Well it has been some time since I have had time to get moving again on Bluenose.  We wait so many months here in Maine for summer that we need a little break.  Summer here is so packed with real sail boat racing, summer parties, hiking, yard work and friends and family visits.  Let's see what I have been able to squeeze in since starting summer in early June.
i started by saying i was going to figure out how to make baggywrinkles at this scale for my summer activity.  I showed the drawing from the classic instructions in my last post.  I got that ans instructions from a colleague rope work craftsman, and sure enough my trying to do it right proved to be tough.
i set up a jig using the rope walk kit to stretch two lines[ black]  I then tied the loops per the instructions to make a real one.  Pulling the natural lines from under the two lines up over the outsides and down through the middle.    We then slide them down to the end and pull them like a hitch.  Here you can see the first 15 or so strings pulled tight and trimmed as well as the second batch pulled and ready to be trimmed.  It looks like one is upside down and needs to be removed. trust me...it is harder to do than it looks for those of us with stubby fingers.
i did this and some where between 40 and 50 lops got me an inch which should be long enough to wrap a lazy jack to make one baggywrinkle.
here you can see i put in a mock line to be a lazy jack.  I then wrapped the one inch assembly  roughly 6 or 7 times.   What I have is a real mop.  My conclusion is  at this moment this process is too intensive.    I need 26 of them for the lazy jacks, and also they are not really attractive.  I visualize if I used smaller thread in both parts it could be 100 knots in an inch and more dense etc. the real lines though where somewhere between 1/4 or 3/8  so it is the "fuzzy' aspect of old manila that is not present in new thread......maybe.    I am back to the drawing board and looking for alternate solutions.   While reading other posts, I have seen good solutions for the smaller scale. Pipe cleaners and example.  at this scale...15 inch average means about 1/2 diameter...maybe sponge??
i tied up a few more stays around the the bow.
The result is still not great but I feel better each time I try to taper the heavy thread and get a more realistic splice under the wrapping. The white wrapping of the boat exaggerates the detail.  Maybe the next one will be better
I made up a real rudder.  even as a radio sail I thought the need to show how it was really made was important
Since this rudder actually works, I need a little license on the hardware
A close look shows only cosmetic use of hardware as the brass rudder rod seen entering the rudder on top and bends in an L shape is the actual control.  A second brass rod also a L shape goes down to be captured in the extended keel.   For potential radio sail there are two slots for Popsicle sticks to add extra area to the outer edge of the rudder.
I end this post with a tease....I have made the main sail and foresail and they will be in the next few postings
Here you can see the large size of these sails.   Also I want to furl them....I think it worked..stay tuned i'll organize the photos
cheers
I still have not decided if I will ever sail this boat.  As part of the options in how to possibly be able to display this model with the most detail but still be able to move it, I need to be able to un-step the masts.....move the boat.....set it up in an hour or less and then repeat the process to go home.  So far I have the peak and throat halyards only on the main and similar but different rigging on the fore.  Going forward to the next step and still have options, I have decided on the following:
  1. see if I can make full size sails and then furl them.  at this large scale that might be OK
  2. find a way to temporarily attach shrouds at the dead eyes.   The stays are no problem as they have turn buckles below and shackles above.
  3. continue to add halyards and running rigging knowing I need to be able to untie and retie.  tangling during movement is a hassle so far.
  4. be able to un-step and re-step top masts as an alternate. The model is then a fraction under 4 feet tall.  This is my best option and my current plan. i am trying to learn where the blocks were mounted that carried lines through the sheave at the bottom of the top mast.  This was a common function with the four masted schooners as well as they some times needed to lower their top masts to go under bridges.  I find no information yet on this detail.
Here we go on the first step.  can I make muslin sails to full size and fold [ furl] them to where they look realistic.  I have used simple Muslin to nicely represent the sail cloth.  Many folks go to foreshortening cloth or substituting silk span etc at smaller scale.  i wanted to try this to see if at 1:24 i am ok with full size sails...let's see how it goes with the biggest one first.
  • Here I have laid out the sail as per the scaled up plans. It is important to follow the roach as that is how the seams were made.   The lines are about 5-6 inches long making a nice arc.  An old fisher plan showed straight lines and the outer most strip curved to make the roach.  I have laid out the reef lines and plan to leave them on the cloth but not add bias tape for doubling since I want to be compact.
  •  A previous lesson learned is to lay out the model spars and be sure they fit before final marking and cutting.  I find typically that to simple cut out sails per the plan, add bias tape to edges, stitch etc. they tend to be a bit big.   I am also no seamstress!
  • The gaff looks good
  • Here we can see we are about 3/4 inch too tall.  So I had to raise the foot, adjust the reef lines and roach a bit before cutting.
  • Now the sail is cut, bias ribbon glued and then sewn on.  All the seams are also stitched.  I had some tension issues as I chose incorrectly to keep sewing around and around and did not allow for stretching out the seams [ as My daughter just explained to me yesterday].   Anyway the minor puckering mostly ironed out and as you see with the first attempt to flake the sail are not too visible.
  • In this step i determined the bulk was looking good, so I proceeded, as on other models, to select a hemp twine more for color to hand sew on to be the bolt rope. as often the case, it comes in 10 and 20 weight and I would have loved to use a middle size that just isn't there.
  • The bolt rope is sewn on, I have folded and unfolded and now sewn on the hoops  I had purposely installed three extra hoops to the mast so that if one broke or was weak I had an option. If I had needed to add a hoop that would be hard as the whole process would have to be done insitu.
