Everything posted by wefalck
HMCSS Victoria 1855 by BANYAN - 1:72
wefalck replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Indeed, close-ups can be very damaging to our pride 😯 Nice job, Pat, on this 3D-printed EOT. I think we will continue to battle with the physical limitations of the digital 'machining' technologies, whether they are additive (3D printing) or subtractive (CNC milling, laser cutting). Small step-sizes and positioning precision are going to be expensive. So, for the time being, we will have to live with these 'steps' on cut or printed items. I found that files don't work very well on plastics and abrasive papers often don't have the 'bite' needed, but discovered so-called 'separation' strips in dental supplies. They are used to open up interdental spaces in vivo or between false teeth. There are two variants: either the diamond-powder is fused onto plastic strips or galvanically bound to very thin stainless steel strips. Obviously the latter are stiffer and in short lengths can be used like a micro-diamond file. They come in width from 2 mm to 6 mm and different grades. I bought them from this manufacturer: https://www.horico.de/en/praxis/separierstreifen/2-uncategorised/91-alle-streifen.html. There may be a similar product available Down-Under. I cut short lengths and hold them in a pin-vise. With this I can file plastic surfaces quite well. As you probably remember, I made a couple of EOTs of the same kind some months ago. While I discarded these ideas for the small size I needed, I had been contemplating making the brass part of the dial as an etched part. The glass pane underneath could have been made by printing the lettering on an overhead projection foil (with the limitations of the printer resolution), cut the disc out and then paint it white from the back. If one still has a camera for films, one could have also made a computer drawing and photographed this so that the image on the film has exactly the right size - the film has such a high resolution, that the lettering would have been almost readable - at least with a loupe. However, I think we can file this under lost technologies. Would have been good also for really sharp compass cards ... I really love those Victorian warships that look so 'ship-shape, Bristol-fashion' with mahagony fittings and brass/bronze trimmings. In spite your trials and tribulations in finding source material, you are quite lucky in comparison to what is available for our German navies of the same period ... I always would have like to build one of those sleek 1860s gunboats, but that would involve even more guess-work.- 1,000 replies
- gun dispatch vessel
- victoria
Belated thanks, Gentlemen, again Since the effective work surface on my workbench gradually had been reduced to around 20 cm x 20 cm, a decluttering action was urgently needed. On the now freed-up workbench I made two improvements to my workshop equipment that I had been planned for a long time: Tilting model stand Decades ago, together with some antique lathe parts, I had received a beautifully made cast-iron foot, the use of which had long been a mystery to me. At some point I found out that it was a table base for a small vice, that I unfortunately don't have. In my drawers there was lounging also one of these hand vices with a grid of holes to allow to clamp irregularly shaped parts with the help of short pins. I never had a proper use for it. But both parts together made a useful stand for models during construction. Unfortunately, this stand could not be tilted. In my treasure chest with 'scrap metal' was a clamp for tilting lamps in nicely cast brass. This piece offered itself to make the model stand tiltable. It was done with some modifications to the existing parts and a lathe-turned intermediate piece. Various M10 x 1 threads (standard lamp thread) were cut on the lathe for it. Fortunately, I also had such a tap. Magnifier holder for the micro milling machine It is handy to have a magnifying glass permanently installed on the milling machine. A suitable magnifying glass had come to me a long time ago as a promotional 'gift'. In the mentioned scrap treasure chest there was also the gooseneck of an old lamp and various lamp fittings. A connectiing piece to fit the magnifying glass with it M6 thread to gooseneck was turned on the lathe. The magnifying glass can now be rotated in the gooseneck. Once we can reliably order again in China, I will get another 'angel eye', a ring equipped with LEDs, as they are sold for installation in car headlights. This makes for very nice ring light, as I had fabricated for the 'large' milling machine. Only that here the ring will be integrated into the magnifying glass, because there is not enough space around the milling spindle. Work continued on the WESPE too, but of that later.
Cutting the Rabbit
wefalck replied to acaron41120's topic in Building, Framing, Planking and plating a ships hull and deck
Before reshaping the bulkheads - check them carefully against the line plan, perhaps the slots in them or the keel piece are just to deep ? -
Anyone ever seen crosstrees formed in nitrocellulose?
wefalck replied to Sparkysparks's topic in Masting, rigging and sails
Ahh, I understand. Interesting question. There are various interesting man-made materials that have interesting properties and workabilities for model-building, but they are difficult to come by these days. We mainly use styrene, ABS and acrylic glass in model building, but builders of 'historic' ships seem to frown on them. They have become common, because they are cheap to produce. However, with a bit of searching you can find the more 'historic' materials as well. I am using bakelite paper (from around 0.2 mm to perhaps 10 mm thickness) a lot. It is brittle, but otherwise machines and sands well. Celluloid is more difficult to find. Because of its high flammability it has been replaced by other plastics. Indeed, various consumer goods, such as combs, boxes, knife and nail-file handles, fashion jewellery, buttons, frames for glasses, etc. etc., used to be made from coloured celluloid. It was also widely used to make toys, such as dolls. However, your question prompted me to search a bit on ebay, and I discovered that one can find actually a lot of celluloid, tortoise shell and other, among products for making guitars, for knife-handles, and still for jewellery-making too. One would need to verify that it is really celluloid and not some other plastic to make look-alike. Thanks to your question, I may discovered some interesting sources of material I tend to use a lot man-made materials for my miniature models, as the grain in wood tends to be too promient, even when using boxwood, or the anisotropy of wood is inconvenient. -
... well, for the moment we are under tight curfew until 11 May, but we expect that it will last longer, perhaps with some restrictions losened, as already in Germany. We have mentally braced ourselves that it will last into the summer. Perhaps this is just wishfull thinking, hoping that we can go on some sort of vacation by then. The fear is that we will see some rebound effect, once the curfew is loosened. We don't even go to the bakery, because the French bread cannot be put into quarantaine for the week before we touch anything brought into the house. Luckily, German-type bread is available from 'industrial' bakeries that lasts for several weeks - that is, if it not eaten before
Someone showed them in a building log here a couple or so of years ago. Got immediately bag of 10 for something like 1€ directly from China and they are indeed very useful for various holding tasks.
