I use my wife's discarded hair curler.  It is stuck on High so she can't use it.  I soak the wood for 10-15 mins.   Open the jaws stick the wood in and close the jaws .  The heat helps with the bend.  The diameter is perfect for every curve I have needed so far (15 or so ships), and can be bent in any direction.
Brand new the curling iron is less than $10 USD.
A vegetable/rice/food steamer cooker should do the trick.
Black & Decker and Oster both have long oval models for < $40.
They are also useful for cooking rice and veggies, so be more cost effective than most tools we buy.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
I use a steamer and you can look here
http://modelshipworld.com/index.php/topic/494-steem-bending-tool-cristikc/?hl=cristikc
how it works. Cristi
Current build : Sovereign of the Seas - Mantua 1:78 scale
Finished:        San John the Baptist - Cross section
                    Santisima Trinidad - Cross section                  Galery Santisima
                    San John the Baptist ( San Juan Bautista)    Galery  San John
                    HMS Victory 1805 - Cross section - Corel 1:98 scale
                    Panart (Mantua) 740 Battle Station          Battle Station Panart 740 Galerry
On Hold:        HMS Bounty 1:64   Mamoli MV39
I have been using an Aeropiccola heat/steam bender for over 30 years. Works well for me. See my post about it from another thread below.
http://modelshipworld.com/index.php/topic/602-how-long-do-you-soak-the-planks/page-2?hl=%2Bplank+%2Bbender#entry216387
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
This is what I have:
I have used it for woodworking and guitar building and it steams the wood well.  The kit includes instructions on making the wood box but would have to be modified for model making.
I also have one of these:
When bending guitar sides, you need to back up the wood with a bending strap to keep the fibers from breaking.  This may not be an issue with model making though.
Julie
First and only build: Endeavour - 1934 American's Cup, UK Challenger, J-Class - Amati 1:35
Hi
I find soaking wood in container of boiling water is the most convenient method. For anything up to 1/8 inch a few minutes soak will do the job. You can vary the size of the container to match the piece of wood you want to bend and any water left in the kettle can be used for coffee (or tea in my case). When bending long strips I use a steam wallpaper stripper and push the strips down the steam outlet tube.
Keith
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
