Dave
This #95 was an incredible posting. Using 3D for the scroll work wow... and the outcome of the metal work is great too. The hint about making up a gig to hold the unique parts and avoid having to remember the next day which is which...great hint. I just messed on the same issue.. thanks for sharing.
jon
Edited by Jond
Sweet!
That is the way I did them though you have done much better. After trying to form the pintles anf failing miserably (I did not know to anneal the brass at that time) I decided soldering would give a better result. Keep posting, we enjoy following your build.
Dave B
Current build: HMS Pegasus, English Pinnace (on hold)
Completed build: MS BluenoseSkippercraft
Thanks Dr. Per, Jon and Dave B!  That was my first ever attempt at any real metal work so it wasn't surprising it took a couple tries.
After a few hours of touch-ups (fixing any paint issues, filing down the bolts on the pintles/gudgeons), the ship is now sitting out in the garage.  The final clear coat has been applied, which means I'm officially done with the hull.  I'm officially moving on to the deck structures!
Hello Dave...
I really enjoyed the 3D printing you did.  What a terrific idea!  Your build of the Bluenose is so much nicer than others I have seen, including mine but I guess I'm more impatient than you.  Keep up the beautiful job; I look forward to seeing your work.
Best,
Jerry
Wheel Box
Over the last few weeks I haven't had much time to work on the build, but I did manage to get the wheel box finished.  Part of the delay was that I ended up building it three times.  Since this was the first structure I built for the deck, I wanted to be sure I liked the look and construction method.
My first attempt was too big - I simply measured the plans wrong, and didn't realized it until I was finished.
The second attempt was perfectly fine, until I started looking at old photos of the Bluenose.  That led me to rebuild it a third time.
The final attempt is the one I'm keeping.  I ended up going with slightly wider coamings along the base.  I also rounded the roof a bit as seen in the photos I found of the Bluenose.  I've decided to use stain in place of the 'burnt umber' called for on the plans.  This isn't historically accurate, but I like the look.
The wheel itself was fun, and set me back a week or so.  While cleaning up the casting, I broke one of the handles off.  I ended up filing it down, drilling a hole into the wheel's rim, and gluing in a very short piece of brass rod to simulate a handle.  Once I got the wheel painted I can't tell which one was repaired.
Hopefully the other deck structures don't take this long, or I won't be done for a few years.
Dave,
I've been quietly following along and I want to tell you that your work is absolutely first rate! I have this kit my workshop and when I start, this will be the first build log I refer to. I've looked at a number Bluenose build logs over the years and I think yours is the best. Best wishes for all your future builds.
Best,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Great detail and attention.  I love the final version you came up with.
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Cabin
Thanks for the compliment John!  I'm not sure that I'd agree that my build is the best, but I'll take it.
Bob & Dave, thanks!  I spent way too much time on the wheel box and wheel, but I wanted to be sure I was happy with the style of the deck structures before I built too many.  One thing I didn't show is that I actually tried building a different wheel from the Chuck's kit available from Syren Ship Model Company.  It turned out pretty good, but it was a little too big so I went back to the one that came with the kit.
The Thanksgiving holiday means I've got a five day weekend, so I decided to dive in on building the cabin.  My plan is to build all the bigger deck buildings first and get them installed on the deck.  Once those are in, I'll finally get around to applying the clear coat on the deck.  I decided to wait to seal the deck until the bigger structures were in place since I opted not to building the coamings in and plank around them.
The cabin took about 3 days.  I think I made it more complicated than it needed to be, but it was fun.
The main structure of the cabin was built from 1/16" thick sheet stock.  I used some 5/32" square strips to make some support beams.
And here's where I made things more complicated for myself...
I decided to build out the skylight and entrance into the structure, rather than adding them onto the completed cabin.  I started by framing out a platform to support the skylight.  I also cut out the entrance and installed the 'walls'.
I added some wide strips to provide support for the roof planking and added in the walls of the skylight.  Holes were drilled for the windows.
I decided not to try and build all the fancy detail in the corners.  I'm not confident I could pull that off.  Instead I just rounded off the corners.
The roof was then planked from the center out.  Since I had built in the structure for the skylight and entrance, there was some work required to plank around those pieces.
I decided to add the molding around the roof line, but I kept it simple.  Rather than doing anything fancy, I just painted and installed some 1/32" square strips to make the molding.
