Jaager
Posts posted by Jaager
  1. Congrats, citrus is supposed to be excellent for
    our uses.  It is just darn near impossible to
    obtain if you do not live in a subtropic region.
    The method that I use now for framing has a need for
    2 inch thick stock if building a 3rd rate or larger at
    1:60 or larger is a project.  Otherwise, 1 inch is just
    the ticket and should be treated as Jim has advised.
    In addition coating the cut ends (including cut off
    branches) with a thick coat of latex paint if you have
    any left over from house painting, or varnish or
    coat with melted paraffin.  The point is to slow
    the rate of water loss to something close to or less than
    the rate from the side surface.  In most species of trees
    this reduced checking and splitting.
    Once you have the billets, you can use the bandsaw to freehand
    shave off the bark.  This speeds water loss or at least equalizes
    the rate at that surface and removes any bark beetle infestation.
    If you do not have use of a bandsaw, a draw knife is a quick way
    to shave off the bark.  Other edge tools work, it just takes more work.
  2. A function of wales = to provide additional strength to
    counter the weakness caused by gun ports?
    There may have been a change in gun weight and/or
    force produced by the powder charge that was a reason
    for the addition of another thick strake.
    Also the ledge produced by the thin strake above the lower
    wale would be an entry point for water into the hull that filling
    in the gape would remove.  Perhaps they got tried of doing
    the extra work maintaining that caulking.
  3. Russ,
    I got that one too.  It does not need to meet much resistance before it
    stops.  I tried a  " 3-12V, 2A Selectable Output Supply "
    Found one for $15  at Marlin P Jones -  and it seemed to work better
    with more juice - so the problem may be the power supply.  I can't be
    sure because I need to get parts to make the connection.
    The power supply wants banana plugs  - which end with alligator clamps
    or bare wire and the tool wants a plug like computer external HD DC power
    supplies use.  I am waiting for Jones to restock some other parts before I
    order.  Maybe more Volts will burn out the motor but it is that or nothing.
  4. To answer your first question: no.  A plank bender is not essential.
    The type that you may be looking at is a soldering iron with a specialized
    attachment with a French curve type surface.  There are several ways
    to bend planking and that tool may not be all that good a choice.
    There are several threads here on the topic that you might review.
    At the least, Harbor Freight has a low end resistance iron for $4 if you
    want to try a dry heat method.
    For hull mounting clamps, there are vac base and screw clamp swivel vises
    of various sizes and prices.- an electronic catalog has one for $13
    and will multitask more than a dedicated tool.
  5. This outline may well be a novel, but this is how I organize the
    progression of framing.
    It is a progression over a long time period, but the introduction
    of trade with the East added a profit factor and an incentive to
    develop larger and faster vessels.
    I will start with the Dutch about 1600.  As per Hoving,  the hull
    started with the keel, stem, and stern post and with or without a
    few intermittent molds - the bottom planking came first and the
    timbers - floors and futtocks were then added.  The design was
    tradition based and followed "rules".  The timbers were a bit
    irregular in length and probably width.  As late as 1669 the
    framing that Dik shows for the 7P has the floor and its follow on
    timbers as a continuous unit to the rail.  The first futtock half
    laps it and starts well up from the keel.
    The English probably wanted a more scientific or at least more
    predictable method.  Whole molding was the method to develop
    the molds mounted on the keel - there were probably more of them than the
    Dutch used and ribbands (rib bands) were fixed to the molds to
    define the shape.  The floors and futtocks were cut to fit inside the
    ribbands and then the planks were fitted.  The timbers were probably
    not artful to look at and the first futtock started well above the keel
    and scarped (sided jointed) to a floor and second futtock.  I suspect
    that there an air gap on the other side - with or without clamps in the gap.
    The models have continuous joins and the timber lengths were regular.
    This looks better and is easier to do.  Fox describes evidence that the
    open spaces were cut from what was essentially  a solid hull.
    The points I see are about 1670 the models have Admiralty style
    framing.  By 1719 the models have free standing paired frames
    with or without continuous butting filler frames.
    I imagine it was a time of generational conflict and tradition vs.
    "modern".
    At the end of the 17th C. the first futtocks probably progressed to
    the keel and the air gaps became narrower and vertically continuous.
    The paired alternate futtock full frame became favored.  The hull
    shapes outgrew the limits of whole molding and the timbers were
    shaped on the ground using portable molds rather than a mold
    mounted on the keel.  What was probably a confusion of methods
    was probably ended with the Establishment of 1719.
  6. If the water content of the wood was higher than equilibrium level during
    assembly, then the shrinkage should be one way.  A fix now should hold.
    If the wood was at equilibrium during assembly and its environment has
    changed enough to open the seams,  I would worry that a reverse change
    would cause a swelling effect.  If a repair that filled the cracks was made
    using a hard material, then a swing to swelling would lead to a buckling
    stress.  If the fastening is strong enough to resist the hydrostatic pressure
    then all should hold and the water molecules would be kept out, rather
    than the wood move.  If the water pressure force is the stronger one, then
    the planks would probably pop up.
