Posts posted by vossiewulf
Ok i don't know what I did to merit a personal ship construction research service but I'm rating the results at *****, a solid five stars :). The Swift's gunwales are basically exactly what I have including the rises of the gunport sills forward and aft. Problem totally resolved while I was working on rabbets with my new carving tools from Mikhail.
So I'll have to add this to the pile of ones I owe you
- mtaylor, popeye the sailor, Rick01 and 1 other
- 4
9 minutes ago, Rick01 said:
I agree that the gunwales from the exterior look perfect on your kit - but as you say when looking at the interior view it seems there is a problem. Not sure if it's the photo but the first gun port seems completely square whereas I'd expect the top and bottom to be angled to match the deck. It's almost as if the deck itself doesn't follow the correct line even though it is pretty obviously correctly fitted. Got me puzzled at the moment as I can't find any faults in your construction. Perhaps looking up a recent build of this cutter and asking the builder if they'd be prepared to measure the various areas - gunwale height, gunports above deck etc. may throw some light on this. Like you I can't envisage gunport heights from deck varying and I'd be tempted to mock up a cannon to see how it sits in each of the ports. I'm off to look at my plans now and see if I can see how this may have happened as I'm totally puzzled at the moment!
Rick
Thanks Rick, unfortunately that's where I am too. I just dropped a note to Amati requesting contact with the designer or someone equally familiar. Will see if they respond.
3 hours ago, Rick01 said:
OK here's mine (excuse the photo quality - not something I'm good at). Height form deck to top of gunwales 12mm, height of planking above gun port 2mm. If the ports are that far out I'd plank the inside from the deck up to get the correct curvature then re-cut the ports as parallelograms measuring 7mm x 7mm approx. Really sounds as if the original laser cut went very wrong!
Hope this makes sense.
Rick
Thanks for the pics, and it looks very good BTW
The only thing is that even looking carefully at your pics I can't see where the difference is. Please look at my pics, maybe you will have better luck. For now I guess I'm going to cut the second rabbets until we figure out what is going on here.
And for what it's worth, I'm just using my cell camera even though I have a fancy Olympus, and it's not even particularly new, it's a Samsung S4 since none of the newer ones do anything I need much better. Except for the new Google phone, I read a review on a camera site that said its camera was superior even to the latest Apple cameras, very near full DSLR quality. So I was thinking about getting one.
I do know that my cell cam only works well with very bright light, you should be able to tell my task light is never very far out of frame just above the model when shooting. In normal light autofocus is spotty and the pics are noisy, but I can fix the noise pretty easily with a fancy noise-reduction add-on for Photoshop that I have. All I do in Photoshop with these though is crop and save as a lower-quality jpg to retain the high resolution but get under the 2mb barrier.
But I am also a fully-qualified graphics guy who long ago worked in the games industry as an artist, I've done 100% of the graphics for my Line of Battle game. So if you need pics fixed I can fix 'em
And here's a pic from the bow - it looks like the gunwales very intentionally rise toward the bow, and it doesn't look wrong it looks pretty logical. So at the moment it looks like I've done what the kit intended - we know the deck line was also dead on the bulkhead tops so that line is what they intended. But I have gunports that vary in height from the deck, the gunwale sheer line is more pronounced than the deck line, and the gunports follow that line instead of the deck.
- mtaylor, Canute and popeye the sailor
- 3
Ok here's mine now from the inside. Height of gunwales at the bow is 14.72mm, midships is 12.8mm.
You can see the bow gunport is higher off the deck than the midships ports and they begin to rise again on the stern. The gunwale/bulkhead sheer is more pronounced than that of the deck. The thing is I can't see where it's wrong, once the top line was straightened you see it makes a continuous smooth curve with the gunports following it exactly.
Also the tops of the gunwales are now closely matching the tops of the bulkhead tabs, which also makes it look as intended. And another is you saw I made my bow stem piece as a dead copy of the original, and these gunwale strips fit perfectly, that was how I established how much the lower edge was supposed to overhang on the bulkheads for gluing.
Can you see where the problem is?
- popeye the sailor, Canute and mtaylor
- 3
I only have one pic at the moment, will go take a couple more. If what you're saying is how it's supposed to be, I have major problems, because the curve followed by the gunports is significantly different than the curve of the deck.
This is what I ended up with after straightening the bulkhead top line, all the ports are an equal height from the top of the rail. The ripples looked like deviations from this line.
