Everything posted by JacquesCousteau
Unfortunately, the camber issue remains a problem. I had miscounted while measuring, and the current camber isn't actually of 7 inches (at full scale), but closer to a foot, on a vessel just under 13 feet wide. This is very excessive--if I were to try to use sanding alone to reduce it to 3-4 inches, I would need to remove 1/4 inch of material from the bulkheads! I'm also concerned that adding 1/16-inch shims to the edges won't work very well, as I've realized that it will completely throw off the sheer line, especially at the bow. Viewed from the front, the sheer line should rise somewhat to a point at the prow, which it currently does to a degree that I think looks appropriate. Adding shims to raise the edge seems like it will likely destroy this. Raising the prow is a possible response, but it will significantly change the proportions of the hull. Possibly I could shim the bulkhead edges by 1/16 inch at the lowest point of the sheer and add smaller shims fore and aft to create a new smooth sheer, but this would require a lot of work and I'm not sure whether it would still throw off the sheer/hull proportions too much. But, maybe I'm overthinking it. It's a bit hard to judge, but my sense is that the vessel shown below (from 1940) has a relatively pronounced camber, and it may be that the amount of camber varied significantly. Perhaps I don't actually need to reduce the camber to 3 inches, although I still definitely need to reduce it somewhat. That said, this may simply be very motivated reasoning on my part. Source: https://www.bibliotecanacionaldigital.gob.cl/bnd/629/w3-article-613543.html In any case, I will be setting aside modeling for a couple weeks while I travel for Thanksgiving, although I may post a bit more on historical context.
- 312 replies
- Chile
- Latin America
(and 6 more)
I'm considering how far to go with it, especially given my very rudimentary metalworking skills (and the rather limited space and budget I have for this). Some of the simpler wire hooks seem pretty doable, at least. On the camber issue, after some searching I've seen some posts suggesting 1/4-inch of height for every 1 foot across the deck as a rule of thumb. So, for a 12.67-foot wide vessel, the camber should be just over 3 inches. What I have now represents a camber of 7 inches. If I add 1/16‐inch shims to the sides of the bulkhead tops and can sand down 1/32‐inch from the centerline, I'll have a camber of about 4 inches, which I think would be close enough without totally throwing off the hull shape. I'll have to think about it.
- 312 replies
- Chile
- Latin America
(and 6 more)
Thanks, glad to hear I'm not the only one in this boat (so to speak). There's such a variety across small boats. The plans didn't look like too much camber on the page, but now seem a bit excessive. At the widest point in the hull, the model has a beam of about 12 ft 8 inches (4.75 inches at scale, and not counting hull planking), and a camber of about 7 inches (7/32 inch at scale). I'm considering whether I can just add a 1/16-inch shim at the edges of the bulkheads and not throw off the sheer line too much. Thanks, definitely! There's clearly quite a bit of making do with what they had. For example, this photo shows some of the details on the shrouds, which the plans show as just attached with turnbuckles. Source: https://www.carlosvairo.com/galeria-puerto-montt-lanchas-chilotas Instead, the first two shrouds have turnbuckles down low, followed by, in one case, a length of wire that hooks onto what looks like a thicker wire for the shroud, and in the second case, what looks like a shorter loop of wire attached to the thicker wire. The last shroud doesn't seem to have a turnbuckle, just several lengths of wire hooked and looped together. It's also notable that the running rigging appears to be white and green. Photos from earlier, like the one below from 1956, also show complex rigging arrangements. Source: https://ceph-puerto-montt.blogspot.com/2009/02/album-del-recuerdo-imagenes-de-nuestra_22.html?m=1 From what I can tell, the foremost shroud has a turnbuckle low down, a big knot or something connecting it to what looks like length of multistrand twisted wire, then a big knot connecting that to what looks like a single deadeye or something similar (a heart?) that connects to either a wire or rope shroud. The second shroud, in contrast, has what looks like a big metal hook low down, with a shroud looped on to that. Photos like these really highlight that these vessels were made and used by people with limited access to resources in remote areas. Rigging, and repairs to it, had to be made with whatever was available that could be made to work. When it comes time to rigging, I'll have to consider to what degree I want to follow this. Also worth noting, Paul, that I'm seeing internally-stropped blocks in the 1980s Vairo photos, but possibly externally stropped ones in earlier photos. If I go with internally stopped blocks, I will definitely be following your recent example in your sharpie build.
