designer's vision, by mitigating the limitations of the hand drawings and measurements of the time, of the 200+ years of wear the plans have been through, and of the distortion the scanning process might've added on top of it all.
On this topic, I'll be registering my progress, in a step by step manner. I insist that you guys point out where I've got something wrong, even if you're not sure of it yourself, we might learn something by looking into it! I'm expecting to make plenty mistakes, and the purpose to pick something simple is that I can start it all over again without pulling too many of my hairs off.
So far, my main reference has been The Elements and Practices of Naval Architecture, from '§ 2. OF THE CONSTRUCTION OF THE SHEER DRAUGHT OF THE EIGHTY GUN SHIP, FROM THE GIVEN DIMENSIONS' (p. 242) and onwards. Steel's book is aimed mostly at full on ships, but many instructions are aplicable to our purposes, many require a fair deal of interpretation - he is not the most clear and didactic, which is not helped by my still limited knowledge of ship building vocabulary, and by english not being my first language.
Why this 23ft launch was picked, specifically? I tried a couple different boats out, I made some sense of this one the faster. The stem's radii and those of the midship frame are really important dimensions that I struggled with on other plans, but that I fairly confidently figured out for this launch.
My take is that ship's boats were neglected subjects in their time, at least from a more technical stand point, and that today they likewise get less attention when compared to the more complex and exciting subjects, hopefully this will be a more thorough and complete reconstruction.
The next post, I'll take you back to the beggining of the model's construction, but, for now, I'll leave you with how the model is looking present-day:
- Arthur
- druxey, AnobiumPunctatum, cotrecerf and 3 others
6
- yvesvidal, Thukydides, cotrecerf and 1 other
4
Incredibly neat work!
- mtaylor and Stuntflyer
2
Chuck,
I've been silently admiring your work over the last few months. I'd really like to build one of your kits, but I can't really justify it atm. See, I live in Brazil, currency conversion makes costs pretty proibitive, add to that 60% import tax (I mean... That's insane). That, and I'm fiddeling myself through building a MSW Bluenose, but it's more of a scratch build project at this point, because the kit is really that poor, anyways, that's a tangent. The point is, I'd definetely buy that small boat if you were to sell it as a regular project. It looks like it will be a quick, well put together, relatively inexpensive kit, and I'm all for it.
Cheers!
I found Endymion on the RMG website, gents: https://www.rmg.co.uk/collections/objects/rmgc-object-81924. As per described by the Science Museum,
built in 1779, 44 gunner.
Funny, my untrained eyes wouldn't think such a beautiful ship came from those plans.
On 8/21/2022 at 5:42 PM, Retired guy said:
Hi Arthur how's the Bluenose coming along, and yes you are correct this is Mrs Victory have had since 2004 but been working on and off for the last couple of years.
Too slowly, Richard 😆. I'm really struggling to find the time to work on her, but so far, I'm happy with how it's coming along. I'm modifying the the kit pieces so they are more accurate to plans, and I'm improving on its construction method, for instance, I'm making the keel/stem as separate pieces, to be fitted down the line, once the planking is already finished. I'll be posting it all on my thread, but none of it is yet finished, so...
You love to see it, Retired guy's Bluenose update.
I take it the other ship you're distracted with is the chomky fella there on the background, Mrs. Victory?
- FriedClams, BenD and Dave_E
3
On 4/16/2022 at 5:44 PM, Retired guy said:
Hi Arthur did write a reply to your question on my Bluenose hope you saw it and here are some more tips.
I read the instruction manual and went with the stages, they are very clear and I had no issues.
Make sure you add the reference line to the Keel pieces also the bearding line, and then add reference line to all the bulkheads ( this will help to see if you need to adjust any height issues) and at the same time trace and mark all bulkheads with side bevel on both sides and then sand these before installing this really does help down the road.
These are all the tracings I did
You can see the reference lines in this picture
Hope this helps and have fun
Regards
Richard
Thanks for the tips, Richard, on both threads!
Good that you mentioned beveling the bulkheads before installing them. I was planning on marking the bevel lines, but only sanding after installing all the bulkheads, is there any disadvantage to this approach?
