gdollow
Posts posted by gdollow
Hi, I have just caught up with this build, the ship is coming along nicely. I am currently build this model. I have the plans from the Royal Maritime Museum, and I have modified the belaying pin racks around the fore mast. This has altered the attachment points for the rigging. Looking at the belaying pin rack by the main mast, is totally different from the Occre plans, again altering where the rigging is tied off. Do you have a rigging diagram which shows where the ropes would be tied off using the modified belaying pin racks?
- Captain Slog, Canute, mtaylor and 7 others
- 10
- Captain Slog, GuntherMT, Dimitris71 and 6 others
- 9
G,
I know it has been a while since you finished the Bismark, but I wanted to ask your opinion on the Veteran Model C38's? I have the Revell Tirpitz and have slowly been purchasing the aftermarket parts I want and have considered the Veteran pieces but wanted an opinion from someone who actually used them.
Thanks in advance,
Steve
Steve
I think that they are good, a mixture of brass and resin. They make a nice replacement for the Tamyia molded box with 4 barrels. I did not use it in the end, but that was because I was getting bored with the model and wanted to get the model finished as quickly as possible, not because of anything wrong with the gun kit. If you do use them you will need to invest in a 0.2mm drill bit to drill out some of the resin for the barrels.
- Leo-zd, avsjerome2003, docidle and 8 others
- 11
Here is some progress on the deck superstructure which is replaced totally with photo etch. I have burnished all the PE as it means you do not have to use a primer. The decking is only placed on for the photos. The colour of the deck was done by 1 coat of pale umber (artist acrylic paint), a thinned down Tamiya deck tan, then a wash of wood brown (walnut), followed by a wash of dark grey. I only let the base layer dry, before putting the rest of the layers on in quick succession.
- RGL, Canute, popeye the sailor and 11 others
- 14
- Lukasvdb, Omega1234, Captain Slog and 9 others
- 12
Thanks. I'll have a look at your build. I wouldn't mind doing the 1/200th scale one, but it is a bit big for my bench!
- Captain Slog, docidle and yvesvidal
- 3
- Captain Slog, yvesvidal, GuntherMT and 1 other
- 4
- WackoWolf, Captain Slog, GrandpaPhil and 1 other
- 4
Graham...
Local sporting goods shop....FLY-TYING thread! All colors (grey is NICE) and finer than even 2 lb. nylon fishing leader.
Thanks
I will see what my local fishing tackle shop has
Hi,
This is looking very nice. Photo etch adds so much to these ships.
would you mind telling me the overall length of the model?
Cheers
Slog
Slog,
This model is 56 cm long, beam of 10cm and overall height 23cm
- Captain Slog and NMBROOK
- 2
HMS Terror by Keith S - OcCre - scale 1:75 - as she (dis)appeared on her final mission 1845 - first wooden ship build
Posted · Edited by gdollow
Thanks for the info, what is the book you are using. I have pre-ordered
