Everything posted by wefalck
We had this discussion somewhere else on the forum: either nitrocellulose varnish (known under the name of zapon-varnish also, which is used to protect polished silver and brass from tarnishing) or a shellac solution. It does not appreciably darken the lines, particularly when used diluted.
One would indeed need to know what (type of) vessel we are talking about. In European commercial vessels for much of the 19th century the light upper yards were often set flying, with no parrel. Sometimes also a kind of vertical stay parallel to the top-mast was used on which the yard ran with a truss into which an eyes was spliced. Weight of gear was important in trading vessels with small crews.
I am a bit pressed for time at the moment and cannot extract relevant works from my literature list, but you are welcome to browse it here: https://www.maritima-et-mechanika.org/maritime/maritimebibliography.pdf. Beware it is long document ...
As I always say: nothing looks more like metal ... than metal However, not everyone has access to certain tools and techniques. Tampon galvanising kits for copper, silver and rhodium are avaialble from jewellers supply houses. They also supply the materials for polishing and buffing, which is not really difficult.
If you could show what the windscreen looks like and and what cross-section the frame should have, one could give some more specific input. I gather you will have two challenges here: a) to shape the frame, and b) to get the shiny chrome finish it presumably had. I assume that it would have been framed with some sort of U-shaped profiles. Depending on the scale of the model, you may be able to buy something suitable in brass or styrene, otherwise you would have to fabricate it yourself. This profile would need to be coerced around the windscreen, or perhaps some sheet metal former to avoid scratching the windscreen. It would need to made in section to allow insertion of the screen material. Brass you could then take to a company that does chrome-plating, or you could spray-paint it using some high-quality metallic paint, such as Alclad, as you would do for styrene. A completely different route would be to build the frame around the existing windscreen with narrow strips of styrene. After masking off, this can be painted again with Alclad paints or something similar.
Mill Speed to Avoid Chipping
wefalck replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
Chipping and ripping often is the result of dull cutting edges, rather than the wrong speed or feed rate. -
I tend to soak the lines in dilute varnish, once everything is in place and weighed down. The weights are removed once the varnish has dried. This keeps everything where it should be.
This kit seems to be based on a French fishing boat from Brest in Brittany. If you can identify on the Internet on what type it is actually based, you may find images of the prototype or someone on a French forum who rigs the model prototype-fashion. There are various books on French boats, but these are usually in French They may also not so easy to obtain, depending on your location ... identifying the prototype would be my first step to get to grips with this.
I would take a board and draw onto it the shape of the hull in the correct dimensions, i.e. to the inside of the rail. Put lots of nails to the inside of that curve and gently coerce the hot, wet plank unto this shape, while holding it down to the board, so that it does not twist. Work from one end to the other and fix the shaped part with more nails and the occasional little wood strip nailed down to hold it flat. You may not be able to do this in one session, because the wood will dry and cool down. Leave it in the jig to completely dry and then steam only the unbent part before putting it back into the jig to continue.
Rudolf, to be honest, I don't know. I haven't had a need to try the laser on wood (yet). It will be a question of thickness and density of the material. Due to the rather low power, the laser point would have to stay longer on a spot to get through, which leads to more charred edges and a perceptible kerf. This is already noticeable on the 0.15 mm thick cardboard I am currently working with.
Very 'high tech' ... the difficulty would be to get the pull equal on all three strands. "Don't say I have a lot of copper... ha ha " - I noted that in Chinese one doesn't seem to distinguish between brass and copper (I have seen this often also in ebay offers ...). Google translator tells me: brass = 黄铜 (Huáng tóng) copper = 铜 (tóng) Is this true ?
Attaching real copper plates with CA can cause bonding issues, as the copper ions can interfer with the cross-linking process while the resin is curing. A contact cement is probably the more secure option. In theory, the plates should overlap a tiny bit, so that the issue with gaps should not arise.