- 312 replies
- Chile
- Latin America
(and 6 more)
Thanks for the likes and kind comments! I'm continuing research on the lancha, and wanted to share an interesting site I saw several months ago, then lost the link to, and then found again today. Carlos Pedro Vairo, an Argentine maritime ethnographer, documented the lancha chilota for a 1986 article in Navegar. (Available online at: https://issuu.com/museomaritimoushuaia/docs/chiloe ) Not only is the article a useful source, but his website also includes a large number of color photos documenting the final years of the lancha. These will definitely be useful images going forward, showing a lot of details otherwise little documented. For instance, one image below shows the cramped quarters crammed in the bow (leaving most of the hull for cargo space) and the brazier that was almost always kept burning while under way to keep warm against the chill. (One wonders how many lanchas were lost to fire). Other images, like the second and third below, show details of the rigging. And still others show details of lanchas beached for loading and unloading, as in the last photo. The photos are fascinating and worth taking a look at. Site Link: https://www.carlosvairo.com/galeria-puerto-montt-lanchas-chilotas Changing gears: fairing is slow going. I think I have the sides basically ready, so I'm going to set that aside for the moment while I focus on the top. I'm planning on adding a subdeck in 1/32‐inch thick basswood before planking the sides, so it's important to get the top right before I proceed. Fairing the top has been quite tricky. Part of the challenge is that the top of the bulkheads isn't quite lined up. To check the sheer line, I placed a strip of chart tape around the corners of the bulkheads, as seen below: Doing so reveals some discrepencies--some are too high, and others are too low, like the third bulkhead in the photo below: A batten down the centerline also shows some bulkheads are a little off. So, I've been sanding a lot along the top and building up low spots. Part of the challenge is that the plans provide for quite a bit of deck camber. I followed the plans for cutting out the bulkheads, but have now realized that I think the camber is excessive. Looking at the photos by Carlos Vairo from deck level, for instance, the camber is apparent but not as much as on the bulkheads. I can reduce the camber a little with judicious sanding, but going too far would force me to also trim the stem shorter and would throw off the overall shape of the hull. Building up the outer top edges of the bulkheads to reduce the camber in that way would in turn throw off the sheer line. In any case, I don't think it's the end of the world if the camber is a little excessive, but this is a good warning of the dangers of blindly following plans.
- 312 replies
- Chile
- Latin America
(and 6 more)
Very nice job on a tricky repair! You mention being unhappy with it, but I think it looks much better and is work to be proud of.
- 84 replies
- half hull planking project
- NRG
Glad to see you picking this build up again! Good idea to use filler on the hull interior, I thought the planks were too uneven on the interior of my peapod build.
- 44 replies
- maine peapod
- peapod
(and 4 more)
A bit more on the build, plus more context on the history of the lancha chilota. I'm making progress on the hull fairing. One lesson that I learned from the Half Hull model was the importance of fairing well, so I've been taking my time with it, fairing a bit here and there and checking regularly with a batten. I've shimmed the second and sixth bulkhead, which seems to have mostly fixed the alignment issues I was having, and think I'm nearly there. A major challenge has been the lower portion of the bow, where the planking needed to take a sharp turn around the foremost bulkhead while also twisting sharply. I ended up sanding the bulkhead down beyond what the plans call for, because I couldn't find any other way to get a smooth curve there. A batten still doesn't quite form a smooth curve there, but a piece of curved, spiled wood (a bow plank I ended up discarding from the Half Hull) does seem to fit pretty well. Given the broad hull form, I think this model will be a bit tricky to plank well. With the hull nearly faired, I finally added the transom. I didn't have any way to really square this up, so I basically eyeballed it while holding it in place. After it mostly dried, I checked the distance between the transom and the bulkhead ahead of it on each side. The port side was about 1/3mm closer than the starboard, so I propped it to the correct shape with the extra support beam I added. Once this is dry, I can finish the hull fairing and add the stempost. Not a particularly exciting build log entry so far, I have to admit, which brings me to... The Lancha Chilota's Development: Design Characteristics In post #10, I wrote a bit about how the Lancha Chilota developed because of a combination of factors in the late nineteenth century: the growing availability of milled lumber and iron/steel tools and furnishings, the growing demand for trade, and