  • Here is a detail of the hoop sewing.  I plan to revisit Lunenburg and study details like this some more.  I likely will not upgrade this model but I am sure there maybe a better means to replicate perhaps with grommets.  Again being furled I am escaping some scrutiny .  You can also see the reefing pencil line without the doubled cloth
  • Now we fold [ flake] then touch with the iron and fold again, matching up with the hoops.
  • We are almost done but i felt i needed to lash on the gaff before completing
  • Here I have lashed on the main sail foot to the boom.  On the real schooner, the photos show individual lashing with grommets.  If the sail is to displayed raised I may upgrade that in the future. At the moment it is an oops, as I did this work and then found my error.
  • Here we have sail flaking almost finished.  The lashing of the head to the gaff is under way.   You can see the loose throat halyard on the table.  It was a bit of an effort resetting and untangling that after all of this as I re-stepped the mast.
I get there in the next posting
cheers
jon
Hi Jond:
Very impressive. It's easy to look through this log and forget the scale - until you see a shot of the main sail on an ironing board and remember what an incredible project this is! Wonderful stuff - despite the difficulties of doing so, I hope you do sail her eventually - I would love to see some shots of that!
hamilton
Thanks Hamilton
I just finished making lazy Jack's for the foresail. I am rushing through several items to make my list of 'need to learn' as our trip to Lunenburg is now only weeks away.
Like you seeing the large size sail, I often wonder why.  I am having fun and learning so that is why.   I have now determined my plan is to finalize all including the main masts.  The top masts are being rigged to either be in place but removable for transport  or be shown being erected.  Learning how they did that is my big search.  Also thinking about weight, they must have been able to run the engine with the windless unengaged, to help haul up the sails when fishing.  I know how the bigger schooners rigged this but find nothing yet on these boats.
Cheers
Jon
N
It's time to start replacing main mast and take a look.  Then it's time to make the foresail and see how these sails came out when back on board.
  • Here we complete lashing the main sail to the boom.   As stated last time I found this to be an error for attachment should be individual lines tied through grommets.
  • Once we roll it up an lash it, as in the 1940 photo, the lashing seems to disappear.   The black lines will get changed out for dark tan when I get some.
  • now back in place, I added the bails and 7 parrals and then re-rigged the halyards.
  • finally we have a bent and furled mainsail.  I am sure it is not perfect scale but it really makes me smile.   With all the ironed folds[ flakes] it would be a mess to pull it up , but if challenged I can raise it up.
  • further to the scale issue, I fear the hemp bolt rope is a little too pronounced in this flash photo.  I sure wish i could have found a medium size.  maybe next time I am back in Joann fabrics.  Now off to make the foresail
  • I basically followed the same process; here we are all done and ready to install.
  • Looking here again I am not happy about the bolt rope. Maybe as I add all the lines it will fade away .
  • here I see the height of the gaff is due more to the hoops that are a little big for strength, but backing off maybe we are OK. It is just more pronounced than the main due to the short length.
  • Two sails are done and since this is my first ever attempt to make furled sails I am ok with them. My lessons learned are to do them before rigging halyards to avoid a lot of fussing and untangling, find a more suitable bolt rope, fine mini-grommets for the foot and maybe a thinned method to double cloth and make the reef point strips, clue reinforcing etc. i normally have used bias tape and that makes three thicknesses of the cloth.  Maybe an iron on or tape method.
  • now off to get the forestaysail on and to start rigging lines.
  cheers
jon
During these weeks I continue to tackle different items trying to figure out what I don't know.  This update completed the three sails for now [ I'll hold off on the jibs for a while].  I need to rig the sheets, lazy jacks and early shrouds and top masts rigging.   Here is part of what i did in the last two weeks.
  • I have used the same technique for this forestaysail as previous builds.  I sew the rings into the bolt rope to replicate hanks.  It is a bit tedious but it works. I still only have the No 20 hemp jewelry twine.
  • I had a little struggle feeding the previously spliced forestay through the hanks, but we made it.
  • 59bac8a59e631_bn_1012cDSC_0123.thumb.jpg.da7bbc3f4bf2b60128de19c42d0021f9.jpg
  • Here we have the sail bent and remounted on board.  I will change out the black lines when I get some more good tan twisted rope.
Now we have several deck items needed for rigging. I thought to do the sheets next. First i completed the halyards on the foresail.
  • to rig the foresail and forestaysail sheets we need to have fair leads.  reading about the early 1910 and newer schooners where I found they used lignum vitae a very heavy dense wood. I chose to use tan glass beads to replicate this detail.  Here are the four [ low tech] steps I used.  One is to to prebend light brass around a bar of similar diameter.
  • Here I crimp the bend to make it tight. I then drill holes for a pin.
  • here i have inserted the pin.
  • Here I hold it as the CA dries. If I were smarter i might be able to solder this but I chose to use CA and so far it worked.
Now we are off to the shrouds and cross stays.  Since I have decided to make the lower masts fast  it is time to move on.
  • on 1:48 scale I was able to do this detail using pins.  here I do not like the look and in the Nova Scotia Archive photos the bolts are quite clear.
  • Here i am experimenting with O-90 hex heads and I like what I see for scale. I rebuilt the wire wraps and the nut and head hold them well. I am also also struggling to understand if the belaying pins were metal or wood.   I painted some of them galvanized and will decide after my next trip north.
  • here the foremast set of dead eyes is done and ready. It looks in the photo like I need to revisit the gold tape in a few places.
I thought I would end this update with another of my oops.  they are fun and many.
  • I needed to build the missing capstans for the donkey engine.  Perhaps in a race the huge crew may have pulled up the sails.   While fishing however, with only six dories,  a crew would have been under 20 and there surely was assistance in raising the sails.   This whole thing is a big part of my upcoming research in Lunenburg.  Anyway the oops!
