I looked at this during my build and I finally settled on RB32mm guns and the 15mm for the Swivels.
However, the 29mm look fine as well on the carriage, and once they are all together along the broadside I don't think they will look undersized, I just preferred a slightly chunkier look.
This is the comparison I made when deciding on my build, and as you can see the Syren version is finer still than the RB 29mm.
B.E.
Thanks for the comment, when the 32 are available I'm going to get them as it's low cost and then I can decide.
will finish second planking and make up the carriages proper with eyelets etc.
did you line the gun Ports? What were the final dimensions of your finished ports?
Hi Paul -- I just now found your log, and have caught up.  You're doing very nicely.  Once you've passed the gunport strip (sort of the initiation into Victory Swans), and the planking, you get to start on the really fun bits.
I'll be following along with interest.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Not been doing much as the garden and other jobs can't be put off. I purchased a few blocks and rope from Syren, top notch, the blocks are outstanding even without a tumble.
Only gripe is the UK Post office sticking on an £8.00'handling charge.
Paul -- I had to fiddle with the gunwales all round, even though I didn't put the decoration on.  I needed the room for the swivel gun mounts and some of the eye-bolts.
Nice planking there!  it all looks smooth and regular.
Cheers,
Martin
Definitely not wide as the strips sit right on the photoetch high points
I looked a Blue Ensigns build, if you look at page 2 mine looked like his with the top red border not parallel, so I measured from the plans and added a splice to make it 4mm as per the drwg and as his page 3. I have checked that all the windows side and rear fit as per his build.
  • 7 months later...
