barkeater
Everything posted by barkeater
  1. I'm not familiar with your kit but II built the Alert by Mamoli which was a cutter with a 360-degree rotating canon midship. If I remember correctly, it was a 4 pounder but had no special name. If you look, I'm sure you can find pictures of the Alert in the gallery to see if what you have matches. Richard
  2. Thank you all again for your input. I'm going to leave the carvings as drawn on the "as taken" plans since there is no absolute indication that they would have been removed and considerable opinion that they would have remained. Richard
  3. I have used bow string wax which is used for target or hunting bows. I don't know the ph or if there are long term issues, but it is easier to use than bees wax and it works well. It comes in a container like chapstick or lip gloss.
  4. Thank you all for the input. I also feel that it was probably removed. Still trying to decide to replace it with something or let it stay. Does anybody have an idea as to what to replace it with which would be similar in size? Richard
  5. I'm building the U'nite 1797 as refit by the British. She was a captured French vessel. I have both the "as taken" and "as refit" plans. The dockyard removed a hog back cabin and railings on the weather deck and replaced the railings which shows in the refit drawings. My question concerns the Phrygian cap and bundled sticks on the stern. Since these are symbols of the French revolution would the dockyard have removed them? The refit drawings do not show the stern. It would have been a great ruse de guerre. I also don't know what I would replace them with since I would like to keep the same approximate size. Do I go with what I know was there before the refit or make something up? I'll probably go with the Phrygian cap and bundle but I would be interested in opinions. Thanks. Richard
  6. This makes it 4 for down.
  7. Very nice. The thing about model ship building is that there are so many different tasks. Just when you've got planking down it's time for something completely different like rigging.🙂
  8. Dave, Hopefully those brass rings look like eye bolts otherwise you are going to have problems😁. You are correct, superglue (cyanoacrylate) is what you want to use gluing metal. As to breakage, I've never had a problem with kit supplied rings/ eye bolts. They may bend but unless you really use a lot of force, I can't see them breaking. For scratch building I use silver wire which is stronger than craft wire. Richard
  9. Bill The picture of the stock sheet you show is a pretty standard top which you should be able to copy. There are a lot of books on rigging if you can't find what you want for free by search. Rigging: Period Ship Models by Lennarth Petersson shows a similar top and is on Amazon in a kindle version for $11.99 ($36.70 for hardcover). There are a lot of books on rigging so look around, but I believe you could use this one to make the top you show, and it is relatively cheap. It is also a good book for other rigging details in a general fashion but does not go into changes in masting and rigging over time as some of the more voluminous and scholarly works do. Again, look around and see what you feel would be most helpful to you. Richard
  10. Welcome to MSW and enjoy. I'm a little quicker on building models but not much as I'm coming up on 4 years on my current build with years to go.
  11. Tommy, As Mark noted masts are quite a wide topic and different masts and yards show different shapes. They also changed over time. If your question is in regard to mast caps, the following illustration from Petersson's "Rigging Period Ship Models" may be helpful. Here the main mast is squared off to sit into the mast cap. The top mast is first square to sit on the trestle tree, then becomes octagonal before being rounded off to fit through the mast cap. Richard
  12. Painting them black would give you more contrast and help them stand out. Just a thought. Richard
  13. I use 5x glasses. I paid about $10 on Amazon. I like these compared to magnifying lamps because I can change my field of view without having to move the lamp. Richard
  14. Cisco, What I did was tear down and replace a shed which was attached to my barn. The barn from around 1860 is in good shape with wooden pegged construction including main beams up to 39 inches. The shed was a later add on probably 1940's and was poorly done and had no footings or foundation being built directly on the dirt. It was a tear down so I used the footprint to design the new shed with the help of an architect. I did have to get permits but by using the existing footprint there really could be no objection as long as I built to code which we did. As to lighting, you will want more than natural light as discussed above. Good luck on you workshop project. Richard
  15. Thanks for the tips. Not in the pictures are high output 4 foot shop lights in the ceiling of both rooms. In the last picture note the brightness. There is no window in this room to the outside with the only window being into the other room which itself has only one window. Without the light on, this room is very dark. I kept the windows to a minimum to give me the most bench/wall space. I moved the two floor lights from the house to get them out of the house but so far have not needed them for modelling but have used the one next to the window when tying flies as I tie a lot of micro flies. I also wear 5x glasses both tying and working on my model. As for pedal controls, I had a Fordom with foot pedal whose motor gave out after long time use. I used to carve decoys with it but don't see any use for it with the way I make models. I do have a Dremmel and a Craftsman rotary tool without foot pedal but use them infrequently. I do have a fold down bracket but use it to hang my waders. My shop vac in the sawing room is not in the picture. Since the other room is set up as a clean room where any dust creation is to be kept to a minimum I can't see cutting a hole in the wall. I do need to look into a dust trap for my sawing. Richard
  16. Might I also suggest for your reading list Bloody Mohawk by Richard Berlith which covers the Mohawk Valley and the NY frontier from before the French and Indian War through the Revolutionary War and The British are Coming by Rick Atkinson the first of a trilogy. I'm still awaiting the second installment. Richard
  17. Welcome to MSW. I grew up in upstate NY (Gloversville). Thank you for your service. Since you are in Saratoga, the Philadelphia from the battle of Valcour Island may be of interest, Richard
  18. Welcome. As Chris said, a great way to start would be to search" first finished builds". Also if you l look there are threads under ship model kits which would be helpful and there are discussions on which company puts out the best products including instructions.
  19. After years of building with equipment all over the house which I had to drag out and then store again, I now have a dedicated shop. Yippee! I replaced the original structure which was a shed attached to my barn with the new structure which has heat and air conditioning as well as exhaust fans. I split it into two rooms one of which is for sawing, filing and anything which creates dust. The other room is for metal work and assembly. I also included a fly tying table as I am an avid fly fisherman. I still have plenty of room left over to add tools. I'm thinking of a thickness sander but I don't need it yet. Richard
  20. It is tough to tell from the picture if you have enough info. I do see sheer lines which should make constructing the hull possible using bulkheads and this would be another option other than a solid hull. First decide your scale. If you are not going to use the scale given which I believe is 1/96 by my math then figure out the correction needed (say 200% enlargement if you go 1/48). Have the plans enlarged and copied which can be done at an office supply store. Now start making copies on your home printer. Cut out each individual sheer line remembering to subtract for the thickness of the plank(s) you are going to use as sheer lines are from the outside of the hull. Since sheer lines are half hull you will need to make these into full hull by matching two 1/2 copies and the make a full width copy with your printer. Glue these to plywood and cut out your bulkheads. Their positions on the keel I believe are given but it is tough to see in the picture. From the looks of it you are going to have to add additional bulkheads in between to allow a smooth flow of your planks. To do this make additional bulkheads using the broader of the two where they are going to sit in between. These will be oversized. Now fare all bulkheads down so you get a smooth run for your planks and you should be able to start planking. Richard
  21. There is no such thing as a perfect model. Richard
