I am far from being an expert at carving in wood.  This was my first attempt and it seemed to work really well.  I am sure some of you will have alternative methods for mounting your carving blanks.
The Queen's cipher is probably the easiest of the designs to start with so I recommend starting with those.
To mount the blank,  I used a thicker 1/8" or 3/16" thick piece of scrap wood (not included with the blanks).  Its cherry and is hard enough to take a beating.  I would imagine softer woods are not the best to use and probably should be avoided.  The base was cut just a little larger than the piece being carved.  It was glued on with a childs glue stick.  This glue is easy to remove and cures permanent and strong....but will easily be treated with rubbing alcohol when the time comes to remove it.
Dont be shy with how much you use.  You want this piece secure.  These are fragile pieces at 1/32" thick.  Take special care with the areas that would be prone to breaking like the bottom tails for the letters.  The glue will dry hard but also flatter.   If some squished out its not a problem because you can easily scrape it away while carving.
Because the designs are so thin it will have a tendency to curl when wet with glue.  To solve this problem I sandwiched it with another small scrap piece and clamped it to dry.  I let it dry overnight before starting to carve it.
To remove the piece after you are done...I literally just filled a small plastic container with 90% rubbing alcohol and dropped it in.  I let it fully submerge in a 1" deep bath for about 3 hours.  It actually fell right off the base without any trouble.
Feel free to share other ways here or in your logs when you start one.  I would NOT recommend trying to carve these blanks without mounting them to a base.  They will just break apart in the first 2 seconds.
Chuck
Chuck, have you had any experience using Aspen or Poplar or Maple (easily found in Lowes/Home Depot) as the base instead of cherry?
Jack
Current buildUS Constellation
No but I am sure that would work....I just had a bunch of bad cherry I needed to use up.   I am sure any relatively hard base will do.   About 3/16" thick  or even 1/8" thick.
Thanks.
Jack
I have experimented with carpet tape and it does the job.
David B
I have used carpet tape for other projects and it does as you mentioned, but the residue is hard to remove unless you use acetone. The same applies when using contact cement in a spay can. It works great but don't let it cure too long with small pieces.
That brings me back to what Chuck suggested.
Edited by Modeler12
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
Chuck
Thanks for showing Chuck !
very smart solution for fixing / removing   ;) Nils
Nils
Current builds
-Lightship Elbe 1
Completed
  • 3 years later...
I've used scrap tile with a smooth surface
Current build: Great Harry, restoration
On hold: Soliel Royale, Mantua
Completed:
Bluenose ll, Artesania Latina
San Francisco llArtesania Latina
Chris Craft barrel back triple cockpit, Dumas
Chris Craft 1940 double cockpit, Dumas
Santa Maria, Artesania Latina
1901 Scow Schooner, scratch built
Hannah, Continental Navy, scratch built
Candelaria bomb ship, OcCre
Pride of Baltimore, Model Shipways
17 foot Chesapeake kayak (2, one scratch), Midwest
USN Picket Boat #1, Model Shipways
Kobuksan, Turtle Korean ironclad, YoungModeler
HMS Revenge, scratch
NY Pilot Boat, kit bashed, Model Shipways
USS Monitor, scratch
Nuestra Senora de Afortunado, 1926 Popular Science plan, Resoration
Martha, CBMM,
Puddle Jumper, scratch stern wheeler
Lady Sarah, kit bashed Constructo Victorian launch
