Posts posted by vossiewulf
I can tell you how to do those things... in Photoshop. Never used GIMP actively.
While you are at it you need to understand the basic path modes - you need to be able to add one path to another, subtract a path from another, and last is leave only the intersection between two paths. Along with the path drawing functions those allow you to create about any shape with reasonable efficiency.
I will say don't limit yourself on layers. Anything which you might want to change in isolation should be on its own layer. And GIMP has to have a layer grouping function.
My UI design files will have hundreds of layers grouped in various ways, like all the elements that make up a button is one group, and that group is part of a bigger group that contains everything that goes on one dialog.
Equally important is naming convention for layers. Don't use something arbitrary. Use something that makes sense and that tells you clearly what that layer is and what it's a part of.
- EJ_L, mtaylor and Hubac's Historian
3
So finally got to sit down and work on this again. And found what I had carefully done before was not right, at least the wales position wasn't and I had to undo some of the work before redoing the wales location and then being able to move forward again.
Rick, I'm going back to my original planking plan, I can only assume the mid-aft section of this ship is distinctly different the Cheerful hull. First thing I did was lay out the garboard and the next plank straight as you pointed out was done with Cheerful. The garboard was very carefully laid out using dividers to ensure the correct .160" width the whole way to the stern. What looks like a bend is where it does the 60-70 degree twist.
But it don't look too good.
It doesn't look straight, it looks like I have a severe downward turn. This hull, or at least in the way I have it, seems to want to do what I originally had. But I'm also not sure if garboards were permitted to leave the keel and have a stealer complete the run. That sounds wrong too.
Also I was going a bit crazy trying to get the wales locations to work correctly, I was measuring from the plans and I wasn't getting fair lines when I looked down the length. So I did the same thing on the plans. That'll teach me not to blindly accept plans even from supposedly good companies.
- Canute, mtaylor and popeye the sailor
3
I hope that was a not quite done pic of the horizontal stabilizer? As it's missing some reinforcing ribs on the elevator.
This shows the ribs in the correct locations but the curve on the elevator tips is wrong on both versions, F.1 on the left and Dr.I on the right.
And here's the first Dr.I model ever, made in the Fokker factory in 1917. Note the curve of the elevator tips and the elevator ribs.
- Nirvana, hexnut, aviaamator and 10 others
13
Oh by the way, both of those carvings are beautiful and I'm not sure how either was done, particularly the driftwood one. On the horse, the guy must have used wire wheels across the grain to make the wave pattern and then clean with sandpaper.
Thank you very much Alexander, scratching boxwood off my list and will look for apple. I can get Swiss pear. I also am going to try the holly, the pieces I have are very white when cut and has almost invisible grain, it's the closest wood gets to white marble. It seems to cut smoothly in what I've done with it so far, I would be tempted to do a copy of Michelango's David statue in this wood
You don't like basswood because it's too soft, right? I also think it's softer than optimal but I'm perfectly comfortable using it as I have with all the chip carving. In fact my standard of sharpening is that it has to be sharp enough to cleanly carve basswood before it's done.
I make these testing edges while sharpening. The rules of the game are 1) totally clean cuts, 2) minimal connection between pieces. The second one doesn't have much to do with edge sharpness and more to do with me being competitive with myself.
Here is the next one starting for the next sharpening session.
And ok, I agree on the larger sizes too. Sometimes hard here to find 2" thick stock that isn't super expensive, but I will do some looking in lathe wood suppliers.
- WackoWolf, Richard Griffith, druxey and 5 others
8
I always thought one of those would look awesome half and half, only half covered. But I also think it would be pretty challenging to keep everything straight if you do that. If you think you can control the differential stresses, think about that method as it would look pretty cool.
- WackoWolf, mtaylor, thibaultron and 4 others
7
Great! I'm glad it sounds like it should work to you also. I don't have any brass in the right size, I need like 2cm x 4-5cm x 2.5cm. I think I have steel dowel pins in the right size for the ball bearings. I'll also find a good brass screw that won't mark the steel of the tools.
