barkeater
Everything posted by barkeater
  1. If you want to do a round top, from Lees "Masting and Rigging" Appendix I "When round tops were carried the following were the proportionate widths of the bottom of the tops based on the length of their respective topmasts: Main 0.28, Fore 0.29, Mizen 0.27 and Sprit 0.4." Hope this helps. Rich
  2. Bill I was not quite sure what you were referring to at first. The picture is from Biddlecombe's The Art of Rigging. I don't do beckets to connect the block to a line. I will form a loop when attaching to an eye or hook doubling up the line after it has run through the eye and seize both the going and coming portions together. I work in 1/48 scale with my single blocks measuring 2x2x3.5mm. In forming a loop to attach to a line, I'd have to form the loop around something the diameter of spaghetti for scale and you really would not be able notice it unless you used magnification. I try to put as much detail into my work as possible but for me, putting in a becket for a block to line attachment just doesn't seem to be worth the added time, effort and aggravation. I attach the line (example: yard lift) to the block continuing the end of the line around the block as the stropping and then seize it to the line as I described earlier. Rich
  3. Bill I use thread for stropping my blocks. I make my blocks with a groove to fit the thread Then I serve or secure the two ends using smaller thread (fly tying thread works well) with multiple overhand knots (5-7) and then hit the knot and the stropping block thread lying in the groove with thinned pva (wood glue). I the snip one of the two ends. The other end is your rigging line, or you can attach to an eye bolt, hook or whatever. When a block is part of the chains, I use silver wire which I mold around the block to the correct shape then remove the wood block, silver solder and blacken with brass black. Rich
  4. I've looked at the picture again. The shading noted comes from the wood and not the rim so therefore it is perfectly consistent with the hoops being empty. The different shading, I think is a draftsman's color key to either these being on an inner row, as they overlap with adjacent deadeyes, or denoting that they were not functioning as deadeyes with the standing rigging. The inboard structures are depicted in red as a color code. Also, they are depicted as having a strip of metal rather than chains. There is one in the mizzen chains which is identical except smaller. Why would the draftsman render them one way and then have to come back, erase the metal strip and then redraw with chains? If he did not finish them, you would see chains. I do agree that the edges of the wales do not extend through and can't fully explain this. It could possibly be that they used stamps to indicate deadeyes and similar structures on the draft and this did not allow for a see through. Not sure if or how stamps were used but it makes sense that they would be. Or it could be that they had a flat piece of wood in them, but this would render them useless. If empty they could be used for belaying or in hauling lines. Richard
  5. Druxey, Thanks. I would never have guessed that they were metal rings with an empty center. Do you have any idea of their use? They are bolted to the ship so it looks like they were meant to take a line. Richard
  6. Well done Druxey. She did have 32 canons however she also carried 4 carronades on the foredeck. Richard
  7. The vessel is the Unite built 1787 and those plans are the "as taken". She was French built and then captured by the British. She was refitted with alterations and relaunched retaining her name. She carried Admiral Nelson to the Mediterranean to take over command of that fleet. I am building her according to the British retrofit plans wherever changes are shown however the chains are only shown on the pre refitting plans so I'm going with them. She was rated as a 36 gun ship by the British. Plans are from the British Maritime Museum. Richard
  8. Need a little help. While there are deadeyes and sheaves illustrated, there are also rounded shapes like deadeyes but they are not pierced so they could not be used as such. Also their strapping is different. Does anyone know their use? Have tried to look them up in various books but can find nothing.
