MrBlueJacket
Everything posted by MrBlueJacket
  1. Here are the bulwarks trimmed down to their final height. I used a Dremel saw attachment (carefully!) to trim it close, then sanded to the final lines I drew with a compass so it would follow the deck properly.
  2. Writing instructions can be a delicate balance between what you think someone buying a certain skill level kit should know, yet trying to help sidestep difficult construction details. Also, what we think we said in the instructions is not always what they are interpreted as.
  3. So with the deck done, I can attach the bulwarks. Still need to trim them down to the caprail level, but it's starting to look like a boat!
  4. Chris, I agree. But my customer likes it. So here's the template for the pounce wheel. 1" spacing, equal to about 5 1/3 feet (model is 3/16" = 1' scale) Note the bow is already pounced. After pouncing the stern deck, I did a brown wash into the holes, quickly wiping the thinned paint off right away. A bit of overkill, but....
  5. So I have the bulwarks ready to install. They are painted and have the scupper slot cut out. But before I install them, I am going to use a pounce wheel to simulate the deck treenails.
  6. Thanks for the deck compliments. I forgot to mention that it is a sheet of pre-glued decking strips, so I can't take credit for anything but gluing the sheet down and trimming :) The kit comes with scribed decking, but this looks so much better.
  7. Got the deck on last night and trimmed it to fit this morning. Cockpit well was opened up with a dremel cylindrical sanding attachment.
  8. Then to cut the plywood to the same shape. Needless to say, it took a bit of trial and error. But in the end, it is a good fit as you can see in the second picture. But before I glue it on, I need to put down the deck planking. Easier to trim first, rather than try to fit the deck on with the bulwarks in place.
  9. So I had a little time to work on the MT again. here's a picture of paper taped onto the hull so I can trace the bottom line of the rabbet for the bulwarks.
  10. Nice job! Am I reading this correctly, you only started the kit this past Sunday? That's quick work.
  11. Hi Ric, The ships I build are for a purpose, (customer, gallery, etc) not just because I want to build a model. My current stack-up is: rigging the USS Perry (new kit) Mary Taylor (customer) Coastal Schooner (new kit) Lincolnville wherry (gallery) Liberty ship (gallery) Red Jacket (gallery) And interspersed are two repair jobs. I trust you understand. Maybe someone out there with an Alfred will step up to the plate?
  12. So to attach the bulwarks, you have to cut in a rabbet around the top of the hull. I started with a piece of masking tape, which I then outlined with a pencil. That gave me a good reference to cut a 1/32" groove. Next is to chisel down from the deck to the groove, forming the rabbet for the bulkhead to attach to. You don't have to be super neat, the inside edge will be covered by the bulwark and the decking. I used a sharp (new) #17 chisel blade.
  13. The pedestals are F0876 and F0877. There's more than one way to sequence the hull. My plan is to attach the bulwarks next, then paint their inner surfaces. Then paint the outside of the hull, then attach the copper plates. After that, put the model back on the building board and do the decks.
  14. Time to drill out for the mounting pedestals and test fit onto a building board. The mary Taylor has a raked keel, so two different height pedestals are needed. And looking down the bow, it looks pretty straight up and down (Thank God, I hate shimming pedestals)
  15. Got a little vigorous with sanding the stem, but a little putty fixes that. Since the bottom will be coppered, no harm done. Some smoothing needed at the stern, too.
  16. Some people prefer to remove the bulwarks altogether and inset a piece of ply. That's how the Mary Taylor is built.
  17. So finally got the stern shaped, the rest of the hull only needed a little cleaning up. So like jfinan said in his Constitution build "laying the keel is always a momentus occasion"
