Wood flour of the planking species mixed with PVA ( Titebond II for me).
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
On some of the build logs I've seen builders using a white creamy looking filler. I haven't seen it at the local Lowes or Home Depot. I will try at Hobby Lobby next.
GREG H.
I found that a number of different fillers worked depending on the situation. If it is a small crack that will be painted over, then the white speckling compound worked great. For small cracks that would be stained over, I tend to put some wood glue in the crack then sand over it allowing the dust to fill in the crack.
If you are painting over an area and have a large defect to fill, then you could use epoxy in it's various forms since it can be sanded and shaped after setting. If you are staining, I have not found any filler that could be used on larger areas (other than a small crack) that would not show up after sanding. The manner it absorbs the stain and the texture give it away.
If you are truing a first planking for a second planking, then almost any filler would do as long as it adhered well to the wood.
Bill
Chantilly, VA
Its not the size of the ship, but the bore of the cannon!
Current Build: Scratch Build Brig Eagle
Completed Build Log: USS Constitution - Mamoli
Completed Build Gallery: USS Constitution - Mamoli
If the filler is to be painted or planked over, then I have found spackle compound the best for the job. It sands very easily and has such a fine grain it is undetectable under paint.
A good tip is to wipe some super/crazy glue over the entire filled area after you have sanded it smooth. The filler soaks up the glue and it hardens and toughens to an amazing degree.
Edited by overdale
Have you tried Bondo? It is east to mix, hardens quickly, sands to an invisible feather edge and is cheap. 30 Yeats ago I build a clyindrical body od the boiler for steam cutter model by turning a slug of Bondo on a metal lathe. It has held up well. I should also add that it bonds well to wood. I keep a can in my shop and use it often.
For those readers from across the pond, Bondo is the proprietary name for a polyester paste putty used by the auto body repair trade.
Roger
I use the Tamiya white putty also. Rather than waiting for it to dry and then sanding, I apply it wait about 5 minutes then wipe it down with lacquer thinner on a paper towel. You'll find that a lot of the putty wipes off with no sanding - what's left smooths out nicely. Also the paper towel is rough enough to leave a bit of texture to what's left.  If you do your last wipes following the wood grain, the texture kind of steaks with the grain. What putty is left looks a little like a wood surface.
Just be sure to do this in a well ventilated area.
Fortunately, I needed very little filler. Where I did, I used Testor's Contour Putty (gray tube). It dried fast and sanded easy. The other thing was that MS Primer was extremely thick. So when I primed the area, it filled the gaps nicely and retained the plank shapes defining them nicely. It also sanded easily. My only problem was that MS's paints do leave brush marks, and the primer wasn't that easy to completely cover sometimes taking 3 coats, but overall I was pleased with the outcome.
John
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Hi.
I do the same as Jaager. Mix a little of the fine dust with the PVA glue to a soft putty. Works a treat.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
