JerryTodd
Everything posted by JerryTodd
  1. Last year it was gusting and the wind was bouncing off everything, including the Savannah, which we were right along side of. Everything on Constellation seemed to work itself loose. A few weeks later at St Michaels, everything went much better, though the wind was still fluky and variable. So this year, I'm not too worried with "at the event" as much as getting TO the event in good order. If it's to strong, too shallow, etc, then she'll sit on the table or get "anchored" for folks to look at.
  2. Got the port hammock rail caps in place with a first coat of paint. Getting the electronics in order and took a few "glamor" pics
  3. Cut some 1/2" by 1" strips from a plank of balsa I have kicking about and began capping off the port side hammock rails.
  4. Well, saying out loud that I intended to do something outside was a mistake. The entity that always ensures it will be cloudy whenever there's an astronomical event I want to see, apparently made sure it would rain today, so I couldn't move the garage/shop contents outside to bring some order to my chaos.
  5. Worked a bit on getting the mechanics and electronics into her. Mounted the on/off switch under the skylight. The wires that ran from the switch charging lead harness to the servo try and Rx were cut to make the harness separate from the servo rig using a two prong plug, but the "crimp-on" connectors slipped right off as soon as I tried to separate the plug - so some time was spent trying to find the soldering iron. Tomorrow will be a drag everything in the shop out onto the driveway day and get this feces sorted or die trying. If that's the case, BTW, I won't be posting pictures.
  6. Not the best image, but the first of her with t'gallants up. This is pretty much what she'll be wearing to the ball next weekend.
  7. RBModel has shackles, some with threaded pins, some with clevis pins (pin with a hole for a cotter pin). I'm not sure if they go as small as you need, the smallest seems to be about 7mm tall. I've been dealing with these folks for years and have always been happy with their products.
  8. Yesterday I did some filling and paint touch-up, and began bending sails. Today I began jury rigging. So far the two tops'ls are up. Last time I did this event the sails were lifting the coarse yards, this time I ran the tops'l sheets down to deck to act as a down-haul and prevent that from happening this time. The fore-topmast-stays'l and the jib are up minus their sheets. I'll probably set the outer or flying jib as well. Because of the added sails, I'll be rigging rudimentary shrouds and stays especially for the t'gallant poles. The top masts are lowered so the garage door won't hit them - just in case. Once the sails are on I'll take a few pics outside
  9. I'm pretty good with cats actually, Bob. We'll see how I do with dogs when I get to the capstan. That's a-pawling isn't it? Pat, there will be pictures, and probably some video too. This morning was spent making the starboard cathead. Seven layers were cut from 1/16" bass sheet, three of those cut short to allow for the sheave slots. The short layers were glued to long layers as well as walnut dowel sheaves, and the bass end pieces from the cut-off portions. Again the hull was pierced to make a socket for a cathead. The position marked; precut with a knife to keep the glass from tearing out; then successively larger holes drilled. The final hole was squared by roto-tool with a burr on a flex-extension and a lot of knife and file work. There's about 1-1/2 inches inside the hull and a little over 2 inches exposed. Knees were made from oak and glued to the cathead, though the cathead isn't attached to the hull as yet. Everything will be epoxied in place and pinned with brass rod; any gaps filled, and all painted black and white.
  10. Baltimore's PortFest is May 18th - I'm going just to see that "six-foot sailing model of USS Constellation!"
  11. Today I focused on the catheads. Relying on the 1888 spar deck plan to tell me where it was, the angle at which it projected from the ship, and how far out; I had to rely on photos to figure out it's steave. The simplest and most accurate way to make the slots for the sheaves was to laminate it. Fortunately, it worked out to being 7/16" square in 1:36 scale which was perfect to laminate 7 layers of 1/16" bass with 3 sheave slots. I didn't put in working sheaves, but used slices of walnut 3/8" dowel glued in place instead. For those of you following along with the possible idea of learning something - here's your chance - do this somewhere long before this during the construction. In this case the catheads are set into the hull at 60° from horizontal right at the hull/cap rail seam, which means I could have simply sawed a notch for it with a razor saw and been done with it. Now I had to bore a hole, and dig it out square keeping two angles correct. Even if I hadn't set the catheads before now, the hole for it would have been there, ready for it. As it turns out; slow careful work with a bur on the roto-tool got me to a good, snug fit. Now all I have to do is make and fit the starboard cathead.
  12. These bitts have a three pronged bronze crown on them. I'll probably wind up painting them with the green patina normally seen on bronze, but for now I just colored them with a bronze metallic Sharpie.
  13. There's obviously more there than just a hammock and it's rigging - blankets makes sense. Sailors had their sea chests and sea bags to stow clothes in. Each one has a man's name and his number stenciled on it. They're not bent into the 'U' or yoke shape - I don't see that you could as fat as they are. I initially thought they were 'bent' till I realized they were set into the rails in pairs, side-by-side. Navy hammocks were 70" long, curled into a yoke would make these this about 3 foot square. I think they are shoved in as deep as they will go. If you cover them with a tarp and cinch it down snug, they would probably compress to within the height of the end boards.
