vaddoc
Everything posted by vaddoc
  1. Some more progress made today. I finally got my gas heater sorted and now the garage is cosy and warm. I also spent 2 days cleaning and tidying up. I started sanding the hull and another difficulty in working in large scale presented. It is actually a physically demanding task! I initially used 120 grit sandpaper but then I used a blade to scrape the high areas. I continued with the 120 and it is starting to look better. There is still a massive amount of sanding but this hull has potential!
  2. I recently finished planking my hull. I used 1 mm micro screws to temporarily secure the planks. These when then removed and the holes filled with tree nails that I make in bulk. It worked beautifully but I built in scale 1:10, I ll paint the hull and my planks were 70 cm long. But maybe it can work for you
  3. My dear Patrick "I’m still chasing that elusive perfectly smooth and unblemished paint job" Easy, you just need to apply coat after coat, sand gradually to 250,000 grit or thereabouts and in a few years you ll get it. (my painful experience with brush painting) Or you can compromise for a really good paint job! It must be summer time down under, I envy the good weather in your photos, here everything is frozen. Looking forward to seeing this glorious golden paint fully buffed and shining Regards
  4. When I started boat building the first woods I used were lime, mahogany and walnut. I gave up on all. The problem with walnut is the interlocking grain. I found it difficult to cut and have a clean edge and when bend could suddenly break diagonally along the cross grain fibres. Shaping a strip, it could follow the stray fibres. There are much nicer woods. It finishes superbly though!
  5. Even after heating and bending, a strip should not really brake if pushed further. It might have to do with the wood you use. Maple and beech for example are very flexible and do not become brittle. This is a mahogany strip 0.5 mm that I bent to make hoops
  6. A milestone reached today. I glued the keel on! The hull is now complete. Next step lots of sanding, filling and sealing!
  7. Dear all Could I ask for your help in understanding how the deck is drawn in small sailboats. I am not exactly sure what or how to ask as my knowledge and understanding of this is very shallow but I ll try. I think I have understood that the camber of the beams is a parabola and that there are many ways that this can be drawn. My main problem though is the deck centreline. The way I understand it, it is essentially a straight line form the stem to the transom, having chosen a crown height at max beam. Due to the deck furniture and the very visible sheer, this straight deck centreline is hidden from view. However, it seems that most decks are truly curved. 1. Is there a rule of how curved the deck centreline can be? 2. If the centreline is curved, what happens to the king plank that needs to be straight? 3. Suppose I draw a slightly curved centreline that pleases the eye and then arrange the beams using the same way to figure out the camber. Is it likely that the deck planks will sit nicely or will a lot of fairing be needed? 4. Is the crown height measured perpendicular to the horizontal level or to the sheer? In the first case the beams will meet the deck planks at an angle and will need fairing but in the second will sit flat. Or is this not an issue to the relatively small rise of the sheer? 5. Is it better to go for a straight centreline or is it better to have a bit of curve? Apologies if I don't make much sense! Vaddoc
  8. Welcome Scipios!
  9. Another quick update The interior of the hull has had filler applied, then a coat of sealer, then a thick coat of Halfords white primer and then a coat of pledge floor polish. I think it is now reasonably sealed! I should have waited 24 hours for the primer to fully dry before applying Pledge but it did not cross my mind. The deck will hopefully cover all sins. I still need to remove the masking tape from the transom and stem but at least the appearance has improved a bit.
  10. Dear all You might find this helpful I have some 2 part epoxy resin that I bought maybe 5 years ago. It is still perfectly fine and I have lots left. However, the resin had become very thick to the point I could not draw with a syringe. I popped it in the microwave with the lid off for 25 secs in increments (for a half full 12 oz bottle). It liquified again beautifully. It seems that the resin can crystallise in cold or with time and that microwaving it or letting it sit in warm water brings it back. Visually, there does not seem to be any difference in its qualities. Previously I had thrown away epoxy or had trouble matching the volumes because of this problem so this seems a good fix. No health and safety guarantees though, I did it when the admiral was out. Regards
  11. Dear all A very quick update. I finished the beam selves, maybe I should have added another 3x3 strip on each side but it is super strong and I think it would be a waste of time and of expensive timber. I also added the stringer in one side and this task proved a very challenging one. It was difficult to find the position and persuade the 11 x 2 mm strip to stay in place. I had to use epoxy and the whole job was very messy. I do not look forward at all to doing the other side. Planking the inside of a ship must be much more difficult than planking the outside. I also started applying sanding sealer to the inner surfaces of the hull. White primer will be sprayed on top when all is finished. I am very happy I chose this boat, so far it has been great fun and I am learning a lot in the process. Still, it is far more difficult (and expensive) than I initially thought. Regards
  12. I think you are right Mark. So the plan now is to finish with the stringers and beam selves and then to seal the inside of the hull and spray white primer all over. Then, to glue the keel on, fill, sand and seal the hull but leave the paint for (much) later on. The beam selves should be 11 x 3 mm. I think it was a good idea to essentially laminate 3 strips 3x3mm each as I was able to very easily follow the curve of the sheer in both dimensions. I decided to use epoxy for its gap filling abilities. Still it is messy and unforgiving and I had to work really fast as with the high temperature in the house it cured very fast. The port side is curing and tomorrow I ll probably do the other side. I think I won't bother sanding the excess epoxy as the deck will cover everything. Indeed, you can never have enough clamps!
