barkeater
Everything posted by barkeater
  1. It is difficult to work with, requiring a lot of work to bend it, and it is toxic but it looks soooo good. I use it for wales. It also is good anchors, stoves and accent pieces such as window frames. If you need to bend it, work in stages, soaking, heat bending then soaking and heating again until you get the curve you need. I leave all wood natural color without painting so I am always looking to add in different types and colors of wood to give contrast.
  2. Do all your lines to a particular mast or yard. Wrap them around their appropriate belaying pins leaving a small tail in case you have to adjust. When all lines have been placed with good tension glue using pva to the pins. Add your rope coils and your done.
  3. Excellent and fascinating work all along in your restoration. Thanks for sharing.
  4. Tough to say without seeing it but I would consider a small amount of cyanoacrylate. It will be visible so only a tiny bit.
  5. Back to the original question. If you follow the rigging as shown in Lee's book or others you should not need to use a brass rod. I would recommend Petersson's "Rigging Period Ship Models" as the book is all simplified illustrations of different lines including lifts, truss pendants, jeers, slings and pendants along with braces. There is very little if any text and no discussion of different changes over time like Lee's book but the drawings are clear and simple. Rich
  6. If you are going to stain it, do it before you add a different wood unless you are going to stain that wood too with the same stain/color. I do not stain at all but leave the wood natural color. As to varnish, varnish will give you a shiny surface. depending on what you are building this may be good or bad. I use Testores Dullcoat which is a matte finish and does not shine. For what I build I feel the dull finish is more appropriate. Take a test try on scrap if in doubt. Rich
  7. Agree that the break was a blessing in disguise. It looks much better without the bulge.
  8. Great stuff. I find it very puzzling too why on the earlier repair the preventer was run under the pin rail. Snaking it under makes no sense from an accuracy point of view and would be harder to do? From the picture it looks like there was enough clearance to run it straight to the bowsprit.
  9. Have you ever tried fly tying thread? I fly fish and starting using it on my builds. It comes in very small sizes much thinner than sowing thread. I use 6/0 and 8/0 to serve or lash lines. It comes in many colors including black and tan.
  10. Interesting that you are starting to get more background info on the model.
  11. Enjoying your work. Is there any way to use bone instead of ivory?
  12. Boat looks great. Looking forward to seeing your progression with the project.
  13. I use Elmer's carpenter wood glue. I take the piece of wood I'm matching and use a file to make saw dust onto a piece of wax paper. Then I take a tooth pick, dip it into the glue and roll it around in the dust. I then pack this into the gap with the toothpick. Then I smooth out the surface with my finger or a scalpel blade. Let it dry and sand it smooth. Rich
  14. Wow, this is a challenge to say the least. Interested to see how you will do it.
  15. I've make my own wood filler using saw dust and PVA all the time. It works great. I recommend this method over commercial fillers anywhere the area will be seen on the finished model. Because it matches the color of the wood you are using it blends right in and hides any gap well. I do use commercial filler for my first planking because this will not be seen and it is easier to just get it out of a can or tube. Rich
  16. Thank you for all your replies. The paired pumps on the side view "as refit" are different for and aft compared to one another and are different from the drawings "as taken". The "as taken" pumps are identical to one another. The unpaired one is seen only on the "as fit" deck plans. Instead of a chain pump or elm tree pump for draining the well, I think it is a hand pump for deck cleaning fed from a cistern. The following is from Lavery in "Arming and Fitting of English Ships of War 1600-1815" " A new system of supplying water for washing decks was introduced in 1770. The dockyards were ordered to 'fix a cistern in the well on board all three- and two=decked ships building, repairing and refitting" The cistern was fed with clean sea water from both sides of the vessel via copper pipe ensuring water to draw from if the ship was under sail and heeling over. The time frame fits as does the unpaired configuration. I'm going with it. Thanks again to all.
  17. The 38 gun Unite 1796 refit which I'm building was not the Surprise. She was taken as the L'Unite' and renamed Unite' after the refit. She was briefly commanded by Nelson in 1801. The plans clearly show that the pumps fore and aft the mainmast are of distinctly different types with the forward pumps being elm pumps and those aft chain pumps. I'm still lefty with the unpaired structure. It would be odd to have an unpaired chain pump or elm pump. Also the picture above of the Surprise shows carronades and on the gun deck. The Unite' carried 12 pounders on her gun deck. She did carry 4 32 pound carronades but this was on the forecastle.
  18. This is a view of the upper deck or gun deck Unite 1796 refit. The paired rounded structures aft and forward of the main mast looking at the side view (not uploaded) are chain pumps and elm pumps respectively adjacent to the main mast. My question is what is the unpaired octagonal structure. This is not shown on the lateral as the pumps are. It is also indicated on the lower deck in the floor plan but also not the lateral view. It could be for the cable compressor however this was usually situated on the undersurface of the main hatch. The quarterdeck shows paired scuttles above it and the shot locker would be adjacent to it on the orlop deck. Could it be a pass through for shot up through the lower and upper decks? I doubt it but I just can't figure it out with a degree of certainty as to what it represents on the plans. Ideas?