The doors were made in two layers.  I cut some 1/64" thick sheet material to the right size, and cut out openings for the panels.  This was painted white and glued onto some 1/16" thick material that was stained to match the roof.
The skylight's panels were framed out.
After being trimmed and painted, I added some short pieces of brass rod to make the bars.
For the compass box, I carved the box from a solid piece of basswood.  I used more of the 1/64" thick sheet stock for the cover.  It was soaked in water then bent around the box.
The roof for the entrance was actually planked like the rest of the roof, but painted over in white.
For the pipe, I decided to try and actually build it.  I cut some 3/32" brass tube to the right size and soldered it together.  I made the 'stand' from a piece of brass strip.
Everything got a few rounds of cleanup and final painting.
I'm pretty happy with how it turned out.  There are a few spots where I could have gotten things smoother or painted better, but I don't think it will be noticeable once I've got more stuff on the deck.
post-22030-0-00204100-1480194247_thumb.jpgpost-22030-0-64452400-1480194262_thumb.jpgpost-22030-0-06854400-1480194272_thumb.jpg
Unidentified Object and Cabins
It would be great if I never had to work and could spend all my time on the build as I've done over the holiday weekend!
I was able to knock out the 'unidentified object' and the two hatches pretty quickly.
From the plans and old photos, the 'unidentified object' called for on the plans appears to be some kind of bin or storage container with a lid.  I had a dowel rod on hand that was the right size, so I used that to make the object.  I cut a piece of the rod to 5mm and rounded off the top.
To create the seam for the lid, I used a small saw blade and cut into the piece as I rotated it.  I used a piece of wood to keep the saw blade at a consistent height.
I decided to build both hatches at once since they are identical except for their size.  I had some wood strips that were the exact height of the sides, so I cut those to the right lengths for the sides of each hatch.  I glued in some shorter pieces to create a ledge for the lids.
The plans show the lids as solid pieces, two per hatch.  Since I've been planking and staining the roofs of the deck structures, I decided I wanted to plank the lids as well.  My first attempt was simple - I just cut some planks and filled in the lid.  I wasn't happy with the results.  It looked like a single planked piece, rather than two halves of a removable lid.
I re-build the lids with a thin frame around the outside of each section.  This took a few tries to get a process that worked well.  I ended up building the entire lid for each hatch as a single piece, then cutting it in half and adding the inside frame sections.
Everything was then sanded and painted.
They ended up looking pretty good when placed on the deck.  I haven't added any of the hardware yet - I'm going to add all the eyebolts/rings on the deck structures in one pass after I get them built (but before they are glued in place on the deck).
I feel like I've hit a 'fun' part of the build - lots of small projects that go pretty quickly.
I have been waiting to seal the deck with clear poly until I had the major deck structures ready.  Now that I've got them ready, I need to stop procrastinating and seal the deck.  Before gluing the structures down, I installed a number of eyebolts and rings on the stanchions inside the bulwarks.  These won't be used for a while, but I think it will be way easier to install these before the deck gets cluttered.
I've decided to leave the brass fittings as unfinished brass.  I know that these would likely have been black on the ship, but if I paint them, I know the paint will likely rub off during rigging.  I've tried using blackening solution with little success.  So, I'm just going to leave all these as natural brass.
With those in place, I marked the locations of all the deck structures and glued them down.  Then I applied some Minwax Wipe-On Poly to give the deck a clear finish.  I've been using a satin clear coat for everything so far, but I decided to go with gloss for the deck.  It is only a slight difference, but I like having a little bit of shine on the deck.
Once the poly was dry, I finished installing all the various eyebolts and rings for the hatches.
Next it was on to the assortment of other miscellaneous things that need to be installed on the deck.  I'm tackling the rest of the deck in three 'phases'.  First I'm going to get all the 'stuff' installed on the quarter deck.  After that, I'll tackle the fore deck, except for the windlass and machinery.  Finally, I'll build all that equipment up near the bow.
So, on the quarter deck...
First up were the battons.  I had no idea how to make these.  I ended up gluing a bunch of 1/32" strips together, then sanding them down to get close to the right size.
The 'slats' are a little larger than the plans call for, but I don't think they look awful.