  13. Dear all thank you very much for your comments Druxey, indeed humidity is what causes the problem but with the cold and the constant heating in the house everything is pretty dry and it will be months before temperatures in Britain pick up! Mark, what do you mean by undercoat? The inside of the planks is well covered with filler but I guess I could spray some white primer on, this should seal it even better as well as cover the ribs and keel. As for the outside of the boat, after filling and sanding I was thinking of actually using a sanding sealer, then primer and then paint the hull. I have used sanding sealer on MDF which is very water absorbent and waterproofs it nicely. This should seal the wood, I just don't know if I can do this before spring time. I was thinking of getting the beams and deck on before sanding the hull but maybe I need to finish the hull first, at least getting the sealer and primer on and the paint bellow the waterline as primer is soft and will mark easily. Regards Vaddoc
  14. I ve made some progress in the last couple of days. Due to the malfunction of my gas heater I had to work in the dining room table. My 2.5 year old daughter was very interested in the boat and she "helped" me a lot this past two days, sitting in my lap and constantly moving while I was trying to drill 1 mm pilot holes or helping me with the screwdriver leading to a few stripped screws... Would not change this for the world! First thing, I decided not to build the interior of the boat. I am not really interested enough and would much rather carry on with the hull, deck, rigging etc. This decision simplified things a lot. The boat has been in the house for 3 days and I can't say I ve seen a huge improvement in the gaps in the planking. I have a feeling that these gaps will not fill well from the outside as I have sanded the inner edges of the planks far too aggressively. I decided to fill al gaps from the inside. The result is unsightly but it does not matter as I have already decided not to do the interior. I used a light filling putty and improvised a few tools. As the boat is so huge I could actually squeeze my arm in! The result was pretty good.I think that later on filling and sanding of the hull will now be much easier. Next I started work on the beam selves. It needs to be 11 mm wide and 3.5 mm thick. I decided to make each self out of 4 strips 3 x 3 mm. I have a few pear wood strips which I can use. Par is super strong, excellent for this task. The upper most strip will be screwed onto the frames and the lower three will kind of laminate with epoxy and may be reinforced with screws. The upper strips went in fine. I felt that the hull stiffened up considerably. Regards
  15. Dear all I think the problem is solved. I decided against building the interior so no huge access needed. Still, the boat is so large that I can squeeze my arm in the hull! Most importantly though, I added the first strip that will make the beam selves (It will be laminated from 3 strips 3 x 3 mm each. I feel that the hull immediately stiffened up a lot. I ll add the rest of the strips for the selves and also the stringers and I will report back when I take the braces off. Many thanks for your advices. Regards
  16. Druxey, the boat now lives in the house and will only go to the garage when I ll be working on it. Yes, we do suffer winters with the dry air! Thank you Mark, it is about 1 mm in many areas, too wide to paint. The whole boat is about 70 cm in length, 1:10 scale. Another problem is that I sanded the bottom inner edges of the planks but much more than I should. After sanding the hull, these gaps should open up even more. It seems that maple that I used for the planks (well seasoned) has high movement in service. I think I ll wait for a few days for the boat to soak up moisture and then I ll fill the cracks from the inside, sand the ribs, install the beam selves and stringers and take it from there. Vaddoc
  17. Dear all Work continues slowly with its ups and downs. John many thanks! I continued taking frames out but then a problem developed. The hull started deforming. I have started a separate thread on this. (https://modelshipworld.com/index.php?/topic/17360-hull-deforming-advice-needed/&tab=comments#comment-536582) I have now taken all the temporary frames out and installed all the permanent frames. I have installed more braces to preserve the shape of the hull. Now, this indeed looks impressive, very rewarding photos! I am not sure now how to proceed and I need to think. Many thanks to everyone that have offered their advice on the thread. However, there are two more new problems. One, my gas heater broke down and the replacement I was sent does not work either. With freezing temperatures I can no longer work. Secondly, there are now gaps in between all of the planks!. I think the reason is the change in moisture. When I installed the planks it was summer and humidity was high. Now the boat and wood is constantly in just above freezing temperatures and I think humidity has reduced a lot and the wood has shrunk. Not really sure how to deal with this. I think a lot of filling will be needed but in the next season cycle it will probably fall off. Who said boat building is easy... Hopefully my gas heater will be fixed and if life allows me I may do a bit of work in the next few weeks. Mary christmas and a happy new year to all! Vaddoc
