Everything posted by brunnels
Looking great, I am working on the shrouds for my foremast, a little bit behind you. Do you think it would be wise to start putting on the cleats before I tighten down the shrouds? I saw the cleats in the instructions and wondered if putting those on earlier would interfere with anything else.
- 422 replies
- Vanguard Models
- Sphinx
I recently saw online that a new Constitution kit is coming from Angora Models. It is a subscription kit which I am assuming is being contracted out, from the pictures there are a lot of similarities to what I see in Occre kits. I can't speak for the accuracy of the kit, but the kit seems very overpriced for the quality shown in the pictures and the overall price. https://www.agoramodels.com/us/constitution/
Howdy all. I have just about all the masts turned down on my proxxon lathe. My next step was building them up, I decided to start on the lower masts to first. The main masts need to be flattened out on 3 of the sides, and then the top portion above the tops are square shaped. To do this I created a very simple jig out of some spare square dowel I had. I can adjust the height of the dowel needing to be cut by inserting different thickness timbers below the dowel. This quick jig worked better than I was expecting, and I was happy with how the lower masts were able to be flattened with a simple file. Next was building up the masts with all the reinforcements, installing the tops, iron bands, and wooldings. I have never worked with card before on a model, but it was simple to work with and looked much better than I was expecting. I will probably add some assortment of card in my toolbox, I can see it being a useful material to use in the future.
Beginner - Rigging Tools
brunnels replied to nheather's topic in Modeling tools and Workshop Equipment
When I rigged my last model, 80% of the rigging work was done with some fine tweezers. I have that 5 piece rigging tool "minature fingers" set that micro mark sells and I actually found them to be very useful for belaying lines around belay pins and cleats that were in hard to reach areas. I use a set of forceps from time to time for spots where my small tweezers wouldn't fit. These are the ones I bought. https://www.amazon.com/dp/B01MXEN7OY?ref=ppx_yo2ov_dt_b_fed_asin_title Another tool I use are cuticle trimmers, they are fantastic for snipping line close to knots when you don't want to leave any excess line showing. https://www.amazon.com/dp/B07J6B3W12?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 I would also recommend something like some "helping hands" to hold lines while you tie knots off ship. Rigging is one of those tasks where you always wish you had a second set of hands to hold something. https://www.amazon.com/gp/product/B0C1ZZ9Y2V/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 I would also recommend a pack of small alligator clamps, they are very useful for clipping to a line if you need some weight to hold it in place. -
Howdy all, over the last week I have started on the masts. I recently purchased a Proxxon DB250 to turn the masts, on my last model ship I used the battery operated drill method to turn the spars down and I wasn't a fan. The last time I used a lathe was nearly 20 years ago in high school wood shop class, so it took a little bit of time to get acclimated with it again. I still have some learning to do, I have forgotten the purpose of each specific lathe tool, and need to learn what turn settings to use for each type of timber, but so far I have had success and really enjoy using the machine. I started on the bowsprit and mizzen mast assembly, I figured those would be the easiest pieces to get my bearings with.
Apologies for my break from updating my build log. October was a very long month for us, our 15 year old Australian Shepard has been slowly losing more and more mobility over the last year with the last couple months being near 100% immobile. At the start of October she took a turn for the worse and we decided it was time. She was my constant companion, nearly always at my side for the last 15 years when I got her straight out of College. Her loss has been a huge adjustment for me to get used to, so apologies for the lack of pictures of my progress for the past couple months. For October, I spent nearly the entire month working on the ships boats. I really don't look forward to building these little boats, ships boats are always a fiddley task that always takes me way longer than I expect. I was planning on buying the 3d printed Vanguard boats so I didn't have to build them, but I needed to take my mind off of some stuff and figured I would give them a try and at least practice some of my skills. They aren't the best, but I am satisfied with the result. Planking Pinnace Completed Pinnace, work started on the other two boats Finished boats. I will complete the anchors and oars once they are permanently fixed in the ship after rigging. I also completed the rope railings and hammock cranes around the forcastle and gangways. After rigging I plan to add netting to the hammock cranes on the gangways. Figurehead. I painted with Vallejo Ochre brown, and then used a Vallejo brown wash on top. Next is something I saw on @hollowneck buildlog. He added a couple small doors to the Quarterdeck stairway which I thought looked really nice, so I decided to add something similar. I made the door out of some spare 2mm pear planking that was intended for the ships boats. 3 pieces for each door ended up being the perfect width. I then added some reinforcement on the back side I then used some spare PE rail stanchions that I cut down and bent for the hinges, and a couple eyebolts for handles. How the ship currently sits. Ready to start on the masts and spars.
As someone completely ignorant on lighting in models, I am assuming you have to install these as you build the model and it isn't something you can add afterwards? Since my Quarter deck and forcastle are already closed on my Sphinx it's probably too late to add. Love the product though, will go great with my future surprise kit.
Congrats, beautiful model. One of these days I will get around to my Syren kit. Are you by any chance from Kiowa, OK?
- 9 replies
- Syren
- Model Shipways
Looking great ECK, you must have an amazing fleet with all the fantastic models you have done.
- 37 replies
I will definitively be one of the first on the buy list, frigates are my favorite vessels and like many the Surprise has a special place, the Master and Commander movie is what really kicked off my love for the age of sail, and one of my favorite memories of my youth is seeing the movie in theaters with my dad and brother when I was in high school. I've been reading the books and I get a smile every time the Surprise appears.
I agree, the figures look great. I will be happy if I could do half as good on the few figures I have.
FC/QD Rail Stanchions and Timberheads: Removed the char off of the timberheads and rail stanchions and glued them in place. The slots in the gunwale cap pieces make this a very simple task. Next came a few coats of black paint and then varnished. QD Breast Rail: Next up is the QD Breast rail, the hardest part about this process was rounding the stanchions. I was also pleasantly surprised how little adjustment I needed to do to the stanchions to get all the horizontal railing pieces to line up and slide in their places. Overview shot of how the ship sits. Getting close to masts and rigging, just a few more tasks on the main ship, and then the three small boats.
An office with 11 amazing models is a life goal I didn't know I needed until now 😃.
- 131 replies
- Medway Longboat
- Syren Ship Model Company
best SECOND model ship kit recommendations
brunnels replied to palmerit's topic in Wood ship model kits
Personally I think anything other than Vanguard would be a step down as far as entry/mid level kits go. Also I think a lot of the time harder rated kits aren't necessarily harder skill wise than what you will have experienced with the Sherbourne, they just require more time to complete. I think a good step up would be some of the two masted vessels from Vanguard like the Adder, Speedy/Flirt, or even the Dutchess of Kingston. -
Bow/Head Main Rail: Finished up the head railing with the large main rail patterns. These are 3 pieces glued together, then painted blue infill and WOP as a finish. Next I added all the eyelets and deck cleats to the Quarter deck and forecastle. I have also started on the Quarterdeck rail by gluing the bottom piece in place.
Ships Wheel, and Binnacle: Binnacle, Ivory white top, with WOP applied on the wood. I plan to add the securing ropes to the outside as well. Ships wheel. I wasn't sure I would like the wheel being made out of PE, but once built up it looks really good and to scale and not nearly as flat as I was expecting it to look. The hardest part was trying to figure out how to make the two ropes from below deck look like one rope wrapped around the drum. My solution was to just cut them both as cleanly as I could and glue them end to end at the bottom of the drum, It ended up looking better than I expected, and the two ropes split can only really be seen if you look pretty closely under the drum.