  • I took a simple dowel in the midi lather and turned these two pieces.  The large outer ring has a nice indentation just like the real thing....but
  • oops it is backwards. The small end should be outside
  • here I remade them in the correct orientation and size.  I am not totally happy yet as the reals one were spun metal.  However they are there and ready to have some traveler lines wrapped as soon as I confirm the routing to either raise the topmast or big sails.
I include this view...a little ahead of the process [ fore mast shrouds are complete]  , but it is fun to see how the overall progress is coming.  I will do the shroud show next week.
cheers
I would like to make this posting as the end of a phase where I sort of knew what was what as to the fishing schooners.  In the next posting I shall share my experience in Lunenburg this month and the impact it has on one studying these great boats. Before I do that I have a few more things I did and I would like to get them logged.  I wanted to start getting the sheets and running rigging on deck completed so I could go ahead and get the shrouds in place.  I also throught this would get me further along in preparing my list of questions for the trip to Nova Scotia.
  • 59d8dcb809806_bn_1016aDSC_0109.jpg.713bcdaf7841538925d37e39732f0150.jpgI wanted to use lines that best replicate the size and color of the real thing.  I bought a few samples from Syren and boy are they great. Thank you Chuck!   Here I am using the line and splicing it to a shackle for the first sheet.
  • 59d8dcb8a99f7_bn_1016bDSC_0117.jpg.e478414dc02418a405a3f7db19e6b9df.jpgHere the jumbo sheet is rigged and passes through the fairlead to a pin on the fore mast rail.
  • 59d8dcb95e390_bn_1016cDSC_0118.jpg.898f6ca568cf1634efbf0990501391e3.jpgHere the sheet feeds through the blocks then the fairlead to the port bitt.  I had to reverse the buffer location with the horse [ and fairlead] from the Eisnor plans based both on the photos from 2014 in Lunenburg and the sense of how they work. my buffer is only a shaped dowel
  • 59d8dcbd8f905_bn_1016dDSC_0125.thumb.jpg.374ed529b14502251c23df03cb0bef33.jpgHere the main sheet is rigged through a single block [ as shown in the 1940 survey photos] to the port bitt.  I again made up a buffer with painted dowel to replicate the rubber fitting.
Next I needed to get the shrouds in place.  My plan is to keep the model with the lower masts in place. The top masts can be removed, so at 4 feet high we can possibly move the model.  The issue then is to get the top dead eyes reasonably straight and the process to become sort of an assembly line.
  • 59d8dcbe3ada6_bn_1017aDSC_0121.jpg.278959921b96ca74f47180570c53e50b.jpgStep one is to make a jig and clear the deck so the upper dead eyes can be attached at a common height
  • 59d8dcbebc483_bn_1017bDSC_0122.jpg.a5f8b468076917e14e17796b995bec2c.jpgStep two is to lash them  leaving the tail loose.  On this first go i did one at a time.
  • 59d8dcbf4dc0b_bn_1017cAAA_1180.jpg.60d56caf9d6c0d7c0f68903e88e41e03.jpgTo be able to splice while the top end remains attached, I upset a stool on a stool added a shelf and sewed the splices in place.
  • 59d8dcbfc74d8_bn_1017cDSC_0102.jpg.232ca6f67a2a6172dd3ef6a8dbedb9cd.jpgI share this image of splicing a shackle for the top mast shrouds with a smile. As I shall show in future posts following the modeling plans that suggest little eyes at the top of top masts [ thus needing shackles] is an oops.  They are all hoops!
  • 59d8dcc119705_bn_1018aDSC_0134.jpg.8d95b923fea09fbc3953b86bcccc4846.jpgHere we are with a full set ready to tie together. yes a little more adjustment to get straight.
  • bn_1018b.jpg.1946b4cae3c782dcf481075f2ded97da.jpgand here the steel rod is lashed and parallel to the rail.  I choose distressed white for the bar because the 1940 photos clearly showed them to be white as well as the paint on the seizing going up about a foot.  I may choose to add the white paint later but more thought on that first. i want to see how the Bluenose ll finished the lashing before I complete these.  one of many questions.
  • My final act before travel was to add the crotch tackles to the main boom.  They help hold the boom steady so I am glad i did. There is an additional turnbuckle security chain to be added as well. I have them but want first to see what I must do to complete the booms and then work outward.
cheers
jon
Now off to Nova Scotia
Hi Jond
Seeing your ship, and the progress that you've made in her, just makes me think-huge in size, huge in impressiveness (if such a word exists) and huge in impact!
Having said that, I'm kinda chomping at the bit to see her underway.  That'll be a sight to see.  You're probably not far off, now.  I'm impatient, I know.
Cheers.
Patrick
Patrick
thanks for your kind words.  as you will see in upcoming posts I went to Canada to ride on Bluenose ll and learned so much about the boat.  I am thinking more and more about being sure about making the rigging work. also to be able to move it around I have chosen to furl the sails.  thy are full size and it is possible to unfurl and raise them and go for it and I may do that some day.  But weather is cooling down, so we are back in the shop more and look forward to learning to make more parts.
59dba3a3139ab_bn_1020vbluenoseiiforaride.thumb.jpg.10e6d5d5300f1230ed1ae87566badddc.jpghere we are last week sailing in Lunenburg in almost 20 knot breeze
cheers
jon
This posting ends a long phase of my work and introduces me to a whole new era.....I hope anyway.
