Everything posted by wefalck
Not bad at all. If I may make a suggestion: I would not produce them with a base, but rather have some sprues or something sticking out of their feet - this would allow to drill appropriate holes into decks etc. for fixing them. It might be also an idea to offer them at one of the 3D-printing service providers for scaleable printouts - thinking of smaller scales.
A Lorch Micro-Mill that never was ...
wefalck replied to wefalck's topic in Modeling tools and Workshop Equipment
Good point: 1. because I wanted really sharp, 'cutting' serrations to positively lock the draw-tube into the knob, 2. this method is less straining on the lathe, though the cutting is quite tough on the nut of the top-slide. -
I cannot answer the question pertaining to HMS BEAGLE or HMS ENDEAVOUR. In general, I think a surface treatment (varnishing, oiling) showing the wood (typically mahagony) was preferred. Like the binnacle it was often some sort of show-piece or adornement and, therefore, also had polished bronze or brass fittings. However, I have also seen painted wheels with cast-iron fittings. I gather it was a question of the 'grade' of the ship and how much pride the owner took into it. Oares, sweeps, rudders, masts and similar pieces of wood would have been stowed inside the boats (if the boat stood upright in chocs or was suspended from davits) and securely tied down. Otherwise, oars etc. would have been lashed-down besides or under the boat. More perishable materials, such as sails would be probably stowed below deck, unless the boat was covered in a tarpaulin or it was the boat that was kept ready for service.
Thanks ! *********** The milling spindle was missing the draw-tube. A new one was turned from a piece of 8 mm tube with a 5 mm bore. One end was tapped 5.1 mm x 36 tpi for the collets, for which I am lucky to have a tap. The other end was serrated to provide a positive lock for the hand-wheel. For this machining operation, a pointed tool was mounted with the cutting face vertical in the QCTP and the draw-tube indexed in the head-stock of the lathe. Serrating the draw-tube on the lathe The original hand-wheels were made from black or dark-brown Bakelite, a materials that is not easy to buy anymore these days as round stock or thick enough plates. I had to resort to a piece of black POM. As it turned out to be too complicated to set up the radius-turning tool for this, the torus-shaped rim was fashioned by free-hand turning. The POM is rather soft and was best finished with a fine file and steel-wool. The finished hand-wheel was loosly taken into a 3-jaw chuck and the draw-tube, that was held in a collet in the lever-tailstock was pressed in. Turning the hand-wheel from POM Finished draw-tube and an original one To be continued ... -
Actually, on rasps this chemical (acid or electrolysis) treatment might be more successful than on files.
In German we have a saying: "Erst das Wasser, dann die Säure - sonst geschieht das Ungeheure" - in free translation "First the water, then the acid - otherwise you are in deep ****". The first drops of water vapourise immediately and the steam carries with drops of acid ... I am sort of chemist, a geochemist to be precise, and I know what I am talking about. Guess why - well not because I made the mistake, but I have seen others doing it and nearly hitting me with a spout of hot sulfuric acid ... I think the electrolytic method would be much safer and more controllable. The other electrode needs to be more inert than the iron (conversely, one uses less inert metals, such as zinc, to protect iron/steel ship parts). I would doubt, however, it is worth the effort. As was noted above, the surface would rather be eaten away quite uniformely, while in sharpening you would need to eat away the bent-over and flattened teeth. Before the process you would also need to clean the file from any dirt, grease, stuck-on filings, etc. in order to present a metallic clean surface. It is better to maintain the files carefully and to buy a new one every 20 odd years or so ...
What is your preferred work height?
wefalck replied to Nirvana's topic in Modeling tools and Workshop Equipment
Yep, bought a couple of eye-surgery scissors and recycled some of the anatomical(?) tools of my late father, who trained as a medical doctor during WWII, such as (heavy) scalpels, cartilage scrapers, etc. Also, the arsenal of dentists and dental technicians contains useful implements. -
8 microns shavings
wefalck replied to Gaetan Bordeleau's topic in Modeling tools and Workshop Equipment
Makes perfect sense to start off with a piece of wood in which the grain is perfectly parallel to the plaining direction. I love nice wood, but hate to see old trees being cut down for it ... -
8 microns shavings
Wonder what kind of wood it is ? -
Not much choice, my work-benches have writing-desk height. I am also like the lorry-drivers mentioned in the initial post: as am working all-day at my computer, I also like to sit down for the modelling work. The bench-height I think it is a sort of compromise. For some types of work, you want to have the desk more or less at ellbow-height, in other cases you would like to look down on the work. Watchmakers and Goldsmith have heigher desks and adjustable fore-arm rests for intricate work. In the old days the watchmakers apparently also put the wooden storage boxes of their lathes on top of their stools so that they could look down onto the lathe clamped to the desk. For rougher classes of work I have a foldable work-bench on which I would work standing. usually outside because of the dust. -
Does cling-film cling to epoxy resin ? No idea, but if it doesn't, you may be able to use it like 'peel ply' thing. I gather it works squeeze the resin flat, rather than following the contour of the woven fabric surface. Could be worthwhile some experiments.