some degree of foreign influence. All that's well and good, but it leaves out the question of how the lancha chilota itself changed over time and space. To start to answer this question, José A. Garnham's website says, on the basis on information from locals, that the lancha did change over time, if only subtly, in hull form and rig. These differences were subtle enough that some informants stated that there was no variation, but I feel that photos do demonstrate some changes. (Source: https://lanchaschilotas.com/diferencias-entre-la-lancha-chilota-antigua-y-la-calbucana/ ) Early lanchas, according to Garnham's informants, were rigged with a relatively short gaff and long boom well overhanging the stern. Their bowsprits were angled upward following the curve of the sheer, and their prows were relatively angled projecting forward. Over time, though, he writes, lanchas changed over to a new design called the Calbucana, as it first developed in the port of Calbuco. The lancha calbucana used a longer gaff that was more sharply angled upward and a shorter boom. The bowsprit was more horizontal, and the prow was more vertical. These changes made the calbucana a more weatherly craft than earlier lanchas. The higher-aspect-ratio gaff sail was more efficient to windward, while the deeper bow and lower bowsprit helped the vessel point upwind. Based on photos, the earlier type was practically superseded by the calbucana--although I have to note that I personally can only distinguish the difference in mainsail shape and don't really see the difference in the prow or bowsprit in the photos. Below: Early-style lanchas with their sails hung to dry at Angelmó, Puerto Montt, in the 1920s. The short gaff and long boom are noticeable. The same source link also includes other photos of 1920s lanchas that show similar rigs. Source: http://ceph-puerto-montt.blogspot.com/2009/02/album-del-recuerdo-imagenes-de-nuestra_22.html Below: A lancha calbucana in 1964. The changes in the mainsail's shape are apparent, if the purported differences in the prow and bowsprit are less so. Source: https://www.memoriasdelsigloxx.cl/601/w3-article-124898.html All of which is to say, the lancha chilota developed over time into a more weatherly, efficient vessel. As with most working vessels, describing them as "traditional" can paper over a rich history of changes over time. Beyond that, lanchas were highly variable in a number of respects. While some had nearly vertical sides, others had more dish-like hull forms. The depth/prominence of the keel also varied, as did the degree of sheer, the sharpness of the bow, and the breadth of the transom. Some degree of variation in form can be seen in the photos below. It's unclear to me whether these differences in hull form reflected regional differences, differences between builders' techniques, different design purposes, or a combination of these factors. Source: https://www.memoriasdelsigloxx.cl/601/w3-article-86076.html Source: https://www.memoriasdelsigloxx.cl/601/w3-article-86073.html Moreover, while nearly all lanchas had flat transom sterns, at least some had overhanging and/or rounded sterns. In this respect, these vessels resembled the larger two-masted schooners (also usually referred to as lanchas) that operated in the region and which I'll be writing a bit about in a future post. Below: a large single-masted lancha in 1950 with a notably rounded stern, quite distinct from typical lanchas. Source: http://ceph-puerto-montt.blogspot.com/2009/02/album-del-recuerdo-imagenes-de-nuestra_22.html Related to design, I've been trying to work out the location for the wale, and have concluded that there were a wide range of possibilities. Some vessels seem to have had a wale or rubbing strip at about the level of the deck, just under the scuppers at the bottom of the bulwark, like the vessel on the right in the photo below, or a bit lower (as given in the plans). Others, like the lancha on the left in the photo below, don't seem to have had visually distinct wales at all. Source: https://www.bibliotecanacionaldigital.gob.cl/bnd/629/w3-article-613545.html Still others, like this vessel here, seem to have had a thick wale at deck level with a bulwark of equal thickness above, and a thin wale (or a rubbing strip?) below. Source: https://www.memoriasdelsigloxx.cl/601/w3-article-86081.html So, I think I have a lot of flexibility in plotting out the wales. More broadly, all of these variations in hull design, and the fact that there's very little we know about the "why" behind them, suggests why local history is important in part to preserve local traditions of knowledge that are threatened by the homogenizing effects of development. At the same time, the lancha chilota itself owes its existence to a similar process by which it replaced the dalca.
- 312 replies
- Chile
- Latin America
(and 6 more)
Good luck on the repair! If nothing else, it will be good practice. I know I've seen a few build logs where people had to replace planks after accidentally wearing through them on the final sanding, so I know it can be done, but it certainly looks challenging.