I need to make some progress on my ship but I'll work in some time on this also, I'm using Mikhail's tools regularly so I want a good sharpening solution in hand soon.
By the way, in following my thesis, you missed a question I had up there about typical sizes for wood for this type of carving
See the post between the one with photos of other jigs and the post that has my design. I want to order some wood and I'd very much appreciate your advice on sizes.
- korablik1979 and mtaylor
2
Maybe something like this. The disadvantage is we are not registering off the flat back of some of the tools, but the advantage is that I think maybe this will work for literally everything but the angled cutters (skew chisels). If I drill and ream the hole to .111" that would be .001" over the round tap dimension and therefore we could turn the tool by hand.
Although there is some space to be seen between the tool handle ferrule and the jig, the idea is that ferrule sets the correct angle for grinding the straight cutters (chisels) and the semi circle cutters (gouges). We prevent the chisels from rotating with the screw, the gouges turn freely and we'll have to keep forward pressure to maintain the angle.
I'm largely certain this will also work for the the spoon cutters as well, which surprised me. On the spoon tools, Mikhail has ground them such that the cutting edge is a radius centered on the tap center and therefore can be sharpened accurately by turning along their length. The only difference is they will not extend as far from the jig to account for their grind angle and will require a spacer, maybe one for each tool, so the brass handle ferrule can still set the correct angle.
May get the skew chisels with the same jig if we drill holes 45 degrees right and left of the central straight hole. I'll have to look at the geometry.
Oh the second ball bearing that is transparent is where I thought one would need to be to behind the tool's center of gravity (CG) and therefore naturally cause the jig to fall forward on the tool cutting edge. Actually that's not right, the jig itself is falling forward and it will have a reasonable mass. I will just have to see where the CG is when the tool is attached to the jig.
- WackoWolf, korablik1979, mtaylor and 1 other
4
Alexander, what are the typical rough sizes of the pieces? I need to buy some wood if I'm ever going to do some carving with these, and my collection mostly consists of furniture hardwoods and exotics and basswood, I don't have any thicker pieces of boxwood or pear, although I do have some holly that seems to carve well. Have you tried holly?
Anyway, what are the typical stock sizes? 3cm x 3cm? Bigger?
- John Allen, korablik1979, Canute and 1 other
4
Thank you Alexander, I think I followed that, and I will try it - I mean the making of eyes. I understand what you mean about no protrusion of the lower edge of the semicircle gouges.
Below are some photos of various jigs for sharpening gravers. These are what I have been looking at while thinking about making jigs for Mikhail's tools. As you see, a jig for the straight chisels should be very simple. With a little added complexity, it could handle the straight and skew chisels. This is what I intend to make first, I have some 1/4" ball bearings sitting around that are a good size.
For the semicircular gouges, I am still thinking. Basically the idea is that the jig axle and the piece that holds the gouge are geared together such that as the jig rolls forward, the piece that is holding the gouge turns along its long axis. I think that will work but I'm not completely sure.
This is the "Crocker Pattern" graver sharpener. They are made by many companies. I don't think they'll work without significant modification or making Mikhail's tools separate from the handles.
This is a Bergeon 2461, not expensive, I ordered one to try it. It's for sharpening screwdrivers.
This is a Bergeon 2462 graver sharpener, fairly expensive for what it is, not sure if I will try it.
All brass version.
This is a very cheap graver sharpener you can find all over EBay and any jewelry or watch making supply companies.
This is one guy's home-made jig. I like it.
Another home-made jig. More sturdy but only good for one sharpening angle.
And a seriously cheap and easy home-made jig
- Jorge Diaz O, mtaylor, WackoWolf and 3 others
6
For the straight and skew chisels a graver sharpening fixture will work to maintain the correct geometry, gravers are sharpened with flat bevels like we want on our chisels.
But as you see they're expensive and they don't address sharpening of the U-shaped gouges.
So I have been designing a jig in my head for the gouges, and a different jig for the chisels. The one for the chisels is pretty simple, the one for the gouges is not simple as what I want to do is have the tool rotate along its long axis while the jig moves forward on the sharpening stone so the entire edge is sharpened equally.