To all those lovers of big schooners like Bluenose, Gertrude Thebaud and the rest all I can say is two trips to Lunenburg is a must.   I mentioned early in this log that we made a visit there in 2014 as I was getting going.  We saw the Bluenose ll that had recently arrived at the dock after her 2012 rebuild. The team was still working out items to get ready to be recertified and then resume sailing.  We then saw all the wonderful models in the museum, bought a few books and I was prepared I thought to get into this build when I resumed it last year.
Over the past several months as I dug deeper I found the Nova Scotia archive photos of the real thing or my photos of models or BN ll from 2014 were lacking in many details.  I also did not understand the synergies between the original Bluenose 1921 and the replica built in 1962 as it applied to the rigging.  I learned early this year that they offer 2-hour sails and wow was I in for that.  I started detailing questions and needs for new photo research.
This September we went and had a great stay in that beautiful town.  Our sailing day was to have been the 28th.  We learned a bad weather day was coming so fortunately we bought extra tickets for the 29th.  We arrived on sept 27 in the evening and learned the sailing was already cancelled for the next day.  Walking down to the dock after dinner, we met Captain Phil Watson the skipper and had a great dialogue.  example
  • he explained that to lower the top mast they string a cable becket over the mast cap with two blocks.  then the 'fid'   the hole through the mast is drilled and burned with hot iron into a curve so the lines feed through.  This detail he explained is the Canadian solution.  The American schooners inserted sheaves.....My mistake 1 of 21 was to have already installed little brass sheaves...oops  I need to repair and will record.   Captain Watson then confirmed that yes of course the old Bluenose as well as other boats this big all use their gas engines to lift and drop the big sails and the top masts.  Those lines of men in the photos are hauling up topsails not the big ones.
  • he agreed with me the top mast shrouds were moved forward and a sixth shroud added due to coast guard requirements; thus, BN ll is not rigged exactly like plans for Bluenose...yeh I got that one right. Overall, he said I would not find other variances as they are serious about maintaining those items.  Example: the aft toping lift sheaves are in the boom and not on the side as shown on Eisnor plans and invisible in the archive photos.
  • more importantly to me, the crew on duty saw me talking with captain Watson, so I could ask them anything.  I must say they are a great bunch and study or no they make it a wonderful outing. One lad was happy to demonstrate up close how the lanyards are used to dog off the halyards to hold them while they are removed from the windless capstan and made off to their bitt or pin.
  • 59dba94abca20_bn_1020lAAA_1190.thumb.jpg.edad0cbfce8c8980c1eadaf1c07ceb3a.jpgthe next morning, I came down early before the rain started and spent an hour on the dock taking many photos of what I did not get in 2014.  I then went on board and spent another hour.  Several of the crew were great confirming how they rig the fisherman stay sail, topsails and identifying a mystery extra line just for lifting things on deck..  The Blocks made to staples on the deck for several lines do not show an any plans, the chains and cables used on jib and jib topsail sheets were great to see as they are stowed.  The sails all furled and secured is how I plan to do the model so this was extremely useful.  Who new…the Jumbo hanks are lashed to separate rings on the fore stay….more rework for me.
  • 59dba8ad9ddde_bn_1020bmoringonboardAAA_1208.thumb.jpg.be6921d484cb78ac5949254cc4aed2b0.jpgI was able to photo everything and label them in note books.  I could never have done this with 65 passangers and 18 crew sailing so I was very lucky for this rain day.
  • the rain then came and we were off to the museum for great research and lunch
  • three people on board and in the museum, all recommended I buy the book by LB Jensen.  I chose not to in 2014 simply because it said Bluenose ll.  When one reads it it explains the level of care that was used to make Bluenose ll a real replica so all the measured drawings and details are real.
  • This book is a real need for a scratch builder wanting to focus on rigging and really understand how these boats worked. It is available either through the museum store or the Bluenose ll store on line.  I bought several other books too as each one seemed to have additional photos and insight to the life and beauty of sailing.
The next morning  wow wow wow
  • 59dba8a4d7b94_bn_1020eAAA_1282.thumb.jpg.c9cf70607fb180fdfafbf26fa9a5e46f.jpgTime to raise sails
  • 59dba59f1c917_bn_1020wbluenosesailing.thumb.jpg.2434a192a5641dd20eaa08ed13e5c27e.jpgWhat can one say!
  • 59dba8a88e83c_bn_1020fAAA_1317.thumb.jpg.a3cad28f9821e98b5149bdf5dc523598.jpgSailing out from Lunenburg
  • 59dba8aa823ff_bn_1020kDSC_0292.thumb.jpg.bb1adb8dda5b8eaf116904378a3a117b.jpgCaptain Phil Watson giving sail down orders
 Nine crew members furling the main
So what is the next phase of this build
The short version is I listed 27 items where either the plans did not explain, or in a few instances disagreed with the real thing.   Again, the plans I refer too were drawn for either a 1:64 or Eisnor 1:48 scale model.  My effort at 1:24 needs to get a lot more of the rigging right.  I will write up many of the items, showing what I thought or where I was stumped, what  saw or learned on this trip, and ultimately what I do in my efforts going forward with the model.  I have so much to learn and it is so much fun.
cheers
Jon
Here is the first in a series of clarifications or corrections made based on the recent trip to Lunenburg. I shall post them as i complete them.
Both plans by Fischer and Eisnor are vague at best about the outer boom lift, mid boom lift and lazy jacks.  They both indicate a sheave to be side mounted on the boom. Eisnor shows no outer boom lift.  The photos I took in 2014 did not go that far aft on the boom and the archive photos are not clear on the rig at all. Another detail is the clew of the mainsail connection. it is not clear on any of the plans or photos. The fisher plans did show the outer boom lift with side sheave leading to cleat perhaps 20 feet forward. They also show a reef tackle line cleated near the end of the boom.