  18. Dear Druxey, Jim, Steven and Bruce Thank you for your suggestions. I have now installed more braces and removed the last two temporary frames. Steven, your boat is very nice. 132 frames though! And I though my 84 were a lot. Still, your boat even without stringers held its shape. My frames are 4 x 2 mm beech and despite they bent nicely after heated through, they are stiff and they seem to push hard against the planks. I am really not sure what I should do. Building a scaffold externally to support the hull seems to be the more comprehensive way but means an awful lot of work. I find that I can squeeze my hand enough to do some work and possibly I will be able to sand the frames and install the stingers and beam selves. I think that I may have overcorrected a couple of areas when installing the new braces as I had to push rather hard to install them. I ll have another look. Certainly though the hull will need to be supported. This was a useful lesson. I think that hulls with steam bend frames are lighter but probably not as strong as hulls with proper solid frames. I ll post updates in this thread when I find theme to do some more work. Regards Vaddoc
  19. Dear all I would be very grateful for a bit of advice. I am building a boat that has carvel planking with 42 steam bend ribs each side. Initially during building there are some plywood frames that hold the shape until they are replaced by the ribs. I have installed almost all the ribs and only 2 temp frames remain in place. I was advised as a precaution to have some cross-spalls to avoid hull deformity and I installed a few. However, I noticed today that the sheer plank has deformed and is now a bit wavy. The photos show that in the gaps between the cross spalls and frames, the ribs are pushing the sheer plank outwards. The photos exaggerate the deformity due to lence and distance issues but it is there.It took a few days for this deformity to develop. In the plans, the next step would be to install a stringer low in the bilge and a beam self. However, I still need to do some work in the interior (sanding, floors, mast step etc). Also I need to first remove the remaining two frames which will probably lead to more deformity. 1. What will happen if I remove all frames and braces? Will the sheer plank short it self out with minimal overall deformity or will it massively deform? 2. Should I put even more braces and pul the sheer back into shape and then install the stringer and beam self? But then I will loose all access to interior. Still the beam self should add a lot of rigidity to the sheer. 3. I this what happens with all steam bend ribbed hulls? Any advice would be greatly appreciated as these are uncharted waters for me Regards Vaddoc
  20. Just a quick update My parents have been with us for a month so lately I was able to work on the boat. They are now leaving so back to my usual snail pace! I ve taken all but two of the frames off and only 4 ribs are left to be installed. It looks alright! Bags of work left...
  21. Thanks Patrick! A couple of more photos, I have installed most of the ribs and removed some of the frames. I also followed Druxeys advice and got some cross-spalls on. I need to finish with the ribs, sand them smooth, fill and sand the inside of the plank to plank gaps and install the lower stringers and the beam selves. I think then the boat will hold its shape a bit better. It is amazing how much material the boat is consuming. Also, these cross-spalls are very much in the way, I did not expect this, I though I would have a fully accessible hull at this stage so now everything will be a bit of squeeze and struggle.
  22. I have a variety of surgical blades which are very sharp but brittle. I use some universal plastic-metal holders that came with a cheap set and hold the blades just fine. However, I lately use more the very common knives with retractable blades that you can snap off a section. I have a few 9 mm and a couple 18 mm ones and I buy blades in packs of 10. I find them less sharp but I can cut paper, wood and metal and somehow are easier to keep on the line I intend to cut. Since I got a 4mm chisel, I find I use it also quite a lot.
  23. I run out of tree nails and made a few out of the nice cherry piece I was given. This is how 1500 tree nails (give or take...) look like!
  24. I ve been silently following your Shadow from afar Patrick, it is a lovely model. I think the golden paint looks fantastic, looking forward for more photos Vaddoc
  25. I continued installing the ribs. I throw the pieces in boiling water, then fit them to the hull and bend to shape, secure with 1 mm screws, then drill and install the wood nails. Then a few hours later remove the screws and fill with wood nails. Most of the ribs are in but there is a lot of work left and some ribs can only be installed after the frames are removed. Beech responds superbly to heat: An interesting aspect: During planking, there were a few areas that the plank did not follow the contour of the hull for all of its length. This was due to a lot of factors. Either the grain had a funny course and the plank was wavy or the frame was a bit off or the plank was a hair too long or did not fit perfectly. I thought that I could pull the plank into alignment with the screws and nails but this only worked to a (small) degree. Hopefully next update will be when all ribs are in place.
