AON
Everything posted by AON
  1. I'm starting with the roundhouse clamps at 11" thick and 13" broad (height). Clamps were normally 25 to 30 feet long but I read the roundhouse clamps were normally made in one piece. Mine are about 49 feet long. That would be a beast to lift in place at practically 1 ton of weight. I made a quick mock up out of scrap poplar, marked off the heights for the clamps and laid the mock up in to check it out. It ran below the top of the door opening. Double checked my pencilled in door locations which were spot on. I found that the original framing plan had the round house deck beams drawn in at double thickness. After adjusting things the mock up just cleared. I then made up the two clamps in Castello boxwood, a paper template of the wall curvature, and then a form to clamp my steamed clamps to. When dried I had 1/8" spring back. Adjusted the form and things are re-steamed, clamped and setting now.
  2. Will this be the master for casting more?
  3. I deleted my earlier post as I made an error having read all the clamp descriptions at once I got confused and melded them. Need to step back for a moment.
  4. I wasn't planning on that next but it would definitely brace things before cutting out the doorways. Hmmmm. Change in plans????
  5. Rebuilt the side quarter and faired (sanded). Looking considerably better this time. I installed a temporary brace across the top of the counter timbers to try to steady things a bit while I work in that area. Marked of the top timbers and quarter doorways. These will be cut down/out this weekend, then I'll get the cills installed. I am hoping to do a better job on them also!
  6. I'm surprised no one asked what the heck that means.
  7. That is very interesting. The Royal Navy BR67 - Manual of Seamanship 1937 reprinted for the Royal Canadian Navy in 1942 lists four types of construction: 1. Clinker built 2. Carvel built 3. Diagonal built 4. Sewn boats Clinker built boats existed well into the 1970's until replaced by the new Fiberglas hulls. We had one, a cutter built for us (local sea cadets) in the 1920's and they were at the reserve base boat shed at HMCS Star and summer training camp HMCS Quadra in the 1970's. My interest is with the Royal Navy of 1790-1800.
  8. That certainly shines a much brighter light on things. Thank you.
  9. Thank to all, and yes it did seem to take a wee fork in the road but enjoyable none the less. I have been peeking in but have be otherwise occupied over the last few days to be able to comment. The first few posts put some light on the subject. I've found that Wolfram zu Mondfeld wrote in his book Historic Ship Models, pg.192: The cutter - A clinker built general purpose boat with up to 12 oars and fitted for sailing - introduced in the latter part of the 18th century. The carvel built yawl of 4 to 6 oars was the smallest ship's boat on board until the late 18th century, when it was superseded by a small 18ft cutter pulling 4 oars, known colloquially as a "jolly boat". The gig - A long narrow, fast boat for personnel transport with 6 to 8 oars. The gig was used for carrying the Captain and usually his private property. With its introduction in the late 18th century the gig took over part of the duties of a pinnace or barge. Only one gig was normally carried. The images on the following page 193 show the gig to be single banked and the cutter double banked. In Ship Modeling From Stem to Stern by Milton Roth, page 136 -137: The smallest carried aboard was the dinghy or jolly boat, ranging in size from 12 to 16 feet. By contrast, the largest was the longboat or launch. The Longboat Launch (first time I've seen longboat and launch together so I guess that answers another question, or does it?) was 20 to 50 ft long, double banked The Yawl Barge was 24 to 35 ft long with 8 to 16 oars, single or double banked (which in profile on page 140 looks like a shorter launch, but per the description the lengths overlap so were they the same thing up to 35 ft? This was a Yawl Barge, what about the Yawl and the Barge?) The Pinnace Cutter was 20 to 50 ft long with 8 to 16 oars, double banked and was the second largest service boat. (so was the Pinnace a Cutter, apparently not according to W.E. May in his book The Boats of Men of War as they are listed separately. Also, the pinnace was carvel planked and the cutter clinker planked... ) The Dinghy Jolly Boat was 12 to 16 ft with 2 oars, single banked (virtually a small boat rowed by one man... like when I go fishing. I read "jolly" as a fun little boat.) I find it all very confusing as most overlap in length, number of oars, and even dual use of names... and then different sources don't seem to agree. I imagine the deciding factor might the end use assigned to the design. Where might that be listed? I hope this helps people understand my confusion.