  • 59e23521e8f0c_bn_1021aDSC_0127.jpg.4c62bfc1b92847c138d8717267fc8233.jpgHere one can see my progress on the model included a side sheave that I have temporarily used as an out haul for the main sail.   this approach is wrong.
  • 59e235228e645_bn_1021bbnmainboomsheaveclewring.jpg.992a51638f798884ff0ce4db2970cfdf.jpgHere is the detail on Bluenose ll.  It's interesting for a few reasons.  Note there is only one through bolt holding the forward sheave.  Also there is a shadow suggesting a larger diameter hole through the boom at the aft sheave. That suggests a through pin welded internally and possible installation of that sheave first in sequence through the side.  There is also a bolted bail holding the mainsail clew at a fixed point.  In the larger photo all the remaining aspect of the outer boom lift is shown with the large line shackled and the smaller line spliced directly to 6 inch ring held by  a pin through the vertical band tabs. Also there is no evidence of the reef tackle being rigged either here or in other photos while under sail.   They did have an effective down haul on the gaff head used as well for the flags, and that was cleated to the boom. They pulled on it while lowering the sails...  more on that later.
  • 59e2352310e6c_bn_1021cDSC_0462.jpg.ca82f058c96d2ec1a3a4090664ba12dd.jpgHere is my solution. I show two through bolts for the sheaves.  I have used a temporary ivory colored line through the block and sheaves and it goes to the pin in the boom jaw port side.   The boom tackle line I needed to move over to the starboard side jaw pin.   i have ordered more tan lines to upgrade this installation.   I am debating if  i need to modify the end band to have two vertical tabs to house the pinned ring as on the BN ll.    maybe later .  I did use new #90 thread bolt to hold the bail for the sail clew.   I now know that I have to un lash the main sail from the boom and retie individual lashings using tan lines....a future punch list item.
cheers
jon
Edited by Jond
I couldn't stand it...I must be nuts
  • I went ahead and rebuilt the boom end topping lift band with top tabs and ring and added the shackle as I upgraded the line to a tan twisted line for the outer boom lift.
  • 59e3c1dd68396_bn_1021dDSC_0477.jpg.73f20d7d8e8a028bf69ec346b594571f.jpgI also started replacing the sail lashes with the first three also using a tan line.  The ends are spliced through using a fid so I simply sewed them on either side and left them loose.  It will be really hard to do the rest now the boom is in place.
  • Other than the more beat up color of the Bluenose ll boom,  the brass fittings needing black or silver paint and the over sized bolt rope, this photo now almost looks like the real thing. I need to move on or I will be remaking the sails.....argh  I also need to get back to figuring out how to do the baggy wrinkles at this large scale.
cheers
jon
Edited by Jond
It has been a few weeks and I have used the old trial and error method more than once.   I also went to Arizona and road on a mule along the south rim of Grand Canyon.  please believe me; that was not my idea.  It was pay back for her going with me to Lunenburg.
Today I want to record the several items entailed in my effort to bring the masts up to snuff regarding the need to be close to true detailing at this large scale.  This post affects the top masts. First lets look at Bluenose ll and refer to the newly aquired Jensen plans
·         59fdf8dd24f37_bn_1022aDSC_0137crop.thumb.jpg.33529245385561d388e2a1893cc9e022.jpgHere is a cropped photo taken in 2014 of the fore top mast from the port side. The black clips forward of the top mast for furling the topsail are clearly shown here and on the Jensen drawings. The drawings show seven, but the photo shows six.  One can also see the black rod that grabs a through bolt carrying the top mast load up to the mast cap. On my model I had attached that rod to the second to top band as had others in the Lunenburg models I saw while there in 2014. A very small detail I learned while talking to the Bluenose ll captain the night we arrived.  The small blackened hole at the bottom of the top mast, just below the bolted rod is the Canadian style fid.  It is a drilled hole slightly chamfered and blackened with a hot iron so the boom hoisting line will run through.  The American schooners inserted a sheave at this point to facilitate raising the top mast.   A becket cable [ double ended spliced cable] with two blocks are draped over the mast cap to carry that line when the masts are set or lowered.
·         59fdf8ddeb039_bn_1022bDSC_0149.jpg.bd2d4d9ba2408fa645de5d1c58d94922.jpgHere is the same top mast in 2017 from starboard side with the top sail furled.  The furling favors the starboard side. There is also more clarity in this shot of the iron work holding the jumper stay and main topmast stay to the mast cap assembly. also note the rings holding hooks on the large peak halyard blocks.
·         59fdf8de79aef_bn_1022cDSC_0150-Copy.jpg.51ce08b53294dc7a822f8a74412d5586.jpgHere we see a cropped photo of the main top mast. There is a significant shoulder in the mast. Here they painted the top section white and the top ball gold.    Looking at the Jensen plans I learned the disk at the top of this section holds port and starboard sheaves for flags.  The flag is on its own spar and run up to the disk.
·         59fdf8def2b7c_bn_1022dDSC_0151-Copy.jpg.76561bee095eda31eeedce03b0054f4f.jpgHere we see the fore top mast.  A similar detail with a 5-foot extension above the shoulder.  On both masts, all for the stays and shrouds are spiced loops draped on the shoulder.
·         59fdf8df72e41_bn_1022eDSC_0151.jpg.86478ccc539d2e7c537f38ded95fe826.jpgHere we find the jumper and top mast stays are each made of two pieces joined at a fixed block. I did not get an explanation why as they are made up as the mast is raised.   The main fore stay by example is made fast before the top mast reaches its peak position.