  7. As a true plastic, I am thinking that it would be the least effective surface to use PVA on.
    I do not use CA, and since (as I understand it)  CA has poor shear force resistance to begin with,
    it is not likely to be a good choice there either.
    I have used poly on a kitchen floor and on paneling and bookcases, but when  attempting
    to emulate the old craftsmen and artists of the 17th C. and 18th C., poly does not appeal
    to me for use on a wooden model.
  8. Most varnish products will probably not play nice with most glues.
    The glue will "bond" to the finish rather than the wood.  With no
    pores there is no penetration so any bonding will be electrostatic
    rather than mechanical.
    Traditional varnish is boiled linseed oil "cooked" with shellac - organic solvents.
    These days polyurethane seems to be more popular and there are
    water based varieties.  It is a synthetic plastic.
    If you are doing an upscale modern yacht, varnished decks may be appropriate.
    You wear no scuff deck shoes to walk on them.
    For most other classes of wooden ships, a slick varnished deck would be really
    dangerous for the crew.
    Because of scale effect, a flat or egg shell finish even for high gloss prototypes -
    or at most matte..
    You might consider super blonde shellac at half strength ( 5%) * and rub it down
    with 0000 steel wool or a Scotch Brite pad.  In any case, if you intend to apply a
    finish before adding and gluing down additional components - it would be wise to
    occlude the glue sites with painters tape or masking tape.
    *  orange shellac is full strength at 20 lb cut ( ~ 20% solution in methanol,
    ethanol (denatured) or ( Pharmco grain - 95% - if you do not mind paying the taxes),
    or anhydrous isopropyl.
    It will darken the wood.
    super blonde shellac is a very light amber.  The purification process removes components
    that help solubilize it - so - full strength is 10 lb cut ( ~10%).  Primer or 1st coat = 5%.
    There is a bit clearer grade: plantina shellac flakes - but it is not that lighter and costs about
    twice what super blonde costs.
  9. It may not be a significant level of energy with LED lighting or florescent either, but
    the way greenhouse effect works is that  some visible energy photons will degrade
    to IR when they strike something inside the chamber and the transparent material at
    visible will reflect IR and keep it inside.  Granted, most will stay in the visible spectrum
    and reflect back out. - We would be able to see what was inside otherwise. - But while
    a UV filter may protect against the chemical reactions that UV produces, I doubt that
    it would negate a heat build up in an efficiently sealed chamber.
    With your room lighting, the lack of heat with LED even given your high light level, shows
    just how inefficient and IR heavy incandescent lighting is.  However, given where you
    live, there may be parts of the year where you might miss having a little extra IR.
    When I was using  300 W of bulbs to heat a homemade kiln 24/7, I did have a measurable
    increase in my electric bill.
    Our philosophy seems to be in tune, I also have a tendency to over engineer my designs.
  10. I have thought about the same ideas.
    For the gas to remain, the container would have to be
    air tight.  The walls are transparent, so light can enter.
    Being totally sealed, there is a possibility of an extreme
    greenhouse effect and the container becoming oven-like.
    There is a problem with this - even in a not  totally air tight situation.
    Joel has it correct - vent holes for circulation for both temp and
    removal of outgassed compounds.  PVA wood glue would probably
    release acetic acid.
    My thinking is vent openings at the top ( for temp ) and probably
    also bottom for circulation.  The trick would be to keep dust out.
    Too dry - the wood may check and split over time.
    .The museum standards for ship models are probably intended to
    preserve a model for as long as is practical - by using materials that
    last to begin with.
  11. The linen supplier twists up the fibers into yarn.
    This is sold as LEA - which is essentially an obsolete measurement - it has been replaced -
    but I have not mentally absorbed it. Since I have obtained about as much and as wide a
    variety of linen yarn as is obtainable now, I don't need to deal with the change.
    And yes,  with LEA - the larger the number - the smaller the yarn.
    From our perspective  the hope would be that  70.2  LEA yarn would be 2 lines with a final size of 70,
    but alas -  what it means is
    Two 70 LEA yarns twisted together and sold as a loosely twisted  thread..
    If unraveled  it would be   two 70 LEA yarns - not two 140 LEA - which would be nice for us
    except -  twisting up the 62 LEA is difficult - it breaks easily - so that may be the practical limit.
    I finally got why the old guys favored linen - the linen wrapping on Egyptian mummies is still largely intact.
    It does not readily oxidize.
  12. Your Dremel will get you there.  There are external speed controls (solid state) if you find it
    burns your work.  To be prudent, you may wish to avoid buying another powered rotary tool
    until you are far enough in that you know what you need.
    Pin vise =  hand power- - there is a variety of them.  A basic General - 4 size collets - metal
    swivel is a good first choice.
  13. Mike,
    I also see the ambiguity with the breach rope length, but
    when thinking about it - do the experiment with the scale
    model - if the recoil distance is 24 feet?  Is it so far as to
    smash gun crews on the opposite side or roll the gun over
    a hatch opening  ( as much as those guns weighed, there is
    a chance that only the sea floor would stop it.)