  14. Staring at the image of the Kearsarge I posted above, I realized the hammocks are not bent into a yoke, but simply rolled up into a sausage. They're put in the hammock rails side-by-side, pretty willy-nilly from the looks of things. An original US Navy hammock of the 1870's measured 39" (99cm) by 70" (178cm) so it's an easy guess at how long the rolls are. Going back to the sausage analogy, they're stuffed with something; I can't figure any other reason a simple 3 foot wide canvas hammock would roll up to be THAT bulky - they're nearly as large as a man's torso! I guess using elbow macaroni to represent the top of the "yoke" sticking out isn't going to work now. I'm thinking making the portion of these things that stick out of the rails and glue them onto the cap piece I already have installed. I can soak them with thinned resin to plasticize them and further fasten them down.
  15. It's connected while the sail is set. It's disconnected on a sail that brails - sometimes. Here's the version Pride of Baltimore had and I recreated on my model. Her mains'l was lowered rather than brailed and except when reefing, the clew pendant was hardly touched.
  16. I'd suggest meeting somewhere and sailing our 1:36 scale models together, but that might land us in Bogota or someplace.
  17. Based on the original image - it's a preventer tackle, to hold the boom out against a gybe. It's not shown connected as clew tackle would be.
  18. Finished making and installing the mizzen bitts. Built up the bow bulwarks and padding the bowsprit hole.
  19. I apparently misjudged the size of the hammocks - these buggars must have been used as tents ashore as well - they're big! Kearsarge 1880's
  20. Hammocks were covered with tarps probably as long as there were hammock nettings to store them in. Constellation's hammock cranes were originally meant to be covered with "weather cloths" ie: painted canvas tarpaulins outboard just as the original six frigate were originally designed with open bulwarks on their spar decks. I'm not sure why the hammocks weren't covered in those images, and I'm not sure yet how I'm going to deal with it. I kind of like the hammocks exposed, so I experimented with some hammock sized bits of cloth rolled and bent into a yoke. They seemed awfully small and lead me to think they were put in in two rows inboard and outboard. I could make a cap piece with the hammocks all protruding out of the top and cast several in resin. I think that would bend and curve enough to take the shape of the rails, save a great deal of work, and be a little tougher than gluing a bunch of bumps on the rail cap piece. Anyway.... The fixed bulwarks forward are shorter than they ought to be, so I started building them up. First I epoxied a sheet of 1/16" bass to the inside. When that was set-up I added another layer outboard and on top of the existing bulwark. Once this sets overnight I'll add more layer to get it to the correct thickness, then trim it to size and shape. I began installing eye's in the deck at the base of the masts according to the 1888 spar deck plan. Most of these are brass screw-eyes, but the two that will anchor the main stay are eye-spikes set into the deck at an angle roughly 90° to the stay. The forward and aft hatches also got three eyes each as shown in the plan. The images are: mizzen, main, and fore and forward is to the left in each. The brass rods standing nearby are for the bitts a rough-out version can be seen in the mizzen image.
  21. So, as I often do with this model, I've run into something of a dilemma. Looking through my images with the intent of figuring out what color the tarps over the hammocks should be; black or white; I found no tarps. The image shows the ship at various points in time pertinent to my depiction of her. Top to bottom they are, chronologically: Naples 1856 by deSimone (The painting my model is based on primarily) Naples 1856ish maybe by Roux - often misIDed as the Levant (I leveled and flipped the image to correspond to the others) Naples 1856ish another deSimone? Naples 1862 by deSimone Chesapeake 1871 earliest known photo In each of these images there are no coverings over the hammocks. In #3 and #4 she is underway, though in the harbor; in the other 3 she's at anchor. Interestingly, the hammocks lean different ways in the images (remember #2 is mirrored). I'm not aware of any other contemporary images of the ship other than an 1859 engraving where she's in dry-dock with nothing in the hammock rails, and an 1864 sketch, also in dry-dock. At any rate, I suspected the tarps were black and now I'm thinking I need to show uncovered rolled hammocks instead. PS: There is one more contemporary image that depicts the ship after 1871. There are no tarps, or even hammocks here.
  22. These hammock rails require a lot of work! Yesterday I added the mainsheet fairleads through them, and polyurethaned inside each compartment. I also extended the forward channels a bit. I made them too narrow years ago when I put them on, they're the right depth now. Today I added blocking to give the covers more glue surface and solidify the panels between the blocks. The first layer of balsa went on all around, capping off the hammock rails at last. And for kicks I sanded and polyed the deck again.
  23. So, I gave the deck a sanding and a coat of oil based poly. This reacted with the marker ink in the deck seams making them bleed a bit. It did give the deck a nice color though. When the poly dried I gave the inboard side a coat of white, including the waterways.