- Canute, mtaylor and popeye the sailor
- 3
Another thing I'm guessing on, the height of the bulkheads vary from bow to midships and to stern. Either I have to use three full width planks with stealers bow and stern or four reduced planks with the top one varying quite a bit in width. And should inner bulkhead planking follow deck sheer or rail sheer? And why in God's name would the height of a gunport change from bow to stern? They seem to follow the rail sheer and it's going to change the field of fire of the bow and stern guns.
Thanks Mark, I guess that means there's no consistency between hull plank lengths across RN ships. Cheerful as mentioned shows a consistent plank length across the ship and if the RN made lengths consistent across each ship, I guess they decided the plank length on a ship by ship basis?
So this will cover the fix to the lack of symmetry in the lower counter that needed to be fixed prior to planking it and the planking.
That started with resawing more holly off the 1" turning blank.
Just enough extra to flatten with some plane passes before sanding to final thickness.
I was about to start cutting planks when I saw how assymetric the two sides of the lower counter were, so I put down the holly and as mentioned above, the worst part was I would have to build one side up, not cut one down. So I made a pattern, first soaking the area of short grain with thin supper glue and covering with with some as well so it wouldn't snap off during shaping.
Bad angle here not clearly showing how much shorter it was than the pattern, and also it would need to be filled in well onto the fuselage to replicate the other side.
And this was also a fun part- it would have been easy of course to use filler and be done in 10 minutes, but this will be a high-tension glue spot for the final planking, and filler isn't a good substrate for that, so I had to make a wood piece, and that wasn't easy since the surface being glued to was curving in all directions and the wood piece had to cover a convex and a concave curve.
I filled the remaining area with other wood pieces and also some poor-man's particle board that was wood chips mixed with CA. I then started working it down to the right size.
OTOH, a little bit of filler between two solid glue points is fine.
And eventually with lots of file and sandpaper work I brought it down to intended size and now these two sides are much closer. I stopped here as the final shaping should occur after the planking is in place.
So, on to planking.
Here I decided it was a good point to stsrt cleaning up the rudder post, so I did so with 120g, removing all dings and getting the sanding scratches at least going in the right direction. Once that was done I taped it over before proceeding, and here we are near the end of the planking.
As you can see, I turned the last pieces 90 degrees, and scarphed them into the previous pieces as it seemed like something they would do in this case, and I'm test fitting the final piece.
Once that was in place it was time to sand and shape the planks down to the lower counter, and then do some final shaping on the lower counter.
After careful work, planking and hull are continuous and sufficiently symmetric to pass muster.
And now need to level and sand that planking so we taped over the previous planking to protect it as well. Once again I used my little scraper to first level the planking.
And then sanded down and the lower tape removed again.
Finally, that joint between lower counter and fascia looked like something that would have been reinforced, so I added to pieces beveled in out of boxwood planking, and dyed it black for contrast. These needed to go on now, and I'll just have to do my best to tape them over and protect them as much as possible during final planking and sanding of the counter and fascia.
16 hours ago, Rick01 said:
I'll follow your 2nd planking with interest as I'm starting a scratch build of a local ship shortly ( topsail schooner Enterprize out of Hobart) and may just try shorter length planks. By the way we may have a little problem in a weeks time. I'm heading up country to Mildura and Lake Mungo so may not be as well off for internet connection - you may well be on your own for a few days but I do think we've covered most of the harder problems that may occur. Sorry can't change my plans as this was arranged before we started on this voyage but I'm sure you'll cope.
Rick
You mean you won't change your travel plans to support a guy you've never met build a model?? MONSTER!
I very much appreciate the help Rick but no apologies are necessary, I will just move ahead and blame you for anything bad that happens
Thanks Mark! I am confused by the first paragraph- did you mean that only the 13" width wouldn't be closely adhered to in unrated ships, or that both the length and width would vary more? Unless I'm well off, 24' seems longer than Chuck is using and I trust he has extremely good reasons for using those lengths.
I'd always wondered about those 30 ships as I'd read it being attributed to using green wood and that made little sense to me- I'd think that would result in all sorts of internal stresses and poor-fitting joints but not full-out rotting. Thanks for explaining.
4 hours ago, Rick01 said:
That's a question that I've never really considered. What constitutes "proper length" with a cutter? I'd have thought that a 50 ft plank wouldn't have been out of the ordinary during the 18th century. This one is a question for someone like Chuck or someone with more historical knowledge than me. I'd suggest asking it in the Building Framing, Planking section. Don't know that it would be harder - manoeuvring shorter lengths would make life easier in some aspects.
Rick
Good suggestion, I replied to a topic that has the info I was looking for but for French ships. Cheerful seems to use 15'-20' planks.