What do you mean by 'forming in nitrocellulose' ? Nitrocellulose is chemically alterated cellulose and its initial state is a kind of viscous liquid. You can use this for different purposes: - you can push it through thin nozzles and spin the resulting fibres into a thread - the first man-made thread - you can cast into films - celluloid, as used for cinematographic material or packaging, or artificial ivory (billard balls used to made from it) - you can dissolve it in solvents to make paints, varnishes, wood fillers and the likes So, perhaps you can explain a bit better, what you mean ? -
I have seen people turning out their first model as scatch-build project perfectly and some people will only build perhaps a couple of model in their life's spare time. The key point is patience and being self-critical. It is not easy to start a piece from 'scratch' again (I am sometimes guilty of not doing it ...), if it doesn't turn out right. The only reason to finish a model is our own impatience - otherwise you can take all your time to get it right ... In my opinion there are no 'beginner' models, there are only models for the more or less patient.
She really begins to look ship-shape ! Nice details ! At this time even warships looked elegant and not only utilitarian. As John, I noticed that these swan-neck ventilators look rather big. Is this per plan ? I also noticed this nice, polished mahagony 'bench' in the stern, but most ships I have seen tend to a grating there ... A third nicely executed detail I noticed are those brass tyres on the cannon trucks. We recently had a discussion in another forum, where people argued that metal tyres would mar the deck. I think I have seen metal tyres in French sources from the 1860s/1870s, but would have to check.- 1,000 replies
- victoria
Crisp job, as always ! It is a good idea to glue the brass frames onto the wooden frames first and then drill and insert the bars. I remember me struggling with alining the brass frames and bars before installing them on the wood ... It is often so important to do things in the 'right' sequence, which sometimes is not the obvious or the prototype one. The bars have to be distanced from the glass, otherwise they would not protect it - anything bouncing against the bars would push them into the glass and possibly break it.
Some people like their model flat all over, but I too think that one can play with different sheens in order to give the parts more 'body' or to accentuate different type of materials or paints. Are tethered model planes still used and is there a supply market for them ? I remember that very fine steel wire-rope was made for that, but don't know whether it would be still available. I discovered fly-tying stuff some years ago as raw material for making my own micro-ropes, but didn't know that leaders were available down to 0.008" (which is 0.2 mm in my units), making it interesting for small-scale models too. Good information for a non-angler.
Unless it will be visible, why would you want to remove an element that adds structural strength to the model at the risk of collatoral damage. It is also good to reflect on 'advise' given in books and other sources: why do they say so and would this advice be applicable to my circumstances ? We are not in the age of the Guilds anymore, so you can do what you think is best - of course considering the technological experience other may have.
It also depends on what size of parts you are talking about ... I have a mitre-saw like the one in your link and it works very well. For finer cuts I use a blade for metal. There is clearance in the middle to allow the blade to cut through, but this leads to the tendency of the blade breaking through at the last 0.5 mm or so. You can avoid this by placing a triangular piece of wood into the clearance. Also, clamp your stock to the saw. Cleaning up will be required in any case. If you don't have a disk sander, you can make a sort of vertical hand sander from scrap wood. I think there are some examples here on the forum. Here is a picture of my micro-version to give you the idea:
As carronades came onto the 'market' only around 1770, I gather these would be cannon and cannon at that time were normally mounted on wheeled carriages.
15' Dinghy by Bedford - FINISHED - 1:1 scale
wefalck replied to Bedford's topic in Non-ship/categorised builds
I gather I am not much of a rower, but it makes perfect sense. Never seen such thing before. I suppose I would have turned to one of those clip-on mirrors some determined cyclists use. Nice 'keeping-with-the-style' solution. -
I am afraid, I only have one or two antiquarian books on the subject written in German. You will need to employ the services of Google ...
dull number drill bits
wefalck replied to BETAQDAVE's topic in Modeling tools and Workshop Equipment
The watchmaker spade drills bits I mentioned above have zero rake. Watchmakers used to forge them from oil-hardening steel, file them to shape, harden them (watchmakers are very familiar with hardening small pieces), and then grind and hone them. They were meant for reciprocating Archimedes hand-drills and cut in both directions. However, they can also be used in electric drills and, of course, in the lathe. I have a small butterfly-shaped jig (the correct name escapes me for the moment) for honing drills on an Arkansas-stone. It holds the drill bits in a collet and presents it to the stone at the correct angle. I never actually used it, I must admit, but I think it could be used to grind the zero rake onto twist drills. -
Just a thought: we all love the challenge of mastering a new technology, but it may be worthwhile to ask oneself, if this technology then provides really the advantages sought for. Most ships have at maximum two anchors of the same type and size. So, unless you are building a series of models, it is rather unlikely that you will ever need that anchor in exactly that size again in your lifetime. In order to replicate it by casting, you have to fabricate a master first. Fabricating another copy of the master is probably less work than taking a mold and then casting it ... Incidentally, printing anchors could be one of the few useful application of filament-printers. The slightly rough surface of the prints might be well-suited to the quite rough forgings of the anchors.
As on the left. If you make it as on the right, the metal with rise out of the vent before the mold is completely filled. Also the vents in the mold on the left should go up to the level of the funnel for the same reason.