- 84 replies
- NRG
Very nice job painting the hull. The minimalist approach really highlights the fine lines, and the green is a nice touch.
- 47 replies
- Erycina
- Vanguard Models
Nice job! I definitely had to deepen the bow rabbet on mine. Getting the curves right at the bow and stern is a challenge, but now you'll have a better idea of what to expect for future builds.
- 84 replies
- NRG
Welcome! I agree that it would be helpful to hear more about your specific interests. Basswood is very commonly used in kits and in scratchbuilding, as it's cheap, readily available, and easy to work with. There are a lot of techniques for smooth finishes, and you can find plenty of discussions about that topic if you search for them. Build logs are also useful resources. Finally, you mention waterproofing, but you don't have to worry about that unless you're making a remote control model. Best of luck!
I've been doing some fairing, something that takes a good bit of patient work and doesn't really produce interesting photos in the middle of the process (e.g., "here bulkhead 3 has been sanded by about 1/128 of an inch, I will check fairness with a batten a dozen times and continue sanding"). So far it's coming along well and is a good bit faster than the multiple months I spent fairing the Half-Hull, although it does look like bulkhead 6 and the lower half of bulkhead 2 will need to be slightly shimmed. While working on that, I turned my attention to something I should have figured out a while ago. As I mentioned above, the plan provides for a combined backbone/keel/stem piece, which I split into separate parts. The plans didn't show a visible sternpost, instead showing the planks simply running to the trailing edge of the hull (with the sternpost presumably inside covered on the sides by the planking. This seemed weird to me, so I looked at photos of the Quenita (the vessel the plans are based on). It was hard to tell what was going on at the stern, as the area was covered in a thick layer of tar or caulk or something. Source: https://lanchaschilotas.com/dscn7156/ In any case, I thought it looked like the planks might indeed run to the edge of the stern. I figured it might be an oddity of the type, so I decided against making a visible stempost and figured I would come back to the question later. As I'm getting closer to planking, I took a deeper look at other examples. Although there aren't many close-ups of this area, I found a few that do indeed show a visible sternpost. The Voladora, a yacht lancha that was built beginning in 2008, does show a sternpost from the sides. It's rabbeted at an angle, such that it's relatively wide where it joins the keel, but tapers (on the exterior) to where it meets the transom. Source: https://lavoladorachiloe.blogspot.com/2008_06_27_archive.html?m=0 The model lancha held by the Museo Regional de Ancud, which I linked to in an earlier post, shows something similar. Checking elsewhere on this site, I noticed that this is basically how the Syren Medway Longboat handles its sternpost, as well. So, before I add the transom (which I've unglued the plank from in the meantime), I'll need to add a sternpost to the aft end of the backbone. I don't think it should be too tricky to add.
- 312 replies
- Chile
- Latin America
(and 6 more)
I think your friend will be very happy!
- 55 replies
- Le Martegaou
- billing boats
Very nice! What are you using for the cargo?
- 55 replies
- Le Martegaou
- billing boats
Thanks! I think I will plank it after adding it, so I'll need to wait a bit until I have access to my exacto knife again so I can pry the plank off after soaking the joint in alcohol. I finished the framework except for the transom, adding support pieces to better support it at the stern. I can't use the binder clips or the square to check evenness on the transom, so I'm planning on fairing the rest of the hull first and using battens to line it up, and adding more support beams once I have it squared.
