Everything posted by Bedford
15' Dinghy by Bedford - FINISHED - 1:1 scale
Bedford replied to Bedford's topic in Non-ship/categorised builds
She's going to be in Wooden Boat Magazine in March under "Launchings" but I haven't written much in that. I'll have to check out this "offspring" It has been a joy to build and very rewarding, every time I take her out someone always comes up to me and comments or wants to talk about her. If you have the desire and the skills, do it! -
Another day in the workshop has resulted in the boom now having a yoke and reefing sheave fitted. This sheave axle required no fancy machining as it is captive once the yoke is attached. The first pic is for anyone who wonders how you get two parallel flats either side of a spar. It's simple really, the sides of the bench plane are perpendicular to the sole therefore if you clamp the spar securely so it can't move at all then lay the plane on its side and plane the first flat you can then swap to the other side to plane the second flat, even if the blade is out of square with the sole the flats will be parallel because the error is repeated equally on the other side. -
Thanks geoffs, I've seen the ones tied up under cover outside the Wooden Boat Centre next door to LBT They're just a nice boat that looks right aren't they. -
I'd be lost without the lathe, it's been so useful in so many ways in this build, the latest is the sheave axle in the mast. It's easy to put a bit of 6mm brass rod through the mast but how to secure it? Solution, start with 20mm brass offset in the 4 jaw chuck. Turn down to 5.95mm then part off with 2mm of the original stock then a little bit of hacksaw and a touch of file and wet&dry and it's sorted. -
Yeah Mark that's what I was thinking. Today I finished the sanding and stepped the mast head to accept the mast band, I had to go with this size, 32mm I.D. because the next size up was 51mm I.D. which is the O.D. of the mast at that point. When I set it up I'll see if I need to put a more gentle taper on the shoulder. So armed with a nice sharp chisel and a compass I was able to come to the end result shown, the mast band fits on very nicely. The next step is to decide if I will use 40mm diameter sheaves in the mast for the halyards or turn up some 50mm ones in brass. I'll do the 40mm first and see how it all feels. -
Work is proceeding on the rig, the sails are ordered and should be available mid January while the hardware is in the garage and the spars are slowly taking shape. I've planed enough shavings off the spars in rounding them to fill a 240ltr bin! I've been sanding for a few days and now only have the 240 grit to go on the mast and they're done. I came to the realisation that I could either have three near round spars or three perfectly round toothpicks! I opted for the near round spars. -
Mark, it's interesting how the old boat builders knew how to make them that way but we don't today. The Waratah is the same, 160 tons, 33mtrs long and no wake to speak of. Granted she's going slow in these pics but she never makes much more wake
- 2,207 replies
Yeah space is an issue for most of us, you'll note the bandsaw is on wheels so it can be put away. When the boat and car are in the garage everything fits in like a jigsaw puzzle but thankfully I have the room to do that. -
Time to build the rig. I went and bought a lump of Sitka Spruce 75x150x5100 from which I can get all three components:- Mast is 4100x70 diam Boom is 2530x52 diam Yard is 2580x50 diam Obviously they all taper but those are the max dimensions. It took some planning to physically cut it all due to the size. -
I'm really looking forward to the day she goes back into the water
- 2,207 replies
My son lives in Canberra and each time he's come to Sydney the weather has been lousy for boating so on Sunday I took her to Canberra and put her in Lake Burley Griffin, it was a perfect day for it. It took a while for him to get out of kayak paddle mode and into row mode but when he did we made pretty good head way, we came alongside the jetty at the Australian Museum, tied up and went in for lunch followed by more rowing and a spot of fruitless fishing before rowing back to the boat ramp. He took a pic of her when we launched her and he has an eye for pictures, always takes a better pic than I do. -
I guess the sky is not the limit after all the ceiling is! That's an unusual problem to have in the model workshop.
- 2,207 replies
Thanks guys. She was entered in the Davistown putt putt and wooden boat regatta last Sunday but the weather forced cancellation. It would have been nice to see what the judges thought of her though I didn't build her as a show boat so didn't expect to win anything. Hopefully I'll have my electric drive next month so I'll be able to enjoy her a bit more and then after I find myself a permanent home will come the mast, boom, gaff and sails. -
She's a good model but that scale is hard to work with, especially for a beginner. Having said that I say good on you and well done. Here's the one I made, you might be able to get ideas from it even though it's behind glass and I don't have it anymore so can't take detailed pics.
- 105 replies
- thermopylae
- sergal
I have that type of pencil shown on deck, it really puts the scale of this build into perspective.
- 2,207 replies
Beautiful work as always, it's a great scale to work in.
- 2,207 replies
I have finished the rudder and tiller, the tiller has been given a brass rubbing strip in case buoyancy lifts it causing it to rub in the transom slot and the haul up/down lines have been replaced with a single closed loop system which will mean there are no hard to manage loose ends getting in the way.