    The tackle -  left taut - it would slightly restrain and spread out
    the recoil stress.  It would also stress the tackle gear and probably
    shorten its working life.  In the ciaos of battle - I wonder if fingers
    could be lost if the gun were fired before crewman loosening the gear
    finished.
  14. I would think that the goal would be to have the recoil be enough for
    the gun to be sponged, cleared, loaded, and rammed while inside the
    ship.  Plus, anyone outside the ship would make a tempting target for
    the Marines of the opposition.  But, since the gun had to bet returned
    to brace the trucks against the spirketting,  it would be inefficient to
    have the hauling distance be any more than was necessary.  Keeping
    the work of hauling at a minimum and having the load and fire interval
    as short as possible -  both important?
    It seems likely that there were tables giving breach rope length for
    each caliber or barrel length of gun.
  15. JMS,
    My comments on size were not directed at your work. I apologize for
    my wording that makes it seem so.  I was influenced by pix of
    recently finished models.   I am thinking that in general,
    the ratlines should be much less than the shrouds they are tied to.
    Your jig is very clever.  It would also work well with a bubble level to
    assist in keeping the line horizontal.
    An old technique was to sew the actual ratline thru each of the shrouds
    and then cover the join with a knot from a separate line trimmed off.
    I had dismissed this, but with your jig and using a line that is finer than
    the ratline itself to make the knot, the result may look better.
    The clove hitch using the actual ratline has always looked a bit "fat" to me
    and has done for about 40 years now. Using a thinner line should fix the problem
    of scale with the knot.  If the knot material was saturated with diluted
    neutral pH bookbinders PVA, it should hold well and the ends trim off cleanly.
    Sorry, more arm chair experimenting here.
  16. This is an excellent idea.
    I wonder how it would work out to use the paper grid and with this tool,
    instead of working from the top and bottom, to do
    top-bottom- middle - and then the mid point of the two open
    spaces. then fill in.  This could reduce the effect of a creeping
    compound error.
    I am also wondering if the result would look better if the size of
    the ratline rope was somewhat less than the literal reproduction
    of the actual scale diameter.  The horizontal lines would then fade
    into the background a bit - which I am thinking would be the way
    it would have actually looked.
    Looking at grid-like components - such as window muntins  and
    gratings - given scale effect - would they look more pleasing to the
    eye if they had reduced scantlings from actual scale?
  17. Bob,
    I was thinking that a vac will pull the same volume of air / unit of time irrespective
    of the pipe diameter from infinity to a diameter that is small enough to offer significant
    resistance to flow.  The suction at the business end would depend on the aperture.
    If the problem is with the flow being sufficient to keep the suspended material in the air
    stream and not settle out inside the tube, I can see where the kinetic energy within the air
    stream would be affected by the pipe diameter ( the other factors being constant).  I guess
    this is another Dennis Moore type situation.
  18. Bob,
    Pharmacology here.
    Thanks for clarifying.  My basic education mostly involved linear Arithmetic and
    Mother Nature's Math is Calculus.  My intuition is based on the wrong Math so I
    am constantly surprised by how things really work.  What impressed me the most
    about the equation was that it does not take much change in diameter to produce
    a profound effect on air flow in the lungs or blood flow to the heart, etc. - that the
    smooth muscles that regulate do not need to constrict or contract all that much to
    do their job.   It does not help intuition that Pharmacology tends to use a 16 oz hammer
    to do a job that a tack hammer would do better.
    With the sealed type system being discussed here, Although using 4 inch piping for
    the long runs may be more than is needed and more expensive is space and money,
    it should not negatively effect the system.  The question: does the reduced resistance
    have a significant effect on the efficiency on the system and the stress on the vac motor?
  19. Expecting that all PVA brands should behave in a similar way:
    I use Titebond II - I squeeze a working quantity onto a piece of
    wax paper.  The left over material goes from an opaque tan/cream
    to a clear amber an no matter how many layers build up - ( I use the
    same piece of wax paper for a long time)  the dried and polymerized
    glue is flexible.  If what you have is brittle when dried - it is likely a bad
    lot.
  20. If I read this correctly: you are concerned about PVA-yellow having too weak a bond based on a temporary
    bond being reversed too easily?
    First - I think you were lucky that it reversed without major damage.  A different type of glue would be more suited
    for the temp function -  although spot and IsoOH to dissolve would work - I just would tend to use too big a spot.
    If both surfaces are totally covered before bonding, I think the "joint starve" problem is a fiction.
    The glue works by undergoing a chemical reaction - polymerization - as it dries.  It essentially forms a plastic material.
    With wood, I am very skeptical that all of the glue could be squeezed out - the wood fibers would crush at the clamp face
    before that happened.
    The stronger the clamping force- the stronger the bond.  Although it is not realistic, the bond would be best if a single chain
    could reach both wood surfaces.  A bigger problem is the nature of the wood surface. More bite is better.  I suspect that
    my compulsion to use 220 grit is right at the point of the surface being too smooth.
    With planking - I doubt too much force is a practical problem - too little is much more likely.
    The wood surface should be free of any substance that could interfere with the penetration of the micro chains of polyvinyl as they
     assemble.