- 312 replies
- Chile
- Latin America
(and 6 more)
More work on the bulkheads. By now, I've added almost all of them to the hull. I've also been adding support pieces, as can be seen below. These are crucial because I didn't do a great job of cutting out the slots, leading to a good bit of play which was actually useful in allowing me to properly align each bulkhead but which would have led to very weak joints. Adding 1/8-inch thick supports along the edges of the joints has significantly strengthened the framework. I've used a combination of methods to ensure proper alignment. Large binder clips help keep the bulkheads square. To check symmetry, I've been drawing a horizontal line across the widest point of the bulkhead, then marking the midpoint and using a small square to mark a perpendicular line (which intersects with the slot). I then line up the internal and external corner of the square along this vertical line in order to draw two lines coming off at a 45-degree angle. This provides me with more points to check symmetry. (As can be seen below, I also carved out a portion to mark the location of the fore hatch. One difficulty is that I wasn't able to bring my exacto knife, so I've been using a tiny cutter lent by family.) The horizontal lines across all the bulkheads helps with visually lining everything up once you dry-fit the remaining bulkheads, but eyeballing it can only get close to proper alignment. So, when test-fitting, I use the square as below (except held by hand) to check the distance to the widest point of the bulkhead and the height. I can then check to make sure it's the same on both sides, which can sometimes require sanding the slot a bit wider. Once it fits evenly, I glue it in place, check again for evenness with the square, and then use a binder clip to hold it square. I also use a string glued to the tip of the prow to make sure that the outer tips of the bulkhead are equidistant from the prow, as Wefalck suggested. (The string is also helpful for making sure that the center lines all align.) Once the bulkhead is firmly in place and the glue has dried, I glue supports to the aft end of the joint and along the fore side of the next bulkhead slot, dry-fitting the latter and binder-clipping it square to make sure the supports are properly fitted. With all that, it's been somewhat slow progress, but progress nonetheless. I can definitely see how a building jig would be necessary for a more complex POF build, but so far it seems like I've figured out a way to work around my self-created issues with this build. I think I may have to add a shim or two to properly fair the hull, but we'll see once I start sanding, and it shouldn't be anything too challenging. In any case, I've been adding support pieces closer to the edge of the bulkheads to make sure that everything stays in place while fairing. The framework is now pretty sturdy. Finally, a question. Is it generally recommended to plank the transom before or after it's attached? I started planking it, thinking that it would be easier to do off the hull and that I could then fair it in place, but I'm concerned that if I need to shim it to get the hull fair, I'll need to pull off all the planking and redo it.
- 312 replies
- Chile
- Latin America
(and 6 more)
Rigging Diameter, Early 1900s Workboat
JacquesCousteau replied to JacquesCousteau's topic in Masting, rigging and sails
Thank you, this is extremely helpful! I hadn't realized the Glad Tidings was a good point of comparison, but it definitely is. The parts lists online are useful to a point, but the plans are much more helpful. -
Thank you to @wefalck, @Thukydides, and @Paul Le Wol for your suggestions. Javier Barón's work is fantastic, and I'm considering whether I want to use a similar method to his to make one of the small boats that often were towed by lanchas. Although I considered filling in the spaces between bulkheads, I decided against it, both because the bulkheads are fairly closely spaced and because I'm planning on making an open POF build next and see this model as good practice for planking that hull. Before adding the bulkheads, I added some blocks at the bow to provide a stronger basis for gluing. I also marked the bearding line and gave the backbone a preliminary sanding so the planking will run smoothly. This process will be finished during fairing. As for squaring up the bulkheads, I unfortunately don't have any legos at the moment. But I do have binder clips that provide a square edge. I started at the bow, first slightly shimming the bulkhead to sit about 1/64‐inch higher so it properly lined up with the rabbet. After getting it at a right angle to the backbone and propping the assembly upright on a flat surface, I adjusted the bulkhead left and right to get it properly centered. I used a small square to measure the distance from the edge of the bulkhead to the backbone, the height of the left and right corners, and the distance from the tip of the prow to each bulkhead corner (following Wefalck's advice, I will use string to do this in the future, but the distance was short enough at the moment to use the square). Everything measured up even. I also added some 1/8-inch square supports on the fore side to strengthen the joint so that it won't come loose when I fair the hull later, using another binder clip to clamp them while the glue dries. Once this side is ready, I'll add similar supports to the aft side, and will move on to the next bulkhead.
