Everything posted by Nirvana
Mike, How about building your own pedestal? 860 dollars seems to be extremely steep for a case. Does it have gold inlay?
- 843 replies
- niagara
- model shipways
Maury, that looks so good. Thanks for the info of the magnesia block.
- 525 replies
- anchor hoy
- hoy
A pictorial update. This block is just balsa to show how I started out. The final part was made out of boxwood. After I had somewhat the right size of the boxwood block the Dremel came into use. There are a lot of angles to consider. I made one block and then made a mirrored part. Then dry placing the part at the end of the quarter deck, to figure out how much to cut off. This part in the middle is the right one to install. Here are the port and starboard part testing the area. Some more trimming and then it will be time to add the waist parts. Below is all my trial parts.
Jesse, apparently you are doing a good job as the yard master (your kitty) is more interested of cleaning than supervising. That looks so good.
- 1,306 replies
- syren
- model shipways
Brian, When I planked Bluenose I started the spiling (minor, as it takes so little) on the eight plank. This resulted (for me) that all the planks ended up at the stem. The only stealer I inserted was at the stern. Take a step back, don't rush this stage. You might want to re-do some of the planking.
Such a master piece!
Peter, I like the extra support you added to the build frame.
- 242 replies
- syren
- model shipways
I didn't realize but saw I have had a "duh" moment. This as the instructions clearly stated, use a plank to clamp to the bulkhead for installation of the stanchions. Well, obviously they knew from the start that was the way to go. There are a lot of cutting to get them done. I am considering cutting the heads from the bulkhead and replace them with stanchions. This to make them look uniformed.
John, as a filler in-between the bulkheads I used balsa. Easy to cut, and makes a huge difference for straighten the keel up. No need to use any harder wood. Maybe pine is cheaper, have no idea. My three blocks of balsa 1x2x12" was some 6 dollars.
- 90 replies
- syren
- model shipways