  9. Microfiles (flat) work well for squaring up the cap. Agree, that if you are starting with a square and then tapering to a round, your cap has to be cut down to be smaller than the tapered mast so it does not get you out of cutting it down. If you start with a square piece, just round it, taper and then square up your cap. Alternatively, you could just taper a dowel but just be sure it is straight and not warped before you start. Richard
  10. Wood putty from your local hardware store would be fine. Just be sure that your gaps are not to big as your want to glue your second planking to wood and not putty which does not have the holding strength. Also sand well so you have a smooth surface without bumps or ridges. Richard
  11. As an alternative, this anchor was made out of ebony and shows the puddening. Richard
  12. Are you heat bending your planks. If not then that might be your solution. I don't use cyanoacrylate just white (carpenters glue). CA I'd bet is causing your quick drying time. Richard
  13. I'm sorry but I have no experience with plastic ship modeling. Hopefully someone can answer your questions. I would think you would install the deck before priming and paint your cleats and other items before attaching but these are only guesses. Richard
  14. Which vessel/ kit? You'll get better answers if we know exactly what kit you're asking about. Richard
  15. If you are talking about tapering a hull plank, then yes. Also put the tapered edge against the already done course of planks and leave the unshaved plank free. Doing it this way lets you know if your taper is clean of bumps or dips rather than find out that you need to redo or touch up the shaved edge after you've glued it in place. Richard
  16. The trick for me is holding (mashing) it down with a probe angled across the coil while I make the next coil with another probe or tweezer. You have to keep pressure on all the time then hit with a drop of the pva and put a weight on top until it dries. Also there was a thread awhile back on making a jig out of wood which you should be able to find. Richard
  17. Grant, I agree with Henry on the use of fly-tying thread for your seizing's if that is what you are asking. It comes in many colors so matching your line should be no problem. Size 6/0 should work in most cases. I work in 1/48 scale. What scale are you in? I seize by making a loop of my seizing thread, passing the thread through the loop 3 times and snugging it down. Then I do a double loop and snug it down and finally an additional double loop and snug it down. These have all been laid touching one another but not overlapping. Then I hit them with a 50% pva to water solution, let it dry and snip my loose end. The results look good simulating the 7-9 turns Henry noted, and you do not add any significant bulk to ruin the outline. Richard
  18. Welcome aboard. Richard
  19. Thanks for posting the pictures. I'm a little further from Portsmouth. 😁 Richard
  20. I'll second the scroll saw recommendation. What you can use are wood sheets. They come in about 20-24 inches in length and say 4 to6 inches in width with various thickness options (1/8, 1/4, 1/2 inches). There are many varieties of wood that you can get depending on your needs. I have used Modelers Sawmill which is one of our sponsors and was very pleased with the pear wood I got. I have also used Rockler and they are good. I have also bought wood elsewhere which was not planned evenly causing me a big headache. Strips for planking can be purchased from multiple sources. A thickness sander is great as is having a mini table saw to rip planks but if you are just starting scratch building then a scroll saw should be your first purchase. As for having somebody cut out the keel and frames, I would think that if you even found someone to do it, the cost would be prohibitive. Richard
  21. Welcome Michael from another Jersey guy. Richard
  22. "I'd only add that if your plank is properly shaped before it is offered up to the framing, use of an electric plank bender or the equivalent to apply heat to the plank at the point of attachment will speed the evaporation of the PVA's water-base and hasten the PVA's taking hold. Care must be taken not to scorch the plank face, of course" One point here. You do not want to glue a soaked or wet plank as it can shrink as it dries depending on how long you soaked it. To get the best result steam bend then let the entire plank dry before gluing. I usually glue the course I did the day before and the I'll bend the next batch once my glue is dry enough which is not long. I also trenail the batch I glued the day before so there is plenty to do and drying is not holding me up.
  23. I do not use nails in my planking as they split wood and have to be removed leaving holes. I glue either clamping or applying pressure with my fingers and then I drill and use trenails which look authentic to the period I am doing. Having said that, a #72 drill bit fits most nails fairly securely and I use them for pinning furniture and where a bolt would have been used. Also, concerning trenails, the #72 bit fits the 28 or 26 size on Byrne Machines draw knife for reference. Richard.
  24. Getting back to Lavery's Arming and Fitting. Very good purchase. I use it as a reference all the time. Richard
  25. I'm originally from the Mohawk valley/ Adirondack region and still have family there. It always drives me crazy to hear people talking about "upstate" when they are talking about a town 20 miles north of NYC.