·         59fdf8e005a5f_Bn_1022fDSC_0179-Copy.jpg.9b1e9ae065685ac50c41cc48fa70831c.jpgHere we find a cropped detail of the gate holding the top mast in place.  The whole thing is very tight, and I need some work if I want the top mast to come out for travel.
Now let’s look at the model and see what I had and the fixes
·        59fdf8e075012_bn_1023aDSC_0460.jpg.b0cde12adf42fca6963e484ebbadc642.jpg Here is the fore top mast.  Based on the modeling plans small iron bands and many eyes are placed at the top to carry stays and shrouds, halyards, clewlines  flags etc.   oops
·        59fdf8e0d9ebc_Bn_1023bDSC_0461.jpg.e707bbafb03c84838a6c6130258ff7ab.jpg Here is the main top mast note the lack of significant shoulder needed for looped shrouds
·        59fdf8e167e15_bn_1024aDSC_0463.jpg.6972e9de032f7b603757ffefbc731b3a.jpg For the first fix, before removing things as I was still dithering on how much to undo, I made up the three small cable connector blocks.
·         Bn_1024bDSC_0465.jpg.bfff613e7079e93b483672a43cf4d64c.jpgHere the first one is connected at the desk top
·         59fdf992a3bf1_bn_1024cDSC_0466.jpg.36e41dca1c6f96800d9870c8932112ed.jpgHere is the first one in place
·         59fdf9932c48e_bn_1024dAAA_1484.jpg.a6709a00f0da14397c4d8d531813b692.jpgHere all three are done and in place……oops too early as I finally decided to do much more.
·        59fdf993a0ab5_bn_1024fDSC_0467.jpg.781b28fe6eab3640c38f831c065b15ce.jpg As part of this process I got out the serving machine and started finally to us it.  I seized about three inches of each top mast pair of shrouds and then made the loop and over wrapped to make the slice.  It’s a good detail, but I do not think very visible at the top of the redone masts. It was however fun to learn to do. The first ones are sort of OK like everything else it takes time to get them good.  I also just read an article suggesting using varnish instead of fabric glue. I want to try that
Now the top masts.  They needed to be rebuilt.  The Jensen drawings gave me much more detail. And I needed to remove damage from have installed sheaves.
·         59fdf9941da32_bn_1025aDSC_0469.jpg.09b01bcdf79c8a3840680993d2fa12ae.jpgHere you see the bottom of the main top mast.  The sheave is there and the rods that held to the band on the main mast.
·         59fdf99493974_bn_1025bDSC_0470.jpg.e923172b08133f28b3a80cf11b852c53.jpgHere is the top with all those blocks. Note there is no real shoulder and reduced top section nor a disc below the ball.
·        59fdf9952e32e_bn_1026aDSC_0471.jpg.03433a57aa74f1c94fdd3cc4ea00f78c.jpg Here I did a measurement and decided that the top 5-foot section could best be attached.  It is to be a pinned dowel. That better reflects the shoulder that was not evident in my current mast.
·        59fdf995c08cf_bn_1026bDSC_0472.jpg.fef8354b354352038f7ab49bc4a36f78.jpg This decision allowed me to cut off the offending bottom
·         59fdf99658603_bn_1026cDSC_0473.jpg.9a8a9c895a2595bab4ae0884bbeecc70.jpgThis is the new shaped top section of the mast.  The Bluenose ll is painted white. I will not paint it but leave is natural like the bottom of the main mast that is visible in the old photos
This is the point of decision.  I have been convinced for some time that if I could make the top masts removable I could figure out how to transport the 4-foot-high model. Perhaps even display the main top mast being erected.
·        59fdf996f1947_bn_1026dAAA_1485.jpg.ba74380338995cca0ef2afe3f6adde45.jpg So here is the possible set up with the main top mast being lifted.
·         59fdf997863ef_bn_1026eAAA_1486.jpg.dd4194db935f2d9c8a3c1d7d1ceafa54.jpgHere is closer shot where the shoulder is holding the new shrouds in place. There are still two blocks, forward for the fisherman staysail and aft for the top sail. The topsail clewline block is sewn onto the sail, and the two flag lines use the sheave in the disk.   The disk is a copper washer with holes drilled.  I have yet decided but as of now no gold paint is going on the ball.
·         59fdf99835357_bn_1026hAAA_1495.jpg.62e5eb16de48da1b2a9d87e208580ef2.jpgThis is the same picture just in the early morning with the bright Maine sunlight pouring into the shop. The Jensen plans show the furling clips on both masts.  I have a 2014 photo where they were not on the BN ll main mast.  With the topsail furled in 2017 I can’t tell.  I decided to keep them based on the redrawn plans
All for now
cheers
jon
Thank you Johann
we are trying and learning so much, but I have so  much more to do.
I looked at your video and found them so inspiring;  the crispness of the metal work ...  wow.
thanks for looking in and thanks for your sharing
jon
This posting is to record two more items on the list of corrections involving spars
Jaws and parrels
·        5a04b6d52438e_bn_1027aAAA_1206.jpg.8aaf46cbfb3d4aef1367a4d9c0f4957b.jpg Here one sees the correct dimensioning and counting.
·         5a04b6d5c3195_bn_1027bDSC_0476.jpg.662c44831c9f40d4943b3370e61003e5.jpgThe model plans had very long jaws.
·        5a04b6d65b69c_bn_1027cDSC_0484.jpg.3cace9361e20dd77b56955da3c0ed172.jpg Here you see the extension forward of the mast.  The Jensen plan gave much tighter dimensions and the pencil mark is right.
