Posts posted by Pete38
Myself, I kinda like the contrast and color variation. Bet when they were building the original they didn't throw any lumber away because of the color variation. With that said, if it bothers you replace it, if it pleased you keep it. Your build your choice, do what makes you satisfied.
Was able to do a small amount this moring after work. Started cutting the smaller beams for the lower deck, I had already sized the stock with my thickness planer to the proper width and height. Use a quick set up to get all 10 pieces correct lenght with no tear out coming out of the saw.\
Slowly but surely getting there
- avsjerome2003, Canute, grsjax and 1 other
- 4
Thank you for all the likes....
Just a little more progress on the lower deck...
A couple of bottom shots
I said earlier that I was going to build the decks on the model, but just for some change and learning new ways to challenge myself, the next deck I will be building as a seperate unit off the model then installing it.
Just to see if i can
Finally got back to the shop for a little bit of work on the lower deck.
Decided to notch all the way through the beam for these parts instead of a half lap. To big of a chance for me to break them off
Started by using a hacksaw blade to notch them to almost full depth
Then clamped a backing board so to limit any tear out while using a small chisel to remove most of the material
Then used a file to make any final adjustment for the fit
Glued and installed clamps, waiting for to dry to start other side
Not much by slowly getting there.
As Ken said above, try roughing the glueing surface with sandpaper. The smoother (finer) the sandpaper the more closed the wood cells will be and not absorb the glue as much, the rougher the sandpaper the more open the wood cells will be to absorb the glue and make a better bond.
Greg,
found this site her http://www.taubmansonline.com/
They have the plans for a Sultana Mississippi River Paddle Boat that caught fire in 1865 killing 1547 people
Hull length 34"
1/96 scale 5-sheets 9-detail sheets for $60.00
Hope this helps
I did order the Belle of Louisvilee plans from them and had no problems, prompt delivery
I am not associated with the company in any way
I have started on the next section of these beams. I have forgotten what they are called?
Started with some rough stock and resized it down with my Byrnes saw and Drum sander
Layed out the patten with some 3M contact spray. (Sprayed only the paper patten and let dry for about 45 seconds to a minute) this way it will come off with out to much trouble with little or no residue
then sawed them out with my scroll saw and sanded to the lines.
Now dry fitting them and marking for my cut joints
Triton by Pete38 - 1:48 - cross-section
in Cross Section Build Logs for HMS TRITON
Soon as work will let me have a little time in the shop. As far as how much to leave....I would try for around a 1/16 (1 to 2 mm) . The more accurate you are at setting the frames on the keel and keeping them aligned the less you would
need to fair them in. hope that helps..