- 339 replies
- dumas
- Chris-Craft
(and 3 more)
Coming .... ************** The milling spindle was disassembled and given a thorough clean and generously oiled before being put together again. I also replaced the slotted worm screws that lock the pulley in place with Allen ones. Not original, but easier to operate. Disassembled milling spindle These milling spindles are intended to be operated horizontally and, therefore, have only a simple oiling hole with no cover. In order to ensure adequate oil supply to the upper bearing surface, I fabricated an oilder that rises to the level of the upper bearing. A piece of 4 mm brass was turned down for a press-fit into the oiling hole. Steps in manufacturing an oiler An 1 mm-hole was drilled part-way from this side and a 3 mm-hole from the opposite side. The resulting tube was cut at a 45° angle and the two pieces silver-soldered together to form a 90° knee. From a short piece of brass a cap was turned and bored for a sliding-fit over the oiler. Since the convex knurling worked so well, I applied this also to the cap. The finished oiler Re-assembled milling spindle with new oiler To be continued ... -
I have used it. However, somehow the acrylic started to cure inside the tube (which is black plastic) and I had to throw it away - the shelf-life was less than impressive. This defeated from my point of view the objective, because I bought it to circumvent the limited shelf-life of CA glues. I have a large tube of UV-curing cement from the original manufacturers of Plexiglas in the fridge for about 30 years now and it still works ... perhaps should have stored the Bondic also in the fridge. In a way it is rather strange, that these cements are quite expensive, because actually every dentist today uses such UV-curing cements (ok these may be rather high-spec varieties) and the so-called 'nail artists' too. For making these not very elegant fancy false and built-up nails you can get UV-curing acrylics and UV-lamps quite cheaply on ebay et al.
Red Paint or Red Ochre
wefalck replied to davyboy's topic in Painting, finishing and weathering products and techniques
Not sure, what point you are trying to make ? Aren't we talking about prototype paints from bygone areas ? -
It is important to keep in mind, which kind of pigments were available at a given time and which ones were cheap enough to be used on a ship. The palette of an artist has always been richer than what was used for such mundane tasks as painting ships. Cadmium-based pigments are a 20th century invention. According to Wikipedia, the potential for the red and yellow Cd-oxides as pigments was recognised in the 1840s, but commercial quantities did not become available until around 100 years later. Today, Cd-based pigments are being phased out again due to the environmental concern over such dispersive uses (for the same reason Cd-based batteries are being phased out as well). However, Cadmium-Red and Cadmium-Yellow paints for artists do not necessarily contain Cd, but are close matches with other pigments. In fact, I think the discussion on the exact hue/colour and trials are rather futile. While iron-oxide reds are rather stable pigments as such, the exact colour of the paint made with them depends on a number of factors, such as how many waters are in the crystal structure of the oxides, where they were sourced, what other components were used in the paint, etc. The best solutions would be to find an ancient recipe for making the respective paints. But even then, there could be significant variations. Also, until the middle of the 19th century, navies gave their commanders considerable leeway in the details of these matters and there was no centralised supply. Colours did not become standardised until after WW1, when for instance the German army began together with industry to develop a colour table that still is in use today, even outside Germany (the 'RAL' numbers). So I would not get too worked up about this as long as you have a somewaht mute and slightly yellow-brownish red. -
With only a few days between the many business-related travels, progresss is very slow ... With most of the machining done, I turned my attention to the finish. I would have preferred to leave the parts in their bright, nickel-plated finish. However, the plating on the foot, for instance, was coming off in large flakes. In addition, the parts fabricated from aluminium have a rather different colour. I wanted to have a unified look. Therefore, I spray-painted most parts in my favourite bottle-green (RAL 6007). Masked Primed Painted To be continued ... -
I gather, you are talking about the mast-fish, this massive piece of wood the Vikings et al. used to step their masts in. I would suggest to carefully degrease it with acetone or similar and then to (spray-)paint it in acrylic 'wood' colour. This light coloured 'wood' colour can be found in the range of several paint manufacturers, such as Vallejo. The next step would be to apply washes of burnt umbra acrylic with a brush. This has to be done in several layers with a lot of water as a diluant. With these washes you simulate the wood structure, so don't try to get an uniform coverage. You can also use black washes to deepen the colour. If you want to have weathered look, you might give a light wash with white. I have shown this example from my own production in a similar thread a short while ago (apologies for copying it again): Base coat After washes with burnt umber and weathering with white
Messis, could you post a picture of the piece you are referring to ? It seems strange that a kit manufacturer should use solid copper pieces. Copper is expensive as such and not so easy to machine or cast ... Metals (and plastics) can be quite convincingly painted to represent wood. There are various examples here on MSW (including my own ). More difficult it would be to match existing wooden parts. Show us the part and we can give you more detailed advice !
