MrBlueJacket
Everything posted by MrBlueJacket
  1. In the meantime, built the propane tank, X-band radar, and muffler/exhaust as well as painting the pilot house.
  2. Yes, it was only one more round of primer/putty. Here's a shot of the rudder and sternpost, and the rudder hole drilled into the hull.
  3. Filled in with auto glazing putty and sanded it down. Hopefully only one more round of primer and putty?
  4. So now the bulwarks are in, a coat of bondo applied to the gaps in the joint and sanded, and a quick shot of primer to highlight the "discrepancies"
  5. Andy - I think you are doing a good job. Remember the old quote: "Putty and paint, makes it look like it ain't" TeeHee Nic
  6. I have been following this build and am amazed at the level of detailing you have done - GOOD JOB! Makes me proud to give you the platform to follow your goal. Nic
  7. Hull sanded down. I always use a sanding block to get a smooth surface. Just using 80 grit for now, but after the next round of primer and putty, will switch to about 150 grit.
  8. Used the Dremel sanding drum to thin out the bulwarks. After I put in the plywood pieces, I will thin some more. Luckily, the Forecastle decking will hide most of that space.
  9. Nice job. As I promised, there is a note in your customer file for 10% off your next kit purchase.
  10. While at a Maine Made show in Bangor, I came across a guy who cuts trees into 1/2 inch slabs for cutting boards. I thought that one of them would make a great baseboard for the trawler. Here it is:
  11. A coat of primer, then an application of red oxide auto putty, then sand. After that, repeat at least once more.
  12. *sigh* another application of Bondo. But finally, it is starting to look like it should.
