Everything posted by Some Idea
So sorry to hear this Kevin and I would have done exactly the same thing as you.
- 443 replies
- Indefatigable
- Vanguard Models
Tobias in hindsight I should have used your method as it's far more accurate than the way I made these parts. When it came for me to apply the planking to the dogs legs I had to thin them out to get the correct hull shape. This pretty much showed my errors in the way that I made them. I can see by the way that you have made yours you will not have the same experience as me. I shall be using your method on my next build and thanks for sharing how you did these difficult parts. Cheers Mark 😃
I have to say that your work is fantastic - Great joints and it's so symmetrical too. I found that making the fashion pieces correctly to fit the wing transom and filler pieces was particularly difficult and you have smashed it - top job!
- 91 replies
- ancre
- La Mahonesa
Hi Nic and welcome - thanks for showing your grandfathers build that really is a lovely ship. If you would like to get into ship building get in touch with @chris watton as he supplies the most beautiful kits. He's based not far from you in Gloucester
I've spent the last few days marking out the strakes which is pretty time consuming. I wanted to stay as close to the plans as possible and try and achieve a nice even look too. I like to use automotive lining tape as it's nice and flexible - the only issue with this sort of tape is that it doesn't stick very well to the wood. So after using tick tape and a planking fan to mark out the master frame I started the job. My planks work out to be 9.9mm wide on this frame so I'll cut them to 10mm as my measurements are probably out a bit. Lining the stern Then the Bow I have one stealer in the stern straight off of the garboard plank and one drop plank towards the bow. So it's just as the plans suggest. I had better start cutting some planks now and get on with the job Mark
My build is out of square by roughly the same amount as yours. It won't notice as it doesn't on mine - keep going as your work looks great!
- 91 replies
- ancre
- La Mahonesa
Hi Brian and thanks for your really nice comments. You're spot on about how people have no clue about how ships were made and they probably have no interest either nowadays. I too really like the frames of this ship but this little vessel has always been a learning curve for me. I need to know that I can plank the hull as it should have been and I would like one side finished so that my family can see the ship without having to imagine it. The port side however will stay bare from the whale down so that the frames will always be visible. Cheers Mark
Thanks druxey and I'm glad you said that because after I glued the stove in I could see that I completely forgot to take the shine off of it. Oh well just another of my little mistakes but I'm gradually learning to live with them. As for the recovery - yea I feel loads better but can't go back to work yet but cheers for asking The garboard strake - This was a bit of a nemesis for me on my last build but I learnt a lot from that experience. So firstly I cut the planks but the profile is not flat it's slightly curved. I only curved the centre section with the view that I could blend it into the other two planks. I won't say exactly how I cut the inner curve as it involved using a table saw in a way that it shouldn't but the result was nice 🤣 I started in the middle as this is an easy plank - The other ends rotate through about 90 degrees. I then made and fitted the other two ends - This strake is 2.3mm thick so takes a little persuading but with hot water is not too difficult. I'm pleased with the result even though I haven't quite got it right on the forefoot. It's difficult to bend and clamp a plank through 90ish degrees and see if it fits exactly. I thought that it was but alas no! A bit of saw dust filler to the rescue which I'll blend in properly at a later date. Just looking at the hull I would guess that it will need a couple of stealers at the stern and a couple of drop planks towards the bow. I'll soon find out as the next job is to line out the planking which will reveal all! Cheers Mark
Hi All So it's time to put all of these pieces together and just generally catch up with myself. So firstly I put in all of the nails that I had missed and finished parts for the hatch above the stove. I also had to make the decorative rail that covers the end of the last beam. Loads of small clamps on the rail to get a nice even curve Then it was just a case of assembly and clean up. The results are below. So thats the forecastle deck and detailed work below pretty much finished. I'm a little unsure what to do next but I think its probably about time I finished off the planking of the hull. Cheers Mark
Some more work done - This time it's the small office/store cupboard. It's a very simple construction with brass hinges and lock. It has a small shelf too and many angles come together for a good fit. So now I have to bring all of these parts together and finish off some of the little details that I have missed Mark
ancre Le Gros Ventre by ChrisLBren - 1/36
Some Idea replied to ChrisLBren's topic in - Build logs for subjects built 1751 - 1800
Hi Chris I did mine the other way around - I cut the profile pieces and then cut the angle onto them. I'm pretty sure that either way will work though. I would also cut the dovetails into the wing transom as I have looked back on my build and thought of some of the details that I have missed. They could have all been done and the reason they weren't was because my patience was lacking. -
Goodness me Chris that really is lovely joinery 👍👍👌 -
Hi Allan - I use water as a clean up but I have never successfully used water to unglue my work. In fact I have had to soak some parts in ipa for 24 hours for them to separate with a good contact point. Can you expand on this a bit because if I can use water to unglue joints I would be very happy to do this.
I agree with Jaager try using yellow carpenters glue. It will give you far more time to place your planks and if you get it wrong IPA will undo your work. I know that many modellers on this forum use CA extremely successfully Chuck being one example but personally I just can't get on with the stuff. Yellow carpenters glue or aliphatic glue as its also called is very strong and grabs within minutes
Thanks Mark The bars really made me think as Adrain Sorolla solved this problem by making a grill that rested on the lower bricks. In the end I just simply ran a 0.9mm drill straight through the side that is pretty much unseen and then filled the holes with tree nails. The bars are made. of 0.8mm brass - Its easy to make things look difficult when you are in control of the photos 🤣 I have now made the feet for the stove so its completely finished now. I have also made the hatch for the main deck - I really like making these as their design just lets them simply lock together. Thanks for all of the comments and likes and hopefully I'll have some more to post soon - Mark