A little late but thanks for that, Gerard! Another important data point for French ships to go along with your information on French deck planking practices (and plank length) in Mark's Licorne project thread.
Chuck or someone else knowledgeable, what were the RN hull plank length constraints in the Napoleonic period? As below I am building the "Lady Nelson" cutter, so I was hoping to find information in Chuck's Cheerful instructions since he uses planks that look like maybe 15'-20', but there wasn't any discussion of the rules that I saw, just tells the modeler to cut the planks according to the plan. I'll assume Chuck's skip order is correct. But instead of just copying his lengths, I'd like to know what the constraints and considerations were and if there were practices like Gerard mentions with shorter planks at the bow and stern and long planks midships.
Also it is interesting that besides having uniform plank lengths on Cheerful vs. French practice, they also all seem to be below the minimum length acceptable for French ships.
Ditto congrats on closing in the milestone, she looks great.
Had another mostly spinning wheels evening when I realized not only was my stern not particularly symmetric, but that it was there before I planked it. Still shrugging at how I seemingly am endlessly checking symmetry only to see things like this staring me in the face.
The worst part is that is it was the low side that I felt was wrong, so I had the much more painful job of building one side up rather than cutting one down. I'll post pics tomorrow, but let's say we need to get moving on the final planking because the stern sure is ugly right now. It's the right shape, but it's so ugly that a little boy who saw it ran out the door screaming "BAD BOAT! BAD BOAT!!" and I haven't seen him since. Still wondering how that kid got in here in the first place.
Of course it's all extremely helpful Rick, already would have run face first into several other walls without you pointing them out. Yes, there will be considerable thinking before placing any furniture, as you point out if there's a pattern I ain't seeing it. And thanks I will check out the cleats as well
1 hour ago, Rick01 said:
Don't forget to watch out for the problem with the "wobble" in one of the gunwales you found earlier on!
Rick
Good point, need to go address that, and thanks you are admirably fulfilling your role today It wasn't in just one, it was in both and that's what made me wonder whether it was intentional. You see one drunk guy staggering about that's one thing, you see two doing it in exact unison and you suspect something else is up.
Rick, I sincerely hope you didn't quote that part number off the top of your head, if so you need help even more than me And thanks, I will go look.
Yes I'm going to remove those bulkhead tabs now and plank the inner bulkhead surface first to get used to the harder boxwood, as of now that will be painted red so I could make some mistakes.
I haven't decided on continuous vs. leaving openings, probably the former as these are basically straight. If it were a trickier area with bending and twisting I'd be more inclined to use separate planks to separate those factors as much as possible into individual planks.
Tony, I was going back over the photos of cutters you provided. The things I need to think about that I came away with were:
- Deck furniture issues with the boom pin rail and windlass and position of pretty much everything, the first model showing the companionway forward under the boom and facing aft with different grate/light positions. One question here is the second model showed 3 additional hand-cranked small windlasses, what are those and were they common?
- Topmast forward of the mainmast.
- Two sets of braces for main and top square sails. Only I don't understand why there are two sets, why not just run them forward to keep them clear of the spanker boom? Seems overly complicated to run them to two places.
Am I missing anything else important?
Glad you guys liked the holly idea, as I went ahead with it
Yes Pat, usually oils of some kind reacting with the alcohol carrier of the dye stain. And if alcohol reacts water probably will too, and that's the other option for aniline dyes, but I have never quite grasped the concept of a grain-raising stain so I have always stayed away.
In the end natural is probably best, but if anyone following has any ideas boxwood stain options, please let me know, I still would like to see a light brown.
Rick, being 137% responsible means also being responsible for ensuring I've read your advice It's a tough gig.
I thought single piece didn't make much sense either, see below. I'm not quite sure what you mean about the cap rail but at least I'll remember I have something to figure out with planking thickness on the bulkheads and the cap rail. The planking stock says 4mm x 1mm, it looked thinner at first. I haven't checked it yet but width is 4.08 - 4.10mm so I assume it's very slightly oversize. Edges are also straight and clean enough to make planking joints as is. This was my first order from Crown Timber but it looks like Jason takes his business very seriously.
So I took my holly piece above and machined in the tiller opening. My red paint has collected dings, will need to touch up.
I frequently use my digital caliper as a marking gauge, it has sharp and fully hardened steel jaws after all. Instead of cutting planks and trying to cut in the tiller operning once installed, I cut the opening first and then cut them into planks as it seemed way easier.
Or I will just walk it across the piece. Each time you move it you carefully and gently register the rear one in the mark you just made so you don't mar it, and immediately roll forward and put some pressure to make the next mark. If you practice you can get very accurate.