  10. Could someone please explain the difference between a Jolly Boat, a Captain's Gig and the shorter cutters. I understand a Jolly boat was 18 feet long or less and was used to transport people from ship to shore or ship to ship. I understand this is the same description of an 18 foot long cutter Are the then the same thing? What about the Captain's Gig?
  11. You have done an excellent job creating a worn out beat up dory. If you removed your hand and changed the setting for your photos I could easily believe it was the real deal. Fantastic. Well done (BZ)
  12. Me too! Me too! A good picture is worth 1000 words.
  13. thumb and push stick - that has been my limited experience also. I should have bought mine years ago! (instead of late last year)
  14. Christmas and New Years Day celebrations are over. Tomorrow afternoon I will be sanding my counter and filler timbers... then come the door cutouts and cills. Meanwhile, over the last few days I was inspired to look at the small boats. Per The Boats of Men of War by W.E.May the 74's of my time period were issued the following six small boats: 1 each x 31 ft Launch 1 each x 32 ft Pinnace 1 each x 28 ft Pinnace 2 each x 25 ft Cutter 1 each x 18 ft Cutter After seeing a couple people present how they built their small boats and studying David Antscherl's published article in the NRJ Vol 55-1: An 18 ft Clinker Built Cutter Model, where he builds it over a plug. Then having followed Druxey's 28 ft US Cutter build on MSW... I decided to draw up the small boats for my ship. Here they are below, ready to start anytime I wish, at 1:64 scale. AON - 18 ft cutter lines -31DEC2022.pdf AON - 25 ft cutter lines - 3JAN2023.pdf AON - 28 ft pinnace lines - 2JAN2023.pdf AON - 31 ft launch lines - 4JAN2023.pdf AON - 32 ft pinnace lines - 4JAN2023.pdf
  15. No it does not. I had to clean up the resolution to see the marks were numbers and not columns! This is part of the Elephant deck plan.
  16. Good morning. I have the plans of both the Elephant aand Goliath. I don't recall seeing the location of the columns shown but will look again after breakfast. I believe the quarter galleries were used by all the officers... on both sides.
  17. Off original plans it measures approximately 27 feet wide in this cabin. Head clearance under the beam is approximately 5 feet.
  18. Good evening Yancovitch, Every time I leave my shop I surprise myself with what I have done. No one knows how impossible I feel every new task will be for me. There are a lot of "do overs" and I have become very comfortable tearing pieces off. But I continue to crawl forward, never give up, always face the new challenge. I know I will fail at some the first or second time, but I get better and learn with each attempt. I am still a novice. Mark That is exactly my approach, extra wide! Good night all.
  19. I'm no smarter than anyone else, I've just accumulated a good reference library! Happy to share.
  20. Completed installing the last of the side quarter filler frames. I will start sanding them to proper thickness (port/starboard) and height next week. Then I cutout the door openings in the frame and install the cills. And then finally the stern frames to close her up.
  21. The tie or tye is the halyard that raises/lowers the lower yard. Item 1 in this image from Historic Ship Models by Wolfram zu Mondfeld, page 310.
  22. According to The Construction and Fitting of the Sailing Man of War 1650-1850 by Peter Goodwin Page 179 figure 6/10 The backing piece was called the LINING. The front piece that bottomed against the lower cheek and rose to half the hawse hole and had a radius in it that the holes for the bend of the cable passing over it was called the ELM BOLSTER. The hawse hole had an oak lining in barrel stave fashion, between 8 and 12 segments. This was covered with lead or heavy gauge copper, the latter being used in the 2nd half of the 18th century (1750+), in some cases lead only.
