HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
oakheart
Everything posted by oakheart
  1. That is a useful image, shows all sorts of things, even with artistic licence they drew what they saw. Love the rug at the companionway entrance. The open grating caught my eye, alway thought they were one piece. with the companion way, as far as I can make out is shown on the plans with a hinged half lid that flaps back. Thinking more about it, placing the doors on the side and having those crazy trapezoid shaped doors makes even less sense. The plans show the steps running fore and aft in line with the ship. I need to look at some more contemporary models. Tim
  2. Working on the companion way, I was not sure which drawing to go with. Bills shows this bills Danish archive this shows doors are not square, I went with this, it looks a bit odd. needs cleaning up and a skirting added round the base the hinges are just black paper but do allow the doors to open ( I just noticed the doors are hinged on the wrong side ) does not look bad in place on deck Having run out of suitable cedar I used some of the maple deck planks, it does not give a good finish, I may just remake it. Tim
  3. My 1:48 scale has just dropped through the letter box. Quality is fantastic. Thanks Chris @chris watton Now it's out with the paints. Tim
  4. Hi roger @Roger Pellett I have taken to using a tiny centre drill, then using stub drills for small sized holes. Unfortunately, they are not as available in the sub 1mm sizes, a pre drilled guide block can help here, even when made from a relatively soft material like a close grain wood or perspex. Tim Edit : I just found these:- 0.5mm centre drill £11 https://www.shop-apt.co.uk/centre-drills-60-altin-coated-carbide-high-quality-45hrc/centre-drills-05mm-x-60-point-3mm-shank-altin-coated-carbide.html 0.5mm stub drill $18 https://www.maritool.com/Cutting-Tools-Drills-Powdered-Metal-Drills-Micro-(.5-1.9mm)-Nachi-Powdered-Metal-Drills/c78_140_1576_1579/p25040/Powdered-Metal-Stub-Length-Micro-Drill-.0197-dia-(.50mm)-SG-Coated/product_info.html are these cost effective in our hobby environment?
  5. Hi Håkan @Wintergreen thanks for the praise. I can see how jigs are useful, the problem is making them accurately. Thinking about it, I do have a 3D printer, I shall do some research to see if there is anything already done. If there is nothing suitable, I could try and design something in Fusion 360 then print it. A lot of people talk of using LEGO bricks, I shall have to raid my granddaughters collection. Tim
  6. Hi Chris, just went to your website, looking for 1:48 version of your new 3D printed cutter but I could not find it? I need it for my build of cutter Speedy Tim
  7. So enough of being cheerful, back to speedy..... Here is the scuttle with a raised grating. I know it should have a half lap joint at the corners, but I found it difficult enough to get this made. How do you all work this small? I know 1:48 is not that small, but getting things square is a problem for me. The hires Danish archive drawing shows some sort of moulding or profile round the top, not sure how to deal with this? Tim
  8. Thank you Craig. I agree it does seem totally impractical in use, but if I make the 'rudder coat' as @druxey suggested , my bread won't get too soggy. I do love this exploration, it's really incredible that we have realtime access to all of these records so we find find stuff out. Tim
  9. OK, Ok I will change it to the real thing, how do you find out all this stuff................. Tim 🙂
  10. Thank goodness, a quick sand down with 400 grit paper a fresh coat of nonWOP and you can't ( well hardly ) see the join
  11. Today I did the stern grating, I used Chuck's @Chuck Cheerful version which is flush with the deck rather than Bills original version. I think it looks a lot neater. I am annoyed with myself, I had pencilled in bills original size for the grating, then gave the deck a coat of nonWOP. Of course the pencil now shows, I will have to try and sand it out and re coat I learn something new every day. Tim
  12. Have you heard 'Samantha Fish' playing her version? Tim
  13. Thanks Craig @iMustBeCrazy that is a really good illustration, I have made and fitted just 4, it adds detail without getting too cluttered. Tim
  14. I have added a corner timber and I think it really helps to tidy up the stern area. I need to line them all up and glue in place.
  15. Thanks druxey @druxey I may have a go at making one and see what it looks like, a bit more research needed
  16. Now I am confused. I do not get the reference? What I think is that Bill who designed this model in 1972 simplified it to make it easier to build. I am learning to build a model ship from wood and having fun doing it, so adding detail that he left out is part of that. here are two counter timbers made but not fixed yet, should I add two more in the corners, it would also hide that ugly gap. Tim
  17. As you said earlier these details are not shown on the plans and any paintings tend to idealize the ship to look neat and tidy. Maybe I could also add some of the barrels and other details as shown on the 'Kite' painting Tim
  18. Thanks Craig. So as 'Master and Commander' I decree that counter timbers shall be fitted 🙂 Tim
  19. and just to confirm my decision, Vanguard @chris watton is bringing out a new kit for the cutter Sherbourne looking at that, I realise that there is some woodwork missing from the transom on this model, I think I will add that. What are they called, on the transom, those angled timbers. after that - I really am going to line the gun ports Tim
  20. Thanks Craig @iMustBeCrazy I have done some more research and think I will leave it as it is. Why examples of Cutters from that period @Chuck Cheerful looks like this, it's a simple hole Pilgrim BM45 although built in 1895 she is a similar size and style of ship and still sailing. other contemporary cutter models at RMG do indeed show the stern decked or boxed in, it looks like anything you wanted you could have. It does beg the question, with these very simple designs, how did they stop a following sea from spurting up through the gaping hole ? was it just canvas as Craig @iMustBeCrazy suggested? Tim