Next I installed the boom sheet buffers.  These were cast metal pieces.  The pieces were cleaned up, painted, and installed.  The fore boom sheet buffer has a platform that gets made from some laser-cut pieces provided by the kit.  Since I'm leaving rings and eyebolts as brass on the ship, I painted the rings on the boom sheet buffers brass to match.
I made the main sheet lead block horse from some brass rod, bent to the right shape, and installed it just in front of the main boom sheet buffer at the stern.
The main boom crutch was assembled from the laser-cut piece and some strip wood.
Next up were the quarter bitts.  I decided to use some brass rod for the 'arms' that extend out from the posts.  I'm not confident I could have made wood pieces look good at that size.  I glued some long pins to the bottom to use as handles during painting.  Once the painting was done, these pins were trimmed shorter and used to help secure the bitts to the deck.
I also installed the bilge pumps and stern chocks, which were all provided as cast metal pieces.
This completes the pieces on the quarter deck, with the notable exception of the fife rail.
I actually did build the fife rail, which was quite a project, but I'm not happy with it and will likely rebuild it with scratch-made pieces.  I knew the fife rail was going to be a challenge because I was missing one of the fancy 'legs' that the kit provides as cast metal pieces.  Rather than get a replacement, I decided to make my own using the little Proxxon lathe I've had sitting in the closet.  Surprisingly, they turned out great.  The problems with the fife rail came as I was trying to glue everything together.  The pieces were all so small and thin that it was difficult to get everything squared up.  What I ended up with is usable, but not as pretty as I'd like.  So I think I'm going to take a stab at making a new one from scratch.  If that fails, I can fall back to using the ugly one I made from kit parts.
Even though I hit a bit of a stall with the fife rail, I'm really happy with the recent progress.  The deck is looking more and more complete every day,
Wow! You are doing a fantastic job with these deck fittings! Excellent job! She looks very realistic!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Thanks Steve!
Tonight I was able to get the fife rail built.  This is my second attempt.  Over the weekend I built the fife rail using the laser-cut pieces provided by the kit, but I wasn't happy with the results.  The provided pieces are very thin, and I wasn't able to get them aligned well while gluing.  Things ended up being uneven, and the whole assembly felt flimsy.
So tonight I started from scratch.
I transferred the shapes for the rail and legs onto a 3/32" thick basswood sheet.
I cut these out using my Proxxon scroll saw.  (When I bought the scroll saw, I didn't realize how much I'd use it.  This small scroll saw has become the most-used power tool I own).  I made the legs and the posts out of single pieces to make the structure more rigid.
The bar across the top was cut by hand, and the holes for the posts were drilled out with a drill bit, then squared off with a needle file.  The slot for the boom crutch was cut with a #11 blade then cleaned up with a tiny needle file.
To make the 'fancy' legs, I stuck a length of square basswood strip into my little lathe.  I'm not very experienced at using a lathe, so as long as they turn out halfway decent, I'm happy.
Once the legs were done, I put some pins in the top using some short pieces of brass rod.  I drilled holes through the fife rail, and glued the legs in place.
The rest was assembled pretty easily.  Since I used slightly thicker material than the kit provided, the entire structure was much more rigid than the original fife rail.  This really helped when it came to sanding and painting.  I glued in some short pins in the bottoms of the legs - these will be used when I secure the fife rail to the deck.
For now, I'm leaving the fife rail loose.  I'm going to wait to permanently mount it until I start working on the masts.  I don't want to screw up and have the fife rail slightly mis-positioned and prevented the mast from being at the correct angle.
Overall I'm very satisfied with my new fife rail.  The material is a little thicker than the kit provides, so it is probably slightly out of scale, but I think the added stability is worth it.
I'm now done with the quarter deck, and moving on to the fore deck.
Dave:
The fife rail looks very good. At full size, your material would be about 2 inches thick. Perhaps a little beyond scale, but not by much, if at all. The cuts and finish came out beautifully. It is a nice piece of work.
Russ
Dave:
I do not think you made any sacrifice on the fife rail. I would have to check the drawings, but I would be willing to bet you are very close to scale. You are doing very well.
Russ
Dave - for future reference, I recall breaking the U-shaped piece of the fife rail during construction.  I solved the problem by gluing a piece of paper to the underside to put it back together.  The fix worked and was surprisingly rigid. It also took paint well.  Just an idea to put in your toolbox for possible future use - a way to strengthen the structure without adding a lot of thickness.
