Everything posted by Nirvana
I have turned my attention to the other side, and working on the fills between the bulkhead. The instructions is showing three planks for the waterway, I have chosen two, one wider for the inside of the bulkhead and a fillers between. Lots of cutting and trimming, but I think this will be very nice once done. Sadly all this will be painted. I am now alternating between the Bluenose and Syren, it's a nice change.
So, the simplest of simplest, my jig for cutting 40 each of 15/32" parts. I used the stick for the height between sills and lintel, placed it on right hand side of the blade of my chop saw. A 1x1" aluminium L profile sat in place with strong masking tape (not good at all when it comes to cover unwanted painted area, ripps the surface where it is attached off). As a trial I cut 10 posts, and all came out perfect for cannon openings. Cutting time less than a minute.
Less is More, was one of mottos with a company I worked for back in the 80's. But how does one apply that to ship modeling?
At my last visit in Seattle one of our MSW member cut me a perfect 15/32" x 15/32" stick to be used for the cannon ports. The stick was cut using Byrnes table saw with micrometer. Instead of marking of each bulkhead from a caliper I used the stick to get the correct height between the lintel and sill. The stick turned out to be a good tool as well.
Fokker Dr.I by Torbogdan - FINISHED - Model Airways
Nirvana replied to Torbogdan's topic in Non-ship/categorised builds
Tor,I am crying seeing the receipt for gas of yours. My last fill up cost me 36 dollars for 13.1 gallons. Now let me try to convert it to Swedish units...... That will be 50 liters and 290 kronor for 87 octane gas. -
Sail design for 18th-century longboat?
Nirvana replied to Cathead's topic in Masting, rigging and sails
Thank you Chuck for the clarification in this matter regarding the horse. In other words the version I did with the tiller under the horse would be later 18th century. I also added a signal cannon at the stem, which I found out that some longboats had as well. -
Tor, Why not upload picture directly to MSW? Do you need photobucket? -
Mr. Pucko Have you contacted the consortium that build Gothenburg? You might be able to buy plans from them.
- 305 replies
- deagostini
- vasa