On 4/15/2022 at 4:40 PM, Retired guy said:
Hi Arthur thanks very much for your kind comment hope what I have posted helps all Modelshipways Bluenose
Regarding the keel pieces they do not fit one another and it is the middle piece, lay the keel pieces on the drawing and line up the top if you have to adjust the keyways between all pieces do so then you will be adding some wood to the bottom of the middle keel piece.
From the picture you will see how much was added and also the left keyway you can see I added little stipes as well
8
Hope that helps.
Regards
Richard
It definetely helps, Richard, thank you!
Yeah... I think I'll have to adjust most of the keyways. On all three pieces one of the keyways aligns up perfectly, another one or two are similar enough to the plans - I think I can get away with just widening those a little -, and the rest of them diverge quite significantly. Also, like the middle piece, the forward one is thinner than it should be. Maybe I'm too picky, i don't know. I expected these laser cut parts to be more precise. If some error was inevitable, they could, at least, have thrown it to the overdimensioned side. Easier to remove material than to add.
By the way, happy easter, Richard!!
- Nirvana and Retired guy
2
On 4/15/2022 at 8:08 AM, wool132 said:
If you haven't already found it, the build log by GenericDave is an excellent reference. The complete version is on his external website, SuburbanShipModeler.
As you stumble along, remember the inspiring words of Homer Simpson: "Trying is the first step towards failure".
Jonathan
Oh yes, I've found it! It's a very well written and well illustrated series of articles. Gary Brinker's youtube videos are also a great resource, I just wish they were higher resolution. I appreciate the tip and the wise Homer Simpson words! 🤣
13 hours ago, Keith Black said:Arthur, wishing you the best on your first steps into the world of wooden ship modeling. Building model ships is a lot like bird photography, it requires a tremendous amount of patience and never giving up.
I love that comparison, hopefully them birds have taught be something. Come to think about, it is probably no coincidente that I'm interested in both these fields.
Hello good sirs,
20 year old law student from Brazil who spends his internship money on ships, that describes it. But really, I love the craftsmanship, the preciseness, the small little parts about scale modelling.
My first attempt at it was actually plastic modelling, but I didn't have the proper tools, parts got broken, parts got not neat enough, I got frustrated by how my model was coming along. And well, one can't really replace complex plastic parts, I'm a make 4 version of the same thing untill it's good kinda guy, and plastic didn't give me that oppotunity. Also, plastic modelling is mostly about painting I feel like, layers and layers of weathering, complex masking, varnish, decals, more varnish, more weathering. I came to the conclusion that I like the building part of it, not so much the painting, and, let's be honest, wooden ship models are much more elegant.
So, here I am, my first wooden model arrived last month, and I'm figuring it out slowly, reading a lot, watching a lot of tutorials, and planning a lot. It's build thread is up by the way, help me out:
Photography is the other hobby of mine, and throrought 8 years, even a little more, I've gone to some amazing places and seen incredible creatures persuing those great clicks. In case you are interested: Arthur Goulart (@arthurmgoulart). It's South America wildlife. Just a word of caution, I'm a lazy editor and an even lazier instagrammer.
Anyways, happy to be part of this amazing community. I've been following the forum for a while, it was about time I got in.
- Keith Black, ccoyle, Ryland Craze and 1 other
4
On 4/14/2022 at 1:21 AM, Nirvana said:
Arthur, first of all - A Warm Welcome to MSW!
I am glad you got the Bluenose as a starter.Yes the dowels for the mast and booms are a disaster in the kit.
Mine was badly warped as well - and today again - I went to my hardware store and got some straight dowels. This to start all over again with the masts.
As for the Bluenose herself, I would suggest to get going with her before attacking the dories.
This will give you the skills to handle the smaller and more delicate items in the kit.
However I am looking forward to see your progress, and if you have questions - don't hesitate to ask!
Thank you for the welcoming Dr. Per!
I'm pretty excited to be here, builds as yours and Retired Guy's will be of huge help to my own. Not to mention the various tecniques, products, research, crazy well built models displayed here. I've been following Model Ship World for a while, I found the forum through Chuck's work, and well, it's a great community, by what I've seen, very helpful and willing to share, it was about time I joined.