Your work on fixtures and fittings continues to be the best I have seen on any Bluenose.  Your attention to detail is paying off!
Bob
Russ, I got curious so I did some checks against the plans as to scaled sizes.  I used 3/32" thick material for all the parts, which at this scale would be about 6" thick.  The kit provides 3/32" thick laser cut pieces for the knees, and seems to indicate 3/32" thick material for the square posts.  The metal castings for the 'fancy' legs appear to be 3/32" thick as well.  So on all those, I think I actually ended up at the correct size.
The bar and the rail itself are 3/64" thick laser cut pieces in the kit, which would be about 3" thick if I did my math right.  I used 3/32" for those, so I'm at 6" thick - about double.
I think I only ended up out of scale on those two pieces, which I can live with.  Once I get pins in there and some rigging line, I don't think it will be noticeable at all.
Bob - I remember seeing that on your build log.  (And I was just looking at your log this morning!)
I didn't realize how unhappy I was with my original fife rail until I had the whole thing glued together and covered in primer.  The biggest problem was that I introduced some 'wavy-ness' as I was gluing things together due to the thin rail piece.  As I started sanding the primer, the force I was putting on it only made it worse.  I tried to use some CA glue to strengthen some joints, which made an even bigger mess :)
If I run into something like this again, I'll definitely try to strengthen up the thin pieces before I begin assembling anything.  I've got a 1/64" thick sheet of some hardwood I found at a local hobby store a year or so ago that would probably do a great job at adding a little more strength.
Lots of random work over the last few days.  I've now got everything in on the deck except all the bowsprit stuff / windlass / machinery.
The galley stack was pretty easy.  Just cleaned up the casting, removed the large 'pin' on the bottom and replaced with a thinner brass rod for mounting to the deck, painted it, and glued it in.
The 'jumbo jib sheet traveler horse' takes longer to say than it took to install.  Just some bent brass rod installed in front of the hole for the fore mast.
Then came the catheads.  I thought these would go quick, but they ended up taking a couple hours.  Part of the problem was that I couldn't find any good photos/information online that showed in detail how the anchor hangs from these, or how the ropes/chains are handled.  Lots of information about catheads in general, but nothing on the specific versions used on the Bluenose.  I did finally find a fantastic diagram on page 399 of Howard Chapell's 'The American Fishing Schooners 1825-1935'.  Once I understood how this would get hooked up, I decided to build them now but not glue them in.  I'll wait to secure them until I hang the anchors in case I need to make further alterations.
The cast metal pieces were cleaned up.  A hole was drilled in the fore side of each one, only halfway through the head, to hold the eyebolt that attaches to the bar.  Another hole was drilled all the way through the head from the top,  This second hole will be used to attach the chain.
The eyebolts that come with the kit are way too big for the catheads, so I made some simple ones out of some wire I had on hand and glued them in.
The plans show some sockets on the waterways that the base of the cathead sits in.  I decided to try and simulate these.  I cut a short length of a very small dowel rod and drilled a hole through it.  I rounded off the top, and used a razor saw to cut just a thin piece off the top.
This ended up making a fairly decent socket.  It doesn't have the detail shown in the plans, but I'm not yet at a point where I could pull off that detail on a piece so small.
The sockets were painted black and glued in after they dried, and while the paint was out the catheads themselves were also painted black.  Eyebolts were added to the rail for the bar, and the bar was fashioned from the thicker brass wire provided with the kit.
Turned out pretty well.  These were fitted on the ship, then removed and put back in storage until later when I mount the anchors.
The anchor pads were cut from some 1/64" thick sheet wood I had handy.  These were pretty straightforward, just small and hard to sand.
One last step before starting in on the bowsprit bits / windlass / machinery is to get all the belaying pins and eyebolts installed.  I had originally planned to do this later, just before rigging, but I decided it would be easier to do now before the deck is completely full.
Installation of the pins and eyebolts was typical - mark locations, drill holes, glue in pieces.  I was very happy with the quality of the belaying pins in this kit.  39 belaying pins and 20 eyebolts.
