Nirvana
Everything posted by Nirvana
  1. Arthur, don't stress and push to get things done. Here is very example to stop,don't glue anything into place. Take pictures for us to look at so we can help.
  2. My simple solution; drill, dowel sandpaper in hand and half an hour work. And here's a link.
  3. Worked oak mast to the left - untouched to the right
  4. Home depot of all the placed....😀
  5. The dowels I am working with are oak.
  6. I headed over to one of the local hardware store to get new dowels for the masts of Bluenose, I went with round dowels from start. I had to go through some 26 dowels to find myself 4 usable straight once. I placed them on the floor and if they could roll without any major effort they were fine. Sighting from one end to another didn't show any warp at all. These dowels are larger than what plans says so there was a lot of sanding to get the proper shape. And yes, I put the dowel in my power drill and sanded it by hand. I use a leather glow that holds the sandpaper, this to avoid the heat build up from the turning.
  7. Arthur, first of all - A Warm Welcome to MSW! I am glad you got the Bluenose as a starter. Yes the dowels for the mast and booms are a disaster in the kit. Mine was badly warped as well - and today again - I went to my hardware store and got some straight dowels. This to start all over again with the masts. As for the Bluenose herself, I would suggest to get going with her before attacking the dories. This will give you the skills to handle the smaller and more delicate items in the kit. However I am looking forward to see your progress, and if you have questions - don't hesitate to ask!
  8. I built the longboat from MS using a heat gun forming the planks. Worked as a charm, no messing around with water.
  9. Ed, I wish I could and a wow to the like. This is so much better than the instructions provided from MS. I might go back to the table and redo everything regarding the rigging.
  10. Oh my, but once all is painted the blemishes will be gone! Thank you, Thor Oden and Frej and Ymer! Yes I am Swedish!
  11. Allan, the amount to the family was 300000 dollars!
  12. When the Bluenose II was built back in 1963, the family of the original Bluenose saw it was a direct copy of the original ship. This led to a lawsuit started in 2012. So it's not only our models that becomes victims of IP theft. I haven't found any records that the case is close, but considering the timeline I guess it has been closed.
  13. Moving forward with the mast project. The trestle is almost finished, the fit almost perfect. Getting the cheeks parallel with the longitudinal line of the ship was tricky but I got the first two in place. The trestle is just dry-fitted.
  14. Kevin, that's an incredible picture. The angle makes the ship to look much much bigger than it is, specially with your house in the background. If you wouldn't had the towel in the picture it would had been even harder to tell.
  15. And with Heller's HMS Victory there are a lot of aftermarket parts available. Like better cannons, wood deck etc. Look at this website. Once I am embarking the journey of building Revell's Constitution many items will be come from that place.
  16. Ed, your building documentation will certainly help me and future builder of Bluenose. I am working on my masts.
  17. Jim, I planked the lower deck and used 2b pencil for caulking. However, 2b pencil do smudge badly if not careful. Looking good and it brings back memories of my build.
  18. That's why I bought some lego squares, rectangulars. It has helped me.
  19. In the latest issue of the Nautical Research Journal, Kurt Van Dahm has a very nice article when it comes to maintaining your airbrush, sure this is written with his experience of the Badger brand. But what he writes is applicable to any brand. Well worth reading. Thank you Kurt, this will help me.
  20. Amalio, what is the finest grit of sandpaper you use in order to keep the material so "fuss-free"? This is art not shipmodeling at my level. Beautiful done!
  21. Zeno, One method used by many of us when it comes to bulkheads ( and yes, the less "play", the better) is using lego bricks to get perfect 90 angle between bulkhead and false keel. This can also help to straighten up a lightly warped keel. You will find out that clamps are a very good friend to get items secured while waiting for glue to dry.
  22. Maybe a sherline mill isn't so expensive after all, take a look at this unit!
  23. My bowsprit is all done by hand, lots of sanding and manual carving with knife. Not as beautiful done as yours but I think it will pass for a less picky eye than mine.
