giampieroricci
Everything posted by giampieroricci
  1. Hallo, Cabrapente! Your work is wonderful! As have you simulated the cerclage of the barrels? By pyrography?
  2. Thank you, very much, friends!! A small coat of matte varnish: completion of the gun deck with hatches:
  3. Fantastic work, Albert!! The colors of your woods are wonderful!!!
  4. I completed a gun carriage it seems that the guns are too inclined downward: I have to delete one of the two pillows under the breech
  5. This is only the first attempt: I should be much more precise with the measurements
  6. burnishing the little door I fixed the hinges with these beautiful rivets round head 0,3x2 mm and this is the end result: the photos are all in super-macro! The door is fully functional, although it is terribly delicate!
  7. I started to build the doors for the oars; the major difficulty has been to be able to realize the hinges so that they were functional. First, by a thin copper foil has formed the curved part: I filed the interior with the grinding wheel after drilling the holes 0.3 mm I finished the outside I made the hinges by cutting half with the grinding wheel The part of the hinge to be fixed at side
  8. Hallo Ed! Your work is simply fantastic!! What did you used to weld the anchors? It looks so perfect!
  9. Thank you for your compliment, friends! This corvette has 12 guns: I have to do a total of 24 hooks.......