I'll get a prototype going and show it to you once it's working.
Although English clearly isn't your native language, you are perfectly understandable, so don't underestimate your English. As I said, I think it is a very hard language to learn and you've already reached a point where you can discuss complex subjects successfully, so you are doing well.
That ship is also amazing, do you have a link to the project? I'd love to see the progress on it.
Speaking on engraving, have you looked at engraving blocks to hold your work when you are carving? It seems to be a perfect tool for the purpose, I have a GRS block and intend to use it for carving- it can be locked so it doesn't move, and you can also unlock it and easily move the work around to any orientation you need. In fact if you look at my build log, I have been using my engraving block to hold the entire ship - the block weighs about 15lbs, it's filled with lead, so it can be used to work and relatively large objects. Here's a video of one in use.
And I agree about tool handles, anyone who is serious about the work will eventually make handles that fit them and the type of work they do. The only reason I want pencil-type handles is for wood joint work on my ship, sometimes the teardrop shaped handle is too big, I also want something narrow that can fit into tight corners.
2 hours ago, popeye the sailor said:
thanks Russ
at the moment I'm planking the main deck. I'm using 0.5 x 3 mm blonde {koto, obetchi, or basswood.....anyone's guess}.....and wouldn't you know it, the edges are rough. so, I'm having to sand the edges of every strip I use. fun like this should be outlawed! but all 'n all.......it's going fairly well. pictures soon. thanks for the good word
so........nothing on the hold covers? I could do a test piece and show you what I want to do....see if it's OK. although....as I recall, Cyril's model had something like that on his. I'm sure his model is a larger scale than what I'm working with. I just checked, and his model is 1/8" to 1'.........not sure of the scale.
Clamp 20 of them together like a book and sand all the edges on one side at once on a nice flat surface! Then reclamp and do the other side. Doing them one by one would be very annoying. I'd use a piece of 3/4" with a rabbet cut into it to hold 20 or so pieces with them just proud of the surface, then split that in half on my table saw and drill and install telescoping brass rod and tube so they can slide. Put pieces in, clamp with c-clamps.
First Alexander, good luck on learning English. In some ways I think it's about the worst of the choices for the international language. First, it's actually three languages merged, old English and old Norse and the language of the Normans, plus a considerable number of words from Latin. And if you compare English and Spanish, English has approximately three times the words Spanish has. And it has more exceptions to the rules than any language I'm aware of and pronunciation that makes pretty much zero sense. So good luck
Your work as usual is beautiful! We call that traditional acanthus patterns, based on a Mediterranean plant called acanthus. Here is a good example.
Also, Gaetan's next project is a 1:24 scale 74 gun French ship. It's going to be HUGE, close to 3 meters when finished. Make sure you follow his progress, it's amazing.
I have yet to start actually carving with them, but I am using Mikhail's tools daily working on my ship. I've been telling people to not think of them only as tools for carving, but the best micro tools for making small wood joints on ships. They're a real joy to use.
For example, try finding another tool that could cut a planking rabbet like in the image below. Of course it makes more sense to cut that rabbet before the stem piece is attached to the ship, but the kit doesn't call for a rabbet here and I didn't think of cutting one until I received Mikhail's tools. And the wood of the stem piece is cocobolo, not at all easy to carve.
I am considering taking them to my lathe though and remove the handle, leaving just enough wood for a threaded insert. I could then switch between the palm and pencil type handles depending on application. I also wish Mikhail would make it possible to completely remove the tool from the handle, like gravers used for engraving. I am trying to design a sharpening jig for the straight and skew chisels, and it would be much easier if there was no handle on the tools at the time we sharpen.
- John Allen, SimonV, korablik1979 and 4 others
7
They're usually sold to woodworkers as a group with raw sienna and burnt sienna and burnt umber and black, basically red brown and green brown and black. But you can get them in all colors, see Highland Woodworking.