Is running rigging smaller in diameter than standing?
wefalck replied to Matt H's topic in Masting, rigging and sails
The ships in question are only known through archaelogical finds and some graphical (vase paintings, stone reliefs, etc.) representations. This means that soft vegetal matter, such as ropes and sails normally have not survived. We have some fragments of Viking-age ropes, but their use and location typically is not known. This means that all our knowledge about the rigging of such ships is interference from moden practices and modern knowledge about material properties. The best approach to estimate what rope sizes would be needed for the models would be to study the replicas built of them. These replicas where built as what the science calls 'experimental archaeology', which means that the scientists used the material evidence to reconstruct these ships plus guess work for the missing parts and then tried them out in practice in order to understand, whether the parts, including the rigging, perform as one would expect. There are usually scientific reports on these replicas available, many of them online. I am not very well informed on the Greek ships, but the first stop I would go to for information on Viking-age ships is the Roskilde Viking Ship Museum (https://www.vikingeskibsmuseet.dk/). Their Web-site should lead you to more information. You then can also search the Web for the names given to the discovered wrecks and their replicas, which should turn up a wealth of information. As a rule of thumb, you would also expect the ancient ropes to be thicker than their modern counterpart would be due to potentially lower quality of the material (not always !) and a larger safety margin to account for potentially larger variability in quality. Another aspect to consider is that for all of those three ships the rigging is a much more temporary arrangement, as it would be for most modern sailing ships. The Greek ships were mainly rowed actucally. The rigging arrangement allowed a quick and easy striking of the mast, with stays, shrouds and backstays set up in a 'running' fashion. Hence distinguishing runnning and standing rigging is not so straightforward. -
Pat was referring to this kind of chain: From: http://www.cqhisea.com/m/productshow.php?cid=112&id=1123 It is common among larger ships and from the early(?) decades of the 19th on. Due to the difficulty in reproducing it, it is often neglected by modellers. There are now some apparently very good 3D-printed products on the market. However, we were discussing, whether studded chain would be really appropriate for your type of ship and period. In any case, the thickness of the material of your chain seems to be rather thin.
I actually wondered myself a while ago, since when studded links came into use and down to what size of chain. I think one of the picture of the GREAT EASTERN from the 1850s shows huge studded links for her anchor chain, but small chains even today are not studded. I would agree, however, that the material for the links on the chain above is a bit on the thin end.
HMCSS Victoria 1855 by BANYAN - 1:72
wefalck replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Bronze is quite corrosion resistant (depending on its actual composition). There are always trade-offs, but bronze nuts and steel/iron spindles is a common combination in engineering. Here, because of the cast-iron gun, the spindle had to be bronze. Everything would be greased and the crew kept busy maintining everything corrosion-free.- 1,021 replies
- gun dispatch vessel
- victoria
Thanks, gentlemen, much appreciated ! **************************************** Folding tool As will be seen in the next post, quite a number of delicate laser-cut parts will need to be folded. Therefore, I thought a folding tool might come handy. A number of commercial gadgets are available, but considering that they essentially consist of a couple of milled-to shape pieces of aluminium and a thumb-screw, I find them rather overpriced at €20 to €70, depending on what you buy where. Also, if I have the right materials and tools, I prefer to make such things myself. I did not have a suitable piece of flat aluminium in stock, so I decided to make it from some 4 mm thick Plexiglas off-cut. This has the added value that you can better see, where you place the folding edge. Plexiglas is more vulnerable than aluminium, but I can always make a replacement, should the need arise. A set of fingers ranging from 1 mm to 6 mm width were separated by notches made with a 4 mm cutter. The front was bevelled for better access to small parts. The opposite side was left straight for longer parts. For the moment, the front edges where milled at 90° degrees, but I can imagine that a slight overbending would be better. I am considering to mill on a 5° or 10° relief angle, but will first test the piece in practice. A more acute angle will make the edges more vulnerable to chipping. The underside is somewhat recessed over most of the width, so that tool really clamps with the front edge, where it is needed, and does not wobble. As I also did not have material for a base in stock, I decided to use the base of the sanding tool that I made a while ago. It has the added value that no extra gadget is floating around the workshop. The folding ruler was drilled and two corresponding holes in the base were drilled and tapped for M3 thumb-screws.
