Rustyj
Posts posted by Rustyj
  1. Hi Ben, Yeah I thought it was kinda neat. I had set the sander next to it while getting more paper
    then thought it was a good reference to the size.
    Thanks Mark, I guess “different” would be the correct word. The size throws off what we are used to
    doing. When doing joints a little flick of a chisel or knife would fix a bad fit. Here a little off requires
    the removal of a ½” wide piece of wood!
    On the plus side there is a lot more to hang onto so the tips of my fingers have suffered less. :o
  2. Hi Ben, Thanks for your continued support. I’ve done a couple of admiralty
    style POF’s already and I’m not sure when I will do a full one again.
    So many things to build. ;)
    Well the floor riders have been shaped and installed along with the motor deck
    clamps. I’ve also placed the first of the inboard planking between the keel and
    the deck clamps. The channel has been cut for the limber boards too.
    Seeing that the clamps and riders are installed the framing is stable enough to fair
    the outer hull now. So I took her outside and seeing she is so big I was able to use a
    palm sander I normally use on full size work to rough her in.
    Here you see one side has been done with 80 grit. I’ll work out to 220 grit for now.
  3. Hi Ben and thanks. It was good to see you back at the echo cross section but no nothing
    from me on the echo right now. That’s a story I’ll have to post there sometime soon.
    Here are all of the floor riders constructed. Then I took and numbered each one as they would
    be unique as I'm sanding them to fit both the hull frames and the mortar deck clamp.
    Once they are finished and in place it will time to put the limited inboard hull planking.
  4. As I was making the floor riders I looked ahead in the plans at the shell room
    as that comes after the floor riders. I measured up the cannon balls, went to the
    shot locker and I just couldn’t understand why I didn’t have any cannon balls
    big enough. I mean they are only 14mm (.55”).
    So I had a not so bright idea. I tip toed into the Admirals craft room, located her
    stash of jewelry making supplies and found some 14mm beads. Then with the
    saddest face I could make asked permission to use them.
    Permission was granted, hole on one end filled, paint administered and tada cannon balls!
  5. Hi Ben,
    Thanks for stopping by and yes it is fun to experiment. I believe the smaller ones
    are closer to scale so you will be seeing them again.
    Onward we go. The mortar deck clamps have been cut and test fit.
    I have also started cutting out the floor riders and will have to shape them to fit the hull.
    So much fun and so little time! ;)
  6. Grant and Bob thanks for your opinion on the treenails. I too like the larger one.
    To me it’s better on the eye. I’ll hold off for a while on making a final decision though.
    Here I’ve made the false keel. It calls for the top edges to be beveled and to do this I used
    the Byrnes table saw with my new tilting table. Once I figured out the angle it worked great.
    No surprise there. :)
    I then glued the false keel in place. I used a second piece clamping the ends to hold it in
    place. I also put a ¼” thick piece in the middle between the false keel and the second
    piece to put pressure there until the glue dried.
    Next up will be making the deck clamps and floor riders.