I now wish I'd mentioned that as you've found out, the only valid test of a filler color is dried
And if at all possible you use test pieces off the main work. People will also say test in a small corner but if you use a small unnoticed corner chances are it's hard enough to see that your judgment of the color is going to involve a degree of luck.
You can get the color you need with universal tints, guitar makers use them every day, as long as your filler is considerably lighter than the color you need so you can add more filler if you go too dark.
7 hours ago, usedtosail said:
Sorry vossie, if I didn't have a whole ship load of rigging to do on my own model, I'd take you up on the offer. I do love soda and chips, though. I have a sister that lives on the other side of the Bay that I could visit too. Maybe see the birthplace of my hero, Tom Brady while in your town. Humm, then there is always a side trip to Napa. Clos Pegase and St. Clement are two of my favorites. This could be fun...
There ya go, win-win for everyone! And it was about 80 outside yesterday
Back in reality, very nice progress and she looks great.
- usedtosail and Jack12477
2
Rick, that sounds correct, it wouldn't surprise me at all if stern names were reserved for 6th rates and up. But this might be one case where I intentionally deviate from reality, as a display object for the average viewer having the name on the counter seems right. But I haven't decided for certain.
Sailor, that's actually an interesting idea, I'll keep that in mind
Popeye, pretty sure I have some extra cooling jackets, they'd be a tad big though, and thanks for the well wishes. I actually pinged PPD and told them they should advertise here, really surprised they don't already, this forum is chock full of likely customers.
- mtaylor, popeye the sailor and Canute
3
BTW, I'm thinking of making this something other than Lady Nelson. I need to go look on Threedecks.org for a cutter of the right time period and size.
There's a company called PPD Limited in Scotland that will do one-off custom photoetch for about $50 delivered to me, and the sheet is large enough that I could do the artwork and get the brass for a number of ship names that would fit the kit part. I would then be open to sending the unused ones to people building. I had them make me 1/12th scale Spandau cooling jackets a couple years ago, was very easy, I made the artwork, emailed it to them, had brass in my hands in a couple weeks, I think I fit like 12 on the smallest sheet they do. Barrel is just a rod, front piece was cast resin.
And if folks here don't know about this company, they should. If you don't have Photoshop skills, not too hard to learn what's needed for this, it's actually pretty simple. Or talk/bribe someone like me into doing something, it doesn't take me terribly long unless you want to do something to simulate super-complex carving. I think I did the artwork for the cooling jackets in about an hour.
Back up on the laptop at least, and installing the basics. I'll take my desktop parts to a shop this weekend, not going to be able to do it during the day this week. And then depending on the answers I'll have some level of shopping to do, and earliest I could start the rebuild is probably the following weekend. So I should be able to get back into the ship workshop and make some progress.
That's assuming, of course, that like my leg doesn't arbitrarily fall off while I'm cooking an omelet or something. I intend to remain fully in a combat stance for the time being, other shoes keep dropping and I'm not sure it's over. That's going to be my new phrase for this kind of thing, it's been raining shoes
The encoding from MSW may be causing an issue. However that's hardly a mainstream file type regularly used, so I'd be happy I was getting it to work at all.
- EJ_L, Hubac's Historian and mtaylor
3
Hey Tom can you come over and do the rigging for my LN? I think you could knock it out in an afternoon. I'll totally pay for the soda and chips
Another one, make sure the bearding lines established by the lower parts of your filler blocks are exactly symmetric and the bulkheads on both sides end the exact same distance from the keel. When I went to cut the rabbet for the first planking I found my two bearding lines looked good but didn't agree in places up to 1/32" and that would have been replicated to the planking and the finished model.
I didn't do this, but if you want to be sure of hull symmetry you can use paper strips, cut one and make it follow one of the bulkhead sides and cut it to the exact length of one side, then lay it on the other side of the bulkhead; if they match you're good.
Lady Nelson by vossiewulf - Amati/Victory Models - 1:64
Ok, thanks Rick. I will go draw a couple more and see what it looks like. But elegant is not one of the words that comes to mind at the moment.
