Posts posted by Adrieke
WEEK 13 and 14 (no I haven't forgotten 12 but the brass parts where damaged, so I have to wait on replacements)
both issues have the same contents :brass parts for the side prison walls, lanterns and doors
as expected the brass parts don't fit snugly in the wood parts so I decided to use some small wood strips to make them fit better
First picture shows one finished part on the left, the wooden and brass part in the middle and the cut outs of the wooden part
one of the cut outs I reduce in thickness to about .8 mm which I fix inside the wooden part using masking tape. then I put the brass part on top (see picture 2)
measuring each inside then cut some wooden strips 2 mm wide. apply some white glue and push against the inside using
the other cut out which I sanded the sides down so they are .6 mm less on each side (picture 3)
once the glue is dry sand them gently down to the level of the part
afterwards remove the masking tape and cut out and turn the part over. apply some superglue on the sides of the brass part and then put 4 more wooden strips on the inside
sand afterwards and then all is left is to paint the wooden parts fat black
- CaptainSteve, mtaylor, tarbrush and 2 others
5
- DCIronfist, mtaylor, tarbrush and 5 others
8
thank you Popeye
I have now started a build log for the Black Pearl
I would put the link in but I am not able to add one as my new computer with IE 11 seems to have some issues with this site . don't worry I ll figure it out when I have the time
WEEK 8, 9 and 10
each week brings 2 parts for the lower deck
no strips of wood for the planking but 2 pieces of cardboard.
main reason I didn't use them was that it is in 2 parts with a seam visible through the open hull
so I used left over 7 mm strips (way to big but they ll do) from the GF and used oak stain to darken them
the bulkheads are treated with a black japan stain
- DCIronfist, CaptainSteve, tarbrush and 3 others
6
- mtaylor, Piet, DCIronfist and 1 other
4
- DCIronfist, edmay, tarbrush and 3 others
6
about 2 months I subscribed to the Build the black Pearl from Hachette as it was just released in Australia.
it was my attempt to get back into building after a long time of no activity, as I figured there wouldn't be much work to do each week. each delivery contains 4 issues , but I will stick to doing one a week. for about a month I was working on another project (a bf gift for my wife) but now I am catching up again.
I ll be doing a post with some pictures every week )
- CaptainSteve, mtaylor and tarbrush
3
Adrieke :- Great to hear from you mate, you have been missed by a lot of guys and it's great to have you back. Are you back in the shipyard yet, if you are then it's time we got an update mate, no pressure though. Your absolutely right, the lads really are pulling out the stops and producing some really great stuff, the bar is being raised constantly and it's great though a little daunting.
yes i am back in the shipyard , and i will have some update pictures soon
Mine is in the dry dock too. sometime in the next months I am going to visit the replica and take plenty of pictures so I have enough photo material to adapt this kit to look like the replica.
soon I ll be starting on finishing painting the hull
for now I am first catching up on another build.
a few months ago I signed up for the build the black pearl magazine, as an incentive for me to slowly get back in to model building.
the idea was to do one magazine each week but some other activities (I got too many things on again) got in the way.
I should be back on track this weekend and then I can put my main focus back on the GF
here a picture of the Black Pearl so far
- Script, popeye the sailor, edmay and 3 others
6
looking great, the stand and the ship
I see you progressed a lot on her David
looking very neat
Black Pearl by Adrieke - Hachette (Amati)
WEEK 13 and 14 continued
the lanterns consist of 4 very small brass parts . the body needs to be bended and glued together.
next step will be adding the top and bottom part but because I am going to try to add lights inside I am leaving them open for the moment
for the lighting I have ordered some very small test led's and also one that is supposed to simulate a flickering flame.
this last one will most likely not fit inside the lantern, but I will experiment a bit. once I know how I will continue I will order the rest of the led's in the right size
finally I started fitting the doors window bars (some wooden strips where here also needed to fit it properly)
2 hinges and a handle will also be fitted to finish it off