Power Tools for a Fully Framed Build
wefalck replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
Depends what you are doing, but I couldn't live without a lathe anymore. With a vertical slide you can even do small and light milling jobs. Apart from the hand-held power-drill that costs very little these days, a lathe (with collets) would be on top of my list, if I would start out fresh. -
Windlass purchase link
wefalck replied to frenchguy's topic in Metal Work, Soldering and Metal Fittings
I just bent and soldered the rods and links from brass wire on this 1/60 scale model: The purchase arms were made from three layers of brass soldered together, as they have to sort of clamp around the ratched wheel. It is a bit fake, however, as the ratched wheel does not have grooves on the side into which the brackets of the purchase arms would link. There are also no ratches -
As I suggested above, perhaps the administrators start a sort of permanent file, where one can compare the different capabilities and capacities. I agree, for making jigs and attachments for your machines, a bigger machine would be handy. But you will find that is always a 'catch 22' - you always better have a bigger machine for making attachments for your smaller machine. But, how did they do in the old days, when there were no bigger and more precise machines ? Sometimes it just need ingenuity and patience and you can turn out good stuff with smaller machines. As said earlier, if you can't have a range of machines, you have to make a trade-off between your needs. In principle, a big machine is more stable, has less vibrations and, therefore, the potential for higher precision. This, however, requires that it is well-made and well-adjusted. The problem is that adjustment costs time and, hence, money. This is were the Chinese makers cut corners in order to be able to sell their products at competitive prices. Compare a modern-day Chinese mill or lathe with a precision machine of the 1940s or 1950s (the pre CN- and CNC-age) coming from Switzerland. On the latter the slides move like silk in spite of the large masses involved, because the ways have been scraped-in and not just milled. In order to get equivalent handling for working on small parts, you have to opt for a smaller machine - unless you are a master in machine adjustment. BTW, I am working steel on my watchmaking lathes and mills. It is a pain at times and takes a long time because I can only take light cuts, but with perseverance I manage to most things I want to do. The same machine, on the other hand, is ways better than a big Chinese machine will be, on small parts. With careful adjustment, the Sherline or Proxxon machines are almost as good. -
Again this is a recurrent discussion ... the epical dock-yard models were made without power-tools available, they were simply not invented then. (Almost) everything can be made with hand-tools, given the necessary dexterity and patience. Power-tools (not the hand-held ones) have the advantage of controlled movements - you work in a Carthesian space and need to worry only about movements along one axis at a time - much easier for many of us. Often power-tools also save elbow-grease, of course. OK, this was rather philosophical. On a more practical level, you need to know what kind of materials you anticipate to work with. Wood, metal, and plastics all have quite different machining properties and require (often) specific tools. Wood requires much higher cutting-tool speeds than metals. This can be a serious limitation, when thinking of using a metal-lathes for working on wood. Most mills run only at around 5000 rpm, which is too slow for the small cutter you are like to use. The only mill I know of that has rpms adequate for wood is the smallest PROXXON. There you run into capacity problems, because the slide travels are rather limited. It would be ok for making small parts, but could pose a problem, when you want notch keels or something like this on largeish models. There will be alsway a trade-off. -
This seems to be a recurrent topic. Perhaps the administrators could/should create a permanent space, where the pros and cons of different types (not makes !!) of machines can be laid down.