I cut off the first two planks, but only scored this one. Because, you know, it's holding the rest together and I want those lines to be straight too.
Once I had the cuts done I marked half of them to be flipped to the other side. Although holly has hardly any grain, it still will help to make it look like a series of individual planks rather than all cut in order from the same piece.
As I cut them apart, I used the piece to mark the plank layout on the fascia.
No pics here, but once I had everything laid out of course, random alignment check 12 zillion and eight found that the fascia was not as flat or as square as I remember it being. So there's about 40 minutes of knife and mini sanding block work in here first getting the fascia fully flat vertically and then relieving the port side so both sides had an equal slight curve.
Once that was done, on with gluing.
Basically cleaned up. I used my little baby scraper that I posted over in my tools thread to level out the planking, just like the big ones they can be highly precise tools if sharpened and burnished correctly.
And completely done with inner tiller opening filled with CA and sanded down and painted. I'll do the lower tomorrow before moving on to the hull planking. Also I need to get the counter out and get that joint right too, as you see the top of the fascia has a slight cant. I made sure the fascia planking was square to the keel so it's right, the top curve is currently wrong.
Rick is there anything else I should do before planking the hull? Not seeing anything.
I spent almost all last evening thrashing around trying to make final decisions on wood colors. I experimented with a whole series of browns and yellows on the boxwood final planking, and mostly found out that boxwood does NOT like dye stains, the results were consistently badly blotchy with no correspondence to surface quality - i.e. I'd sanded the whole plank carefully just to avoid rough spot blotchiness. So this is chemistry somehow. There are things you can try to do to make wood behave for staining, conditioners and the like, but not worth the risk to me as they don't always work.
I don't really like pigment stains as no matter what they partially obscure the underlying grain and wood, but if someone has recommendations for boxwood, I'm listening. My original thought was a lighter than cocobolo milk chocalaty color for the lower planking. Crap now I want chocolate milk. So it wouldn't have to be a very dark stain.
Assuming nothing works there, that leaves me two choices for the final planking, the natural yellow of the boxwood or black; the blotchiness goes away if you stain it very dark brown or black. And it's a nice look, black with none of the surface character of the wood hidden by a layer of paint. So plan B color scheme is black lower planking (it's a reddish black too, works with cocobolo) with or without painting the bottom white (haven't decided on that either), natural boxwood along the bulkhead gunports, then back to black for the top rail.
There is boxwood stock for all the masts so I can blacken the yards the same way and have the mast natural.
But as mentioned, if anyone has a good light brown pigment stain for boxwood, I'd still like to look at that option.
Anyway here is the cocobolo with a mild red/brown stain to bring out its color and the boxwood planking in black and "white".
I also have a small problem in that I thought the outside of the stern fascia piece was planked, and RICK WHO IS 137% RESPONSIBLE FOR PROTECTING ME FROM DOING SOMETHING STUPID LIKE THAT ( ) didn't say anything, so now I have a supposedly finished surface with paint and dings.
So I need to cover that too. I could do it with the boxwood but I was considering using holly for the lower two stern surfaces while having the counter black. I'm pretty sure that will either look really good or really bad, but I'm not sure which. I'm soliciting opinions here too.
Gave me an excuse to resaw one of my holly pieces, had them a while but never had a reason to use any. Holly looks all sweet and innocent sitting there, but take a saw blade to it and it instantly goes full-on nightmare beast. This is another advertisement for the Excalibur 16 scroll saw, with a new 12.5 TPI skip-tooth blade it was possible to resaw it accurately.
And I thinned it down quite a bit with various small planes as the fascia piece at least just needs a veneer-thickness cover.
And I need to try carving this, the detail possible would be really excellent.
- popeye the sailor, Elijah, Canute and 3 others
- 6
Looks pretty good Vossie, the second layer has a very good base. It seems you have tamed the beast
cheers
Pat
No, I have reached the standoff phase where he's not shredding me to pieces while giggling, but I haven't even brought the saddle out of the house yet. Until then he's waiting for me to lose focus for one second
Lady Nelson by vossiewulf - Amati/Victory Models - 1:64
Ok, will look there, and glad I can contribute to your overall health I will go look at Chuck's post. I mean I assume Chuck is totally accurate about what he's doing, I'd just like to know what the rules and constraints were.
The tools are phenomenal. I have many fairly expensive edge tools from traditions all over, US of course and Swedish and German and Japanese, lots of Japanese tools. These are as good as any made anywhere. And he's selling them for about 1/3 what they're worth, you could make a reasonable living buying tools from Mikhail and selling them on Ebay with a 200% markup.