I've actually started the Bluenose itself today. I got the keel pieces off the sheet, checked with the plans, and... They don't match up. Some of the bulkhead slots are offset. The keel pieces actually don't even match up with eachother, the back piece doesn't fit properly with the middle piece, the fit is loose and the back piece is wider. So, I've got some figuring out to do.
I'll keep you updated of my progress, and questions, ohhhh, I'll be asking many of those. 😄
- Keith Black and Ryland Craze
2
Richard, do I love your build, omg. Clean, that defines it. Best Bluenose build I've seen.
I started my Bluenose today, got them keel pieces off the sheet, checked with the plans, and... They don't match up. Some of the bulkhead slots are offset. The keel pieces actually don't even match up with eachother, the back piece doesn't fit properly with the middle piece, the fit is loose and the back piece is wider. Did you have these same issues? If so, how did you fix them? Did you manage to get the keel perfect to the plans?
Anyways, I'll be definetely following your build along, and checking it every once in a while as reference for mine. Keep it up!
Cheers from Brazil.
Alright, time for ya'll to follow my struggle.
The Modelshipways Bluenose will be my first ship model, I got the kit pretty cheap - $90,00ish - on the "Help us Move" sales Modelexpo just had. Huge model for a begginer, but since I live in Brazil, and it takes around two months for anything, really, to get here, I figured that I would get the big ship and double up on research time.
So the kit arrived and, naturally, I have some noob questions that I'd like to ask you gentlemen.
Dowels, regarding those.
None of them are perfectly straight but then there is this one:
Would it work to heat it up and straighten it, as you do with planking? Or would the wood eventually warp on me again, and thus I should contact Modelexpo for a replacement?
Also, my kit came with two different types of wood for masts and yards - basswood and green vietnamese stuff-, which I'm not too fond of, I'd like to keep it consistent. The basswood, as I understand, isn't the best for masts and yards, due to its softness. So I might be looking into getting some nicer wood for that.
As for the green vietnamese stuff. What is it? It feels light, it's fairly small grained, it's pretty consistent, it's kinda green, and it's "from vietnam" labeled:
Last question: I have some Mr. Hobby lacquer paints at hand, are there any cons to using those on wood instead of acrylics? Lacquers seem to be often used as clear coats over wood, but better ask, they're much more agressive than acrylics.
Afraid to screw up the big expensive ship, I decided to get my first taste of wood modelling with the dories. Overall, I'm pretty happy on how it's been going, even though the by the manual method of building them is hopeless. The jig Modelshipways provides is too fiddly, and there is no way, no way, the thin wood frames would hold the boat to it's proper shape, as per suggested. I won't elaborate further, getting you to propper understand the problems with the kit's dories would take a lot of text and some images, and I don't think you guys are interested in that. Rather, I'll show you what I'm currently doing about it:
These are the leftover of the laser cut pieces for the jig that should be used to get the dories to their correct shape. I've cut off the jig's "footprint" from the waste portion of the laser cut sheet provided by the kit, if that makes sense". Now I'm converting those "footprint" pieces into a small POB model, I'm making my own keel and bulkheads. Then, i'll add some filler blocks, make the boat a solid piece of wood, and use it as a template for constructing the dories. I'm currently aligning evrything up and shaping the boat's top.
That's it for now.
I look forward to learning a lot from you!
Cheers!
2
23ft Launch (1785) by Arthur Goulart
in CAD and 3D Modelling/Drafting Plans with Software
Yeah... The abyss has stared back at me, nothing I can do about it now 😆. I can already see some ways the comparison will be useful in the upcoming steps, I'll probably be able to improve, or be reassured of my design for the boat's rake, sternpost and rudder. Having those four other plans is quite the unique opportunity to understand what was the designer's process.
And on the topic of Marmaduke's Naval Architecture, I'm actually kinda surprised I had no idea that book even existed. I had a quick look through it, it seems to be just the thing for this project, much more complete than Steel's when it comes to whole moulding, and that plate 1 find was a great one, @iMustBeCrazy!
And btw, do any of you have a pdf for The Shipbuilder's Repository? I have looked everywhere for that and found nothing but crazy expensive physical books.
