Posts posted by Rustyj
Hi Ben and welcome back! I look foward to seeing your updates.
Moving on making frames here and I forgot to mention that when I added
the chocks to the frames I left them a little proud. After that I used a spindle
sander to clean them up.
Here I’ve placed the bracing around the keel on the building board to hold it
in place while I test fit the first of the frames.
Here are the first two frames set temporarily on the keel in the jig.
Hi Jim B,
I have the same as Jim L and agree100% I also would buy your's, when you finish making it, tomorrow!
Hi Chris, Very nice work on those rails. It is a fun area especially when you did such
good work setting it up. It's important to remember that work very early in a build can
have a major impact later on. I should know!
Well done.
I do think the natural walnut has become my choice already.
Me too!
Working on the frames here and there is an interesting way they designed the sweep and gun port openings. As you can see from the plans they are all cut out prior to installing the frames. I used the
Byrnes table saw and disk sander to make the cuts.
The nice thing is that if they are off a bit I can adjust them as the upper hull
is planked inside and out.
Thanks Paddy,
You know you can always have the plans reduced to the Triton scale. It would
save a lot on the wood costs and completed size. If I had to purchase the wood
in 1/2" billets I don't think I would have done it at this scale either.
Thank you Pete, Bob and E&T for your interest!
Hi Bob, Slow or not she's looking good!
Hi David and E&T, Thanks for looking in. Sorry for the delay but I missed your posts.
Well I’ve finished the Triton cross section and she’s safely tucked away in her case.
Now it’s time to get back to the “set up”. Now where was I had left off? Oh yes I had
completed the keel and now it is time to cut out the pieces for the frames. There are a
total 17 frames 5 of which are doubles so that’s 22 frames to make. I will take and cut
up the frame plans and use temporary paper glue to adhere them to the cherry billets.
Then I will use the scroll saw to cut them out, over lay them on the plans and then glue
them up using wood glue. It doesn't show but remember the wood for the frames is
1/2" (12.7mm) thick.
And here is a single and double frame all glue together and the chocks added.
Two down and a whole bunch more to go.
- captainbob, harvey1847, popash42 and 3 others
- 5
- 1
Great start Bob. I look forward to your improvements and modifications.
Should be fun for us all.
Hi Glenn,
Good to hear from you again. I devoted the bulk of my time recently to finishing
the Triton Cross section. Now it’s time to start things back up again.
Hi Jim,
I’ve used the foam center sanding sticks but never tried a paint stirrer before. Great idea.
Hi Bob, Happy Birthday and congratulations on finishing up your build. Very well done.
It was a joy watching along and I’m really looking forward to your Essex. I know seeing
your work will tempt me to build her too but I must remain strong! Enjoy.
Great work on the entire build Grant.
That happy/sad moment of completing her is approaching fast.
That's a very nice fit. Very good Paddy.
Hi Grant, I too would like to echo the very nice job on the brackets.
Thank you Kevin, Grant and Christian.
Hi Paddy. No documentation. I saw it done that way in Chad’s build log, liked it so I did it that way too
Bomb Vessel Granado by Rustyj - FINISHED - 1:24 - cross-section
in - Build logs for subjects built 1501 - 1750
Hi Ben,
Thanks and it's great to hear you are back from your vacation.
