Here are a couple of pics showing the conning tower top fitted with slightly thinned down parts - periscope etc, the photos are not too great as they where indoors with just kitchen lights and no flash, both were a bit grainy due to high ISO and the close up was a very low shutter speed so a bit of shake. OC.
- 229 replies
- trafalger class
- airfix
I used to be a keyboard player and still record using VST digital equipment. OC.
- 229 replies
- trafalger class
- airfix
I thought the same - I might try an take a couple of them away, and thin the rest a bit with a sanding stick. OC.
- 229 replies
- trafalger class
- airfix
Right - more work on the sub this afternoon, I masked and re painted the top anti-slip black paintwork, then I turned my attention to the sail/conning tower top section, this has multiple devices - periscope etc, theres were cut from the spue and cleaned up before placing in thier respective positions, I also painted the inside white as this will be seen from the top. Here are a couple of pics (taken with my phone camera as I do not have a close up lens on my dslr) OC.
- 229 replies
- trafalger class
- airfix
I wont scare anyone - so I will relent from singing, I used to be in a band in the 80s but thats another story. OC.
- 229 replies
- trafalger class
- airfix
Such a shame there are no QE ships in 1/350 scale of that period - only WW2 versions. OC.
- 1,090 replies
- showcase models
- vendetta
Hiya mate hope you and yours are well, wondered where you had gone, thought my singing had put you off I decided to give her a complete makeover, she has had a refit and new lick of paint and shortly ready to go back into service. OC.
- 229 replies
- trafalger class
- airfix
Thank you sincerely mark, she does have a more stealthy look to her now. OC.
- 229 replies
- trafalger class
- airfix
Those are Superb greg, I have them on my warpy kit in the pontos set. OC.
- 405 replies
- tamiya
- king george v
Looking good, I wouldn't have fancied climbing those ladders. OC.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
I cured my stuck glue tube with some heat - you know those attraction car displays with the flame thrower exhausts.......... only kidding, I used a gas blow tourch. I realy used a lighter to heat up the end of the tube. OC.
Evening All, Im returning soon - so dont go away, im just finishing off my sub build, then I will return here as I have restored my mojo for my plastic builds, and my hand is not playing me up to bad. So recharge your pop corn and drinks (whatever your poison may be) and please make a slow return back to your seats. OC.
On the masts themselves, they look like ladders, my warspite has them as part of the pontos pe parts. OC.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Did you have to attach those tinyyyyy ladders up the mast? OC.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Thanks carl, spraying it was so easy and clean. OC.
- 229 replies
- trafalger class
- airfix
- 229 replies
- trafalger class
- airfix
Wouldn't it be great if we did a Battle of Jutland project - I would need to wait till xmas though to see what santa brings. OC.
- 1,090 replies
- showcase models
- vendetta
This would be an amazing kit to do for a Jutland participant. http://ironshipwrights.com/pages/bellerophon.html OC.
- 1,090 replies
- showcase models
- vendetta
I still have "The Ole Lady" to carry on with (remember her) I stopped because of my hand condition, but touch wood it hasn't been too bad building my sub. OC.
- 1,090 replies
- showcase models
- vendetta
Yep I have done similar - the top of the sail is open at the moment, so I managed to find one of my brushes where the handle fitted inside with a quite tight fit, I ran some gaitor pva down inside around the handle, with any luck it will hold the brush handle enough tomorrow so I can hold it to spray with. Then when dry I should be able to cut away the handle to allow the top of the sail to be fitted. OC.
- 229 replies
- trafalger class
- airfix
