Nice progress! She is looking great! She will look even better in the water!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
sweet looking boat Paul......you've done a great job so far  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Ok so I have a question. First... I made up a few test strips to test the fiber glass, long story short I did not like it I can still see the matting threw the resin and that wasn't going to fly. SO I asked my dad for advice, he suggested that I use some marine spar varnish being it was real mahogany instead of fiber glassing it. So I did some research and found out different methods and what kind of varnish people use to restore or maintain on the real deal the original Chris crafts. Now I've found one I like but I haven't pulled the trigger yet just wondering what you guys think of this method it would be a lot easier and in my opinion more realistic. I think I would still fiberglass the inside and bottom due to it being plastic and so it doesn't split like I've herd they can.
Opted to go with real boat varnish instead of resin and fiberglass method. I applied the varnish with Jen foam brushes. This left it extremely smooth and no brush strokes or bubbles. I chose this because I didn't like the way the fiberglass looked due to still being able to see the matting underneath the resin. I will however fiberglass the inside. This picture is at about two cotes, I now have four and plan to do 12 sanding between every two cotes.
That looks beautiful, you'll be happy with the result
I will be fiber glassing the inside. I used a marine varnish that is purpose build for wooden boats, that's what the salesman told me anyway. In the instructions from the kit it says not to fiberglass the bottom due to the resin possibly having a reaction to the vellum so I will be varnishing the entire boat.
Wow looks a million bucks. I like the decal
. Good work.
Regards, Scott
Completed builds:
Awaiting construction:
  • 2 months later...
  • 3 years later...
Regarding sanding the chine. I’m still a bit confused. Before applying the PVC clad. Should I sand the outer edge of the chine so that it is flush with the sides of the frames, Dumas says leave it alone, Matthews says sand it. Thanks🙃
