Everything posted by AON
What about using these replacement erasers on the end of a dowel? Integra Pencil Cap Eraser for Standard Pencils, 144 per Box, Pink (ITA36523) https://www.amazon.ca/Integra-Pencil-Standard-Pencils-ITA36523/dp/B00181LCHU/ref=sr_1_6?crid=47MKFGNSI70S&keywords=eraser+tips+for+pencil&qid=1647134226&sprefix=eraser+tips+for+pencil%2Caps%2C167&sr=8-6
Does the thumb screw on the end of the post move at all with the passing of multiple strips over time? Your and Michael's design has some merit to it. My posting #1277 (8 JAN 22) in my build log shows an image with drawings I made. I'd be happy to send you a PDF copy. Kurt says the NRG are looking at selling a simplified version (mine was a combination of his and John's versions) sometime soon.... he is getting pricing for the bits and pieces. If I were to do mine again I'd likely make it at least 1/4" wider.
I will post the one image showing the sheave in use later this morning when the noise of the scanner will not wake up Her Majesty. Also, I just sent you a PM regarding the other information. Alan
Sorry, I assumed most vessels from the late 1700's through the 1800's would be rigged somewhat similarly so all sailors would be familiar with it regardless what ship they transferred to. I am probably wrong. I did not expect you to have the books I mentioned in your library, hence I asked if any information I had mentioned was of any interest to you. I understand it is not. I hope someone knowledgeable steps up and you find what you are looking for! Good luck Commander.
The Fully Framed Model by David Antscherl (Swan class Sloop) has these sheaves. Modelling the Brig-of-war "Irene" by E W Petrejus does not show any. The Brig Niagara (on Lake Erie) does not have these.
Have you Harold Underhill's "Masting and Rigging the Clipper Ship & Ocean Carrier" ? Fold out Plate 51 (pages 281 through 290) show all 135 belaying points for all lines. But I have not noticed any details on fife rail sheaves. Edward Hobbs' " How to make Clipper Ship Models" has very informative fold out standing and running rigging plates (III & IV) But once again nothing noticed regarding fife rail sheaves. Wolfram zu Mondfeld's "Historic Ship Models" pg 310 has a figure showing the lowest heaviest yard halyard running down to a ramshead block where it and the sheave in the fife rail act as a block and tackle system to provide additional mechanical advantage to raise/lower the yard. Are an of these of interest to you?
Thank you for posting these. Very interesting. I never knew they were soaked, heated and widened.
Ropewalk: A Cordage Engineer's Journey Through History
AON replied to BenD's topic in Nautical/Naval History
It is interesting for the purist to note that none of the ropes are BLACK or WHITE. Even the 4 strand tarred rope is not BLACK. -
The Fully Framed Model (6th Rate), vol 4, pg 44 - served all over The Anatomy of Nelson's Ships (1st Rate), pg 226 - seized at the bight at the heart and another at the foreside of the hole at the in the knee and a third at half span between the other two. Historic Ship Models, pg 276 - the two parts were seized together in several places
So I am merrily moving along at a snails pace cutting thin strips with my new Byrnes table saw and installing chocks between frames when Flyer posts he noticed an issue with his bobstays interfering with his figurehead in his Bellerophon kit build. The arm broke off of his and he glued it back but possibly not in the same position. Even though his figurehead is different than mine I immediately thought I might have a similar problem and I'd best check. So I installed my bowsprit and figurehead and dummied up a couple of bobstays and there it was, the lines were bent inwards at Pegasus' hooves and lower fore legs. When I get the nerve to try and clean up the horse's head I'll thin down the hooves and legs. I can possibly thin down the stem a little to help create minimal clearance.