·         5a04b6d6ddf9a_bn_1027eDSC_0487.jpg.e205517c00dc0649147eaa2c2ba35f7e.jpgHere you see the large beads I used for 7 balls on the parrel.  The size and number for the main was smaller and 9 each.
·         5a04b6d7626e7_bn_1027fDSC_0502.jpg.ae203f39c72c2f98ea339769f8d752d1.jpgHere is a the main fixed
Mid main boom topping lift.
This goes lift up slightly forward of the main sheet band.   Model drawings did not agree, some show common with the main sheet band.
·        5a04b6d8825c3_bn_1028aDSC_0143.jpg.04b732438011b4734e10ab1b4cdb9b76.jpg Here we see the proper fitting for the mid topping lift on the main Boom.  Note the two horizontal tabs and vertical bolt leaving a gap of about 3-4 inches.   There is a bent figure eight ring angling upward to carry the spliced cable boom lift around this bolt.   Behind the bolt the outer topping lift lead is fed on its way forward to a pin on the jaws.[ port side ]
·         5a04b6d960212_bn_1028bDSC_0127-Copy.thumb.jpg.e3775322140520f10df6252692c2a7e6.jpg
See on this photo there are two becket cables wrapping the mast above the second band.  Two small ears support the dead load before tensioning the lines.
·         Here we see the ring on the model based on not having enough 5a04b6d9e4a02_bn_1028cDSC_0501.jpg.dcba547b18b2a5834f79f98fadb5ce84.jpginformation.  I had two rings to pick up the lift.   There is also confusion on the model drawings that the Jensen drawings correct as to where these lines go.
·        5a04b6da77e56_bn_1028dDSC_0504.jpg.bb3a882ecb23dcc2a3fbc098ea5314a4.jpg Here we see the corrected band with figure eight bent ring, shackle and spliced steel cable.   Now I need to figure out the baggywrinkles.  They are about 1-1/2 inches long and roughly a ¼ in diameter.
·        5a04b6db06980_bn_1028gDSC_0509.jpg.a99c7f09c4e11c5b49090f187ceb0c0c.jpg Here we see the just installed top blocks on beckets.  The paint on the blocks is being touched up before I run the lines.
onward we march
cheers
jon
Add back stays to rerun halyards on the main mast:
I mentioned in an earlier post that I found in Lunenburg that most lines are a rich tan colored hemp traditional style.  To replicate that I went to the Montreal hobby store and got several sizes of their tan lines.  Rigging lines on board adds a challenge for making splices.
·        5a05e6aae31fc_bn_1029aAAA_1499.jpg.f13355d1a58ae110bccb104dcc180b34.jpg Here again I have set the spare hands on a stool and after running lines feed them out to allow splicing.   I then pull them back through and make them off.
·         5a05e6ab7acab_bn_1029bDSC_0486.jpg.4d93bd1399aec9a45a866c8d5c4e5394.jpgHere in order to make up blocks for the back stays I am adding both shackles and hooks to the Bluejacket blocks.  I then paint the blocks white and the copper silver for the galvanized.   There is some confusion in photos because the Bluenose ll chose for natural color on all blocks and black paint on all of the metal work.  I have decided to take the forged rods on mast bales and the like and repaint them black but am keeping galvanized look for the fittings and bands as the lower deck photos hint that to be correct. This is a choice as there are not enough old photos especially with the rigging to clarify this point.
5a05e88f126f3_bn_1029dDSC_0255.jpg.ec954436ad001491917fefe99f3408f1.jpgHere for the record is a block from Bluenose peak halyards. It shows the white paint and light remaining galvanized roller bracket on top.  The block would be upside down  as the roller rode on the "wire bridles" as named by Jensen"  lines spliced to the gaff.  5a05e6ac283bf_bn_1029cAAA_1502.jpg.801240dd11c9496627ad2281190fed5f.jpg
·         5a05e6ac283bf_bn_1029cAAA_1502.jpg.801240dd11c9496627ad2281190fed5f.jpgHere we see on the rail the throat halyard whip and the back stay.  I chose for now to have one back stay here and the port side in the aft position.  That is important, so the lines are the right length. With the throat whip to starboard, the  throat main halyard drops to a block on the deck on the port side.
5a05ebf80233e_bn_1029eAAA_1285.jpg.0e1575b2eb7967fec3eff5a9704c2dd1.jpgHere you can see the crew feeding the main throat halyard for the final step of raising the sail.  The Black braided halyard went through the large deck block and ran forward to the winch [ capstan] port side.   The peak Halyard ran forward similarly on the starboard side and you can see it on the deck past the mast.   The gal standing at the right of vertical halyard has 'dogged' off the halyard with the lanyard. the hitches are just below her hands.  The Lad is taking the halyard off the winch and making it fast to the forward pin.   They then coil the halyard that had reached the forward capstan on the deck next to the mast while sailing. The white braided fore sheet on the port bitt.   These deck blocks do not typically show on model plans.   They are also used to raise the top mast.      The fore mast is a little different and I will share that next time.
I thought it to be reasonable to share a photo of the main competitor to the Bluenose in the 1933 and 1938 races, the Gertrude Thebaud…..Gerty, as she is displayed in Lunenburg.  She has been moved and now lives close to the trophies honoring the races. Many details are similar, though she was smaller.  It is a great model to study.
cheers
jon
Patrick you are too kind as usual.  when I look at your interiors on you pages I am stunned at the patience and steady hand you have.  an that is real detail.
as to 1:24 scale detail, I am in the awe stage...  possibly also known as the upper part of the Rabbit hole i have entered.    Like do I need to redo the parrel through the front of the boom Jaw?
anyway thanks for following
jon
Jon,  I just spent a pleasurable hour catching up with you build. Your rigging is looking very professional.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith
Thank you for you encouraging words.  It is your build that fills us all with awe. I have been inspired again thanks to you to try to use soldering and my late brothers Sherline to actually make a fitting.  I need to have more bolted shackles connecting things as I am going to figure out how to remove and reset my masts for transportation. The copper wire bending only goes so far. I also note your use of brass wire for hooks.  I struggle bending the brass but it would be stronger.
