Thanasis
3 Followers
About Thanasis
  • Birthday 01/17/1962
Contact Methods
  • Website URL
    https://www.naftotopos.gr/index.php/el/
  • Gender
  • Location
    Greece-Volos
  • Interests
    Greek traditional wooden ships
4,278 profile views
  1. Hi all. These are also my cheap ideas on thimbles... Thx
  2. Hi George. I admire your tidy workbench and having seen your previous work, I'm sure for the magnificent result. Thx Thanasis
  3. Thank you all. What I meant was to make any modification only on the sides of the groove. I would never touch the already shaped and pre-caulked plank.. My suggestion with the folded sandpaper is what you see in the (photoshopped) below photo. You can keep a strip of folded sandpaper between a " Bulldog clip" and use the folded edge in the groove. Keep the jaws of the clip as close to the folded edge... Thx
  4. Hi. Did you try with a suitable finger nail file or with folded sandpaper...? Thx
  5. Hi. I don't know how much "tiny" but see whether those joints from an old umbrella might suits you... Thx
  6. Hi. I follow the procedure where the upper deadyes are already attached on the edge of a shroud but the seizing knots are slidable. So I have the ability to align all of them. See there "A way of seizing (my way)" Thx
  7. Thank you Chaptman Yes I have read about that also in the fight against Aegean pirates, where the chase in no wind state, was kept on by rowing boats. But again in this case the boats were parts of the chaser ship. In my cases these small fleets (one schooner and 12-13 boats), were formed quikly to seize the chance. And what make me wonder is , whether was posible some of those specific type of boats (is narrated as "maltese" boats), could be kept in ports or near by, for these kind of missions. Thx
  8. Thank you both. Yes, it's rather something similar since the tactic in Danish gunboat war, was exclusively between armed small boats attacking a target. In my cases there were only armed men using the unarmed boats like tranfering vessels. Thx
  9. Hello all. I'm in the middle of a search related to an Ottoman small rowing boat, maybe also with some kind of riggs, back in 1800. In two historical cases, this kind of boat in a number of 12-13 of them full of gunmen, were accompanying-supporting a schooner, as all togethere, were attacing in an enemy vessel. Does this pattern indicates a kind of a naval tactic of that time. Is there someone who could inform me about. Many thanks in advance. Thx
  10. Hello. Having inventing this "my way of seizing" I would suggest to take a look in the below sketches. A. Shows how you should fold the thread around the bowsprit if there are already other rigging stuff alongside. It also shows the "premade" seizing, from which all the thread's edges should pass. Here the seizing is off the tool but it would be easier if you pass all the edges of the threads while the seizing is on the tool. B. Shows the already placed seizing (still a bit loose) and the deadeye in the upper loop. C. Shows that first you have to tighten the maine thread and then the thread of the seizing. At the end there will be a double loop around the bowsprit and a single one around the deadeye. Cut all edges and a bit of glue will secure the whole set. I hope it could be helpful. Thx
  11. Hi. There is also the below fishing tool which is called "Tie-fast knot tiyer" You can see its uses for ship modeling in the link. My way of seizing Thx
  12. Hi Cristiano. I just visited your build log, and I find your work amazing. Congratulation for your search and certainly for your beutiful model. Thanasis
  13. Hello and happy New year.
    See whether you can find something new-useful in the link (pdf file).
    There is some sources about the ship's base in Samos in page 67 and drawings and  a photo in pages 148-149.
    http://ikee.lib.auth.gr/record/128802/files/GRI-2012-8293.pdf
    Take care
    Thanasis
    1. woodrat
      woodrat
      Thanks, Thanasis. The pictures are very useful .
      Dick
  14. Congratulations George. I just show your progect, having stay away from Pcs for the summer and I'm amazed by your scratch building method and the excellent and beautiful result. I'm looking forward to see your work on "Karteria". Thx
