HMS Argonaut by crabbersnipe - 1/96th - Leander class frigate
Completed the hull planking, quite happy with things so far - need to do some finishing touches to the bow still (used some vertical strips that need sanding), and next step will be a rough sanding using 60 grade grit, before applying some resin into the joints.
After than some more sanding and applying filler where needed.
E
Link to comment
Share on other sites
Gave the hull a first coat of resin + hardener, worked especially into the joints and where the seams are slightly opened between the various planks.
Will rub this down once fully dried out and then proceed with filler and body primer - heading for a lot more sanding no doubt !
Glass matt have been ordered and are on their way, so no time to waste.
Am pondering whether to remove the sonar dome (that is part of my keel assembly) to facilitate the matting of the hull, and re-attach later & separately. Seem to think this protuberance will stand in the way of a neat glassfibre cover......
E
Link to comment
Thanks for the advise Roger, will be removing the sonar dome shortly and re-attach once the fibreglass is put on.
I suspect the same logic applies to the flat stern piece vs the hull ? Am considering covering the stern first, and then proceed with the rest of the hull thereafter - again because of the corners.
E
Link to comment
What an Amazing build  :o:dancetl6:
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
  • 3 years later...
Can't believe 4 years have lapsed since first starting this model but sadly this build started to slacken after a while due to various circumstances. However, pleased to advise we have picked things up again and whilst I am sure there is a considerable gap in my photo record let me already share the very latest to show where I am with things - finished the 4.5' gun turret last night, worked on the funnel and gave the superstructure some colour. Enjoy,
E
Link to comment
What an amazing build  - having seen her in the flesh in the 70s  at Pompy   I guess I have a  vested interest in following your fine work.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
