Hi all
I have spent a couple of days messing with deck planking plans for my brig supply. I decided to look at the primer tutorial in here and went for the 13524 plan at planks 100mm, I have attached my drawing plan and would also like to ask if deck plans are done from the tip of the bow to the back of the stern as this ship has three decks at different heights, or can each deck be planned individually. Will be a while before my deck is laid but I can use any spare time to prepare wood ect. Would a larger plank size be better, I want a staggered deck and will be caulking using grey pencil with a light oak varnish. Thank you.
Current build: Caldercraft 1:64 HM Brig Supply
Finished builds: HMS Endeavours longboat
I like the pattern of the planking. Wish I could give you advise, but I know less then you do in this area.
The one thing I would like to know is, should  #1 line of planks start more to the left, so the very short planks at the right will be a little longer.
Don't know if I  explained that right.
Joe
I'm thinking your planking plan is good to go.
Yes. It looks good!  ;)
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
For the change of shift it is ok :-)
Just realize, that the scarfs follow the real beams underneath!!! Those are usually situated fore and aft the gratings, companionways, masts etc. and are not as regular as you show, thus resulting in different lengths of planks! Also no scarfs on the short pieces as in-between the gratings or near the head or stern.
Here some sketches I did for our german forum some time ago to show the approx position of the deck beams, I think based on Alert. Also added the planking pattern and the waterway.
XXXDAn
Edited by dafi
Realizing that it reflects North American practice rather than English, but in the Appendix of HASN, Chapelle includes a contract for two 600 ton Sloops of War for 1828.  The interesting factor for the deck is that for both the decking and the waterways it calls for planks averaging 40 feet in length.  It means that if you wish, your deck need not be so "busy" as far as the number of butt joints.
.I will repeat what I posted in Jan.  from the rules of the organization that was essentially the American version of Lloyds and probably used the rules from London as a basis for their own:
Record of American and Foreign Shipping
                         of
American Shipmasters' Association
                   1870  &  1885
Deck Plank
section 25.
The upper or main deck planking should be of the greatest obtainable length,
and free from defects, close-jointed and fastened with two spikes in each beam,
and one in each carling.  No butts of adjoining plank should be nearer each other
than the space of two beams ( when a strake intervenes the distance of one beam
will be allowed).  No butts should meet on the same beam, unless there be three
strakes between them.
Although this is from 1870, the properties of wood did not change, so these rules probably fit from 1650 on.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