Today I'm taking some time to touch up some paint on the bulwarks, and I'm pulling everything out of the workbench and doing a complete cleaning.  Hopefully I'll be diving into the deck stuff near the bow tomorrow!
Thanks Russ!
Over the last week or so, I've gotten the bowsprit bitts/samson post and the engine box completed.
The bowsprit bitts and samson post were pretty straight forward as the kit provides the key piece as a laser-cut item.
The whole thing went together pretty quickly.
The engine box gave me a bit more trouble.  My first attempt was fine until I got it painted, then I notices a few too many imperfections in the wood.  I tried to fix them with some filler and repaint, but wasn't happy with the results.  The second attempt failed during assembly - I wasn't able to get it square enough.
My third attempt was successful.  This time I made a much more rigid internal frame for the box, then used 1/16" sheet material for the 'walls'.  The lift out door on the side was simulated by cutting one of the side panels halfway through (so it remained one piece, but looks like two).
The smaller part of the box was built similarly, but I left some open space on the inside frame since this piece has three holes in the walls.
The holes were made by drilling holes then using needle files to square them off.  They aren't perfect, but it is what I was able to do with the tools on hand.
The entire thing was primered and airbrushed white.
I decided to try and simulate the hinges on the top.  I used some thin brass strip I had on hand and some thin brass rod.  These were soldered together.
Once soldered, the three pieces were cut apart and each piece was cleaned up.  I filed away a lot of the solder (I always make a mess when soldering), and trimmed the brass strips to be shorter and tapered.  I touched them up a bit with some brass paint to make the color a little more consistent.  They were then glued on to the roof of the engine box.
I also simulated a small handle/latch using some thin brass wire that came with the kit.
I noticed after I glued it on the deck that despite all my attempt to double-check things, I managed to screw something up.  I glued the smaller portion of the engine box so it lined up with the outboard edge of the larger box.  It should have been even with the inboard edge.  I don't think anyone would notice this once the ship is done (except for me or another Bluenose builder).  So, rather than rip it off and risk damaging the deck, I'm going to leave it.
Fortunately when I was positioning it, I was using the inboard hole on the smaller box and the samson post as reference points, since the windlass/machinery touches both of those.  So really, the small box is in the right place and the larger box (which nothing else connects to) is just out of position by a small amount.
I don't think there is anything else I can work on to procrastinate - I've got to start in on the windlass and machinery.  It shouldn't be difficult, and it will be similar in process to a lot the work I did on some Model Airways WWI aircraft a few years ago (which use a lot of cast pieces to build up the engine).  My fear is that there is a lot of potential for detail with this stuff, and my ability to toss stuff and start over will be limited by the use of cast metal pieces.
This last week has been spent playing around with new toys to try and overcome a problem.
I recently started work on the windlass and machinery.  The first piece I worked on was the countershaft assembly.  My very first step was to clean up the metal casting provided by the kit.  This piece is basically a rod with two gears on it.
Naturally, I broke this piece while working with it.  I snapped the rod.
I cut the gears loose from the rod, and I am holding on to those as a safety net - I can always drill holes through them and slide them onto my own brass rod.
But...I just got a new Proxxon MF70 mill and I've been looking for things to try and make with it.  I decided to take a stab at making replacement gears using the mill.
The larger gear is 1/4" in diameter, so I started with a 1/4" diameter aluminum rod.  I used a 3mm bit on the mill to do most of the work, and a 1mm bit to cut the 'teeth'.  I used my drill press to drill a hole through the center.  The rotary vise for the Proxxon made cutting the teeth pretty easy once I figured out the # of degrees between cuts.
It took 4 tries, mostly because I was still learning how to use the mill, but I did manage to make a usable piece.  It isn't perfect, and the teeth are different than the kit-provided piece, but I think it actually looks cleaner and more precise than the cast piece.  Once this is painted, I think it will look fine!
I was very happy with the level of precision on the Proxxon.  It cut through the aluminum easily.  I'm sure it might have a tougher time if I were doing something larger (and the Proxxon is very much for model work, not larger-scale machining like you'd do with a bigger mill).  All the milling was done manually (turning dials) since I'm still waiting on the motor mounts for my CNC conversion.  (Although I have gotten all the electronics working and the control software halfway written).
Anyway, I haven't actually made any progress on the ship, but I've managed to make a gear, and I've very happy with that accomplishment for the week!
