Everything posted by Jim Lad
Matt, rather than a hobby knife, I use a scalpel. The blades seem to remain sharp longer and they're comfortable in the hand (at least for me). The only caution would be not to get your blades from a surgical supply outlet - they're too expensive. You'll do better at a veterinary supplier of even a chiropody supplier. Some hobby shops also carry scalpel blades. John
Another Rigging Clarification Needed - Lifts
Jim Lad replied to BANYAN's topic in Masting, rigging and sails
Sorry Patrick - missed this one. Topsail yard lifts were usually standing - i.e. shackled to the yardarm band and the mast band as they were only required to steady the yard horizontal. Lower topsail yards didn't have lifts. John -
The Historic Naval Ships Association gives the standard width of sail canvas as 20 inches, but I'm pretty sure the standard width of canvas in England was 2 feet. John
Ernestina Morrissey by Jond - FINISHED - 1:48
Jim Lad replied to Jond's topic in - Build logs for subjects built 1851 - 1900
She really is looking first class, Jon. John -
Hello, and a warm welcome to the forum from 'Down Under'. John
Introducing Colin. Currently living in South East England.
Jim Lad replied to colpatben's topic in New member Introductions
Hello Colin, and a warm welcome to MSW from 'Down Under'. John -
Hello from Northern California Foothills
Jim Lad replied to bobandlucy's topic in New member Introductions
Hello Bob, and another warm welcome to the forum from 'Down Under'. John -
Pat, even large and heavy as they were, I wouldn't think it would take much power to cant a lower yard. After all they were pivoted at the centre and should have moved pretty easily. It also wouldn't have been much work to tail a tackle onto the running part on deck if it was really needed. John -
Hello Paul, and a warm welcome to the forum from 'Down Under'. John
Macro photography on the cheap.
Jim Lad replied to ausf's topic in Modeling tools and Workshop Equipment
Tubes work very well for macro photography. Their main disadvantage is that they have a very narrow fixed focus range which makes them a bit tricky to use on moving subjects such as insects. The depth of field can be vastly improved by 'focus stacking' - taking a series of images at different focus depths and then combining the images in a photo processing programme. John -
The classic method was to eye splice the ratline at each end and then seize it to the shroud using light line. A clove hitch is not a secure knot so would never be used in practice at the end of the ratline. Except at very large scales, eye splicing each ratline at each end becomes rather impractical. An alternative recommended by Harold Underhill (and one which works well in practice) is to sew the end of the ratline through the shroud. John
Hello Henry, and a warm welcome to MSW from 'Down Under'. John
Hello Jeff, and a warm welcome to the forum from 'Down Under'. John
Very nicely executed, Dan; congratulations on a job well done. John
- 33 replies
- James B Colgate
- whaleback
Welcome back, Joe. Looks like you're making a good job of your sloop. John
Good job on the deck, mate! John
- 62 replies
- muscongus bay lobster smack
- Finished
Yes, the reef points are on both sides of the sail. When the sail is reefed it is gathered up and tied off with the reef points, thus making a shorter sail. John
