looks really good OC  :)   well done on making the stand  !
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
4 hours ago, cog said:
Lovely work OC. Slow but steady, that's the best way !
Thanks carl.:)
OC.
Edited by Old Collingwood
signiture
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
37 minutes ago, BANYAN said:
Nice to see you back at it OC; she is standing proud now.
cheers
Pat
Thanks pat.:)
OC.
signiture
Current builds
Completed works.
Thank you sincerely.:)
OC.
Current builds
Completed works.
Slight change of plan I thnk, as I have been working from the stern - forwards, I think tomorrow I should work on the stern walkway, as this is a mini kit in itself and requires some PE parts.
Here is a photo of  how the parts look and when fitted to the ship.
OC.
Current builds
Completed works.
I started on the rear walkway today folks, first I had to cut two pieces from the PE fret namely the floor and railings, then after a slight sanding of the edges next step was to bend the railing to meet the shape of the plastic roof section, I did this by bending it against a narrow sanding stick, as it was gentle enough not to damage the PE part, but also strait enough to get the fold,  after doing this and comparing the shape to the roof - I layed a troth of PVA and layed the railing to it positioning it carefully then left it to dry.
Next I turned me attention to the walkway footplate, this again was a PE part but I decided to attach it to the plastic footplate part after thinning it slightly - this will give it a liitle bit more strength.
When they have set before adding the floor I will bend them into shape slightly more accuratley, ready for a bit of CA glue to secure them prior to painting the insides.
Another reason for using the plastic footplate along with the PE is to make a better surface to glue it to the hull.
Here are a few photos of the parts folks.
OC.
Current builds
Completed works.
there ya go.........gett'in into some of the nuts and bolts action  ;)    look'in good so far!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Well that hasn't worked out well  - whole walkway structure fell appart after I glued it all together, and its all a buckled mess  - combination of lack of dexterity - holding small parts, and inabilty at glueing and securing such small areas.
So guess it will have to be Warspite but minus the walkway (not very realistic I know)
OC.
Current builds
Completed works.
Nothing to salvage? Not even the plastic parts ... It would be a shame, though, but if you can't , you can't. I sometimes have to make parts (PE a.o.) a new after the original took a jump ... possible in your case?
Take care
Carl
Take care
Thanks carl,   think I maaged to salvage it (In a fashion) its a bit miss shaped but is super glued a bit stronger now(got most of it on my fingers)
OC.
Current builds
Completed works.
So  - as i just explained to carl  - I could not let it defeat me, so I took the parts and run hot water through them to remove any traces of PVA, then under our kitchen halogen lights and my magnifier I tried again using direct super glue, firstly attaching the walkway base to the rail, then the roof,  mind you I managed to get more super glue on my fingers than on the assembly.
At least its securley put together now even though its a bit rough and slightly distorted.
OC.
Current builds
Completed works.
Mind over matter! Well done OC.
And don't forget, when something isn't perfect...you're the only one who knows and probably nobody else will notice it.
The builder himself is always his own worst "food critic".
Robin :)
WIP: No ships atm...sorry!🙄
Completed: Greek bireme - Dusek - scale 1:72
 Louie da fly: "I think it requires a special kind of insanity to choose a galley to build a model of."
Robin :)
Thanks robin, close work through magnifiers dont help either,  looks ok well actually stunning when I take my glasses off.   lol.
OC.
Current builds
Completed works.
Well done OC. Hope your fingers didn't get glued to eachother, a bit awkward when dealing with PE ... I tend to use dirty glasses (fingerprints e.a.) when I fouled up ... makes it look even better ...
Carl
Yep I know,   Im going to start leaving the lens cap on when I take photos.^_^
OC.
Current builds
Completed works.
So - back on with the rear walkway today, I gave it a few coats of mid grey and left it to dry, its a bit rough looking,   but it will be tucked away at the stern so no one midships or forward will notice it - just keep the captain away from it or it will be holystone duties for the painters for weeks.
OC.
Current builds
Completed works.
glad you were able to recover........I thought you were gonna come back ad tell us that you have a very nice walkway cemented to your index finger  :D  {ya have to laugh about it...no sense the frown}.   I've been looking at pictures of the ship I'm working on.......there is one picture where the stern is all full of dents.
so,  I would think that a minor ding here and there could be acceptable.   carry on........your doing a swell job  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you my friend,  no worry about getting the walkway stuck to my finger but - "you know those sticky custard slice cream cakes"?  managed to get that stuck to my finger, not good eating a sticky cake while building a model.:o:rolleyes::D:D
OC.
Current builds
Completed works.
More work on the rear walkway, I started by offering the part up against the stern to see how it fits, then I applied a thin coat of CA and pressed it in to pleace, then a light sanding and a few more light coats of mid grey.
Here's a couple of photos folks.
OC.
Current builds
Completed works.
8 hours ago, cog said:
A nice veranda for the capt'n to take his summer strolls :) Looks good OC
Thanks carl.
OC.
spilling
Current builds
Completed works.
3 hours ago, RGL said:
Looks good mate, it’s easy to get distracted doing the tiny details and we forget it’s hardly noticeable on the finished product.
Thanks greg very kind of you.
OC.
Current builds
Completed works.
51 minutes ago, BANYAN said:
A great outcome OC, it looks good despite your misadventures with VA :)
cheers
Pat
Thanks pat  I soon un-stook myself from the cream cake that was so precisely stook to my fingers(the rear walkway came away also):)
OC.
Current builds
Completed works.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