- 312 replies
- Chile
- Latin America
(and 6 more)
I recently began work on a 1:32 model of a Lancha Chilota, a kind of small coasting sloop used in Chile from roughly 1900-1970. (Link in signature). I'm trying to figure out what diameters of rope I should use for the rigging. After doing some searching and not quite finding what I was looking for--most rigging references and posts on this topic are about warships from 1650-1850--I thought that I would post directly here. Sorry if this question has been answered elsewhere! From what I can tell, much of the standing rigging was wire, while the running rigging was rope. A couple photos that show what I'm talking about: Source: https://www.memoriasdelsigloxx.cl/601/w3-article-86081.html Source: https://www.bibliotecanacionaldigital.gob.cl/visor/BND:320806 I recognize that it's very unlikely that someone will know exactly what diameters of rope and wire were actually used, and my sense is that these vessels would have likely used whatever was at hand and effective for the job rather than following fully standardized rules. For my build, my goal is more to choose material that will look in-scale than to figure out how to exactly replicate the rigging. I've had a hard time figuring out what diameter of material would be appropriate for a vessel of this size (around 25-30 feet long) in this period, though. I found some information in Willits D. Ansel's The Whaleboat showing that around 1910 , whaleboats generally used 9/16-inch line for the shrouds and 5/8-inch line for the halyards (I'm assuming this is diameter, as the rope would be quite thin if it's circumference). In 1:32 scale, this would correspond to roughly .45mm/.017in and .5mm/.019in rope (using sizes available commercially from Ropes of Scale--at this time, I am not able to make my own rope). However, while a whaleboat is of comparable length, a Lancha is a much bulkier vessel seagoing vessel with a lot more sail area, so I assume the equivalent lines would need to be thicker. Moreover, the wire standing rigging would have presumably been thinner than rope rigging of corresponding strength. Changing gears, I saw that the parts list for the Model Shipways Willie Bennett skipjack kit, which is also in 1:32 scale and models a workboat that also used wire standing rigging, includes .012in and .02in wire, as well as .021in and .028in rope, all of which are sizes that I could approximate with available sizes of black and tan rope from Ropes of Scale (respectively, .35mm and .5mm black rope, and .6mm and .7mm tan rope). However, the Willie Bennett is a larger vessel, 42.5ft long vs the 26ft lancha I'm modeling, so presumably the lancha could use rather thinner lines. All that considered, at the moment I'm thinking of representing the wire standing rigging with .25mm/.009in and .45mm/.017in black rope, and the rope running rigging mostly with .5mm/.019in and .6mm/.023in tan rope. Does anyone have a sense of whether that would look out of scale, or have suggestions for more accurate measurements? Thanks in advance!
While traveling, I brought along the second test sail to try out. Unlike the first one, it's made of tissue paper instead of a coffee filter, and has reinforcement strips glued around the edge and panel lines drawn on (I didn't bother getting them fully even, as this is just a test). After wetting it and furling it (flattening one half to mimic how it will look resting on top of the rancho), I have to say that I think I like the look of the coffee filter better. In too many places, this sail took on sharp creases that don't look so much like fabric. Maybe I didn't soak it enough, but I did run it under the sink which seems like it should have been enough. The reinforcement strips are also nearly invisible and started peeling off in a couple places. So, for the final version, I think I will 1) make it out of a big coffee filter, and 2) not bother with panel lines or reinforcement strips (although it will get bolt ropes). This is taking some time, but I'm looking forward to having a result I like.
- 286 replies
Also, if anyone has any suggestions about how to best ensure that bulkheads are even and square on the backbone, I'd love to hear them.
- 312 replies
- Chile
- Latin America
(and 6 more)
A bit more prep work on the lancha's skeleton. As mentioned above, the backbone was a bit oversized, so I trimmed off the excess on the front and bottom. I also extended the space for the transom. Later, I marked off the space for the rabbet (not pictured). There were a few places where I had cut too close to the line and the bulkheads needed to be built out a bit. In a couple places where it was more of a gouge, I added a bit of wood filler. For other spots, I built up multiple layers using thin scrap strips from planing. After the photo below, this was then sanded smooth. I was worried about imprecisions in cutting the slots, so I started thinking up ways to check before gluing how things are lining up. I hit upon the idea of loosely placing a 1/8x1/32-inch batten along the sheer line, clamped in only a few locations, as a way of doing a preliminary check for fairness. In general, the results were reassuring in that nothing seems to be disastrously off. A few bulkheads will need to be adjusted, especially number 6, which is notably short on one side creating a dip, and number 8, which is sitting a little high, and the bulkheads haven't been properly squared yet to the backbone. But other than those, the battens produced a more or less fair line. I was even able to use them to confirm that the transom, which I was worried I had cut too low, sits at the proper height. Next up, I'll be adjusting the fit (especially for bulkheads 6 and 8). I'm also going to add a 1/8‐inch-square strip along the bow so that the planking there can smoothly run into the rabbet. This will also substantially strengthen the projecting bow of the backbone, which is extremely flimsy due to crossgrain.
- 312 replies
- Chile
- Latin America
(and 6 more)
Welcome, and very nice job on the hull!