Cheers
Jon
Edited by Jond
Hi Jon,
your Bluenose schooner looks beautiful, looking forward to the final picture set...
Nils
Current builds
-Lightship Elbe 1
Completed
Take out masts
I had an epiphany.        If I improve the bolts on the chain plates and critical shackles, I could remove:
·         20 bolts on shrouds
·         Three turn buckles on stays
·         Three sheets [ add bolts in shackles]
·         Cross stays above [ add bolts in shackles]
·         Jumbo boom gooseneck figure it out add bolt
·         Back stays two lines and deck blocks for each mast
·         Halyards, whips, boom lifts etc . say 20 lines now 30 lines later
In maybe an hour or so I could remove the masts. I am not sure where this is going, but just to make some  improvements on my current lists I need to get the masts out, so let’s try it.
this could have been a big oops  let's see how it went.
5a09dff19f426_bn_1031aDSC_0489.jpg.9055a754f29df47c08e97290258f5e15.jpgI ordered more small bolts.  i chose the 0-80 as they are a little more robust and if they are going to come out and go back that is important.  I had snipped them to length. That crossed up the threads to help keep the nut in place, but that prohibits re-threading. In this photo you see I am trying new bolts at the right length.  First on the left shroud is a new 1/4 in bolt...too short.  The right shroud has a 3/8 bolt...too long   Oh well I should have known no standard sizes would work here. Now i have two more bags of mini bolts.
5a09dff23da9e_bn_1031bDSC_0490.jpg.8e636b31206e36de22cc684e889fdff3.jpgHere I have filed and chased the threads with a die so the right length bolt is ready to go
5a09dff2d63ed_bn_1031cDSC_0500.jpg.660ddbc6965515232cbcd502fc04aba8.jpg Here i demonstrate the use of two mini bolt sockets that make this a reasonable option, especially  if this is to be done and redone.  You can see the black paint falls away from the brass, but that's no big deal as I am constantly going to be touching up if i choose to move this thing.
5a09dff37e2d9_bn_1031dDSC_0491.jpg.33cd45ede8d17363ab6dbd6bcdbe32b7.jpghere the first set is off and bolts saved in the plastic cup.  yippee!   I normally end up on the floor looking for that errant nut.
5a09dff4318cb_bn_1031eAAA_1506.jpg.4594c2b4eb8599cb28d87337c126c61f.jpgHere I have untied and grabbed all the lines tight to the mast.  simple masking tape to hold things from getting too messy.
5a09dff4c8806_bn_1031eDSC_0494.jpg.9828ab3fcd9cb3b7ce87b7bac798674a.jpgNow lets start working on upgrading those sheet blocks to see where a simple nut and bolt is all that is needed to disconnect.  this is 0-90 bolt.
5a09dff5802ac_bn_1031fAAA_1507.jpg.b71a7f925d645a30a25b1d9e36b8f74b.jpgHere is better view to the spaghetti taped to the mast.   wish me luck on this one please.
5a09dff612cc1_bn_1031gDSC_0495.jpg.8322fc4fb3516850d5a36663a1fa5574.jpgNow for all those cross braces.   i like the idea of upgrading these shackles and ties through the bales to 0-90 bolts and nuts.  I continue to use copper instead of brass for the bales because as here , I effectively chase threads into the copper as I install the bolt the first time.  I suppose i could tab a bent loop if it were brass, but I find it too difficult to bend the brass as it is not fully annealed.  Since I am painting it I currently stay with the copper.
5a09dff6b5d55_bn_1031kAAA_1504.jpg.3c5b26a3d527b86134d9a74faa4232ec.jpgWell here we are finally ready.....Shall we lift the mast????
5a09dff763ab6_bn_1031lAAA_1505.jpg.84b1b9198cc7a81ec4e4c262f992128c.jpgIt came out...we'll discuss what happened when it's time to restep.  not too serious, and if we made it, we should be able to fix it right??
cheers
Jon
Hmmmm! Glad I decided to have my masts fixed. This all looks very interesting and complicated. Good luck Jon.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I just caught up to this build. Have been absent from models for quit awhile. Last time I checked in you were still doing deck furniture etc.
Insane detail for a R.C. Model Jond!
Superb craftmanship to say the least!
Two thumbs Up*
A mighty fortress is our God a bulwark never failing!
Thank you all for your concerns regarding going back together after demasting.   Before I posted the demasting,  I completed several upgrades on the boom , installed what I call the mast boot and put her back.   It works; yes with some breakage and other issues I shall share.    It definitely is not for once a week but may let me set the detailed lines and things aside and then add simple masts and sails just for sailing.  More on that as I work it through. At least I can transport her to the Owls Head Museum show next march, and now have a scheme to let her sail if only once.
i chuckle to see insanity listed above as a suggestion of my mixing scale with sail.  I am using a new word...analidity to describe some of my plans.  But that is what this is all about.  Anyway, each time I move stuff, something breaks.  Today the camera tripod fell on the bow sprit and broke a clip holding stays.  Fortunately the 'sailable' bottle style turnbuckles are strong and the replacement was a simple brass founding.
anyway I am struggling on a few things today [ remaking the main sheet bands to be correct] and hope to update in a day or so. I plan to remove the foremast next week.
cheers
jond
