Hi Bill, Its in there. Scroll on down to the S's. I'll move the ones with the Le in front down with the rest to prevent future confusion. I marked it finished and that will be in the next update.
Jeff
Jeff
Jeff I just now added this new build I am starting. However when I started the “New Topic” I could not get kit build log to register in the topic line. I could only get “how to use MSW forum” to post. Could you fix that for me?
Thanks
Bill
https://modelshipworld.com/topic/36221-endeavour-occre-154-by-bill97/
Edited by Bill97
Jeff at your convenience would you move and retitle this to member build log?  No matter what I do I can’t seem to delete content and restart the topic in the correct category. I think I have created a mess. I tried to start a new log a member build but concerned I may have two now.
https://modelshipworld.com/topic/36221-endeavour-by-bill97-occre-154/
Edited by Bill97
I already moved it once this morning, so I don't know why it still showed up in Nautical General Discussion. Anyhoo, I have moved it again. Hopefully it sticks this time.
From the comments above it looks like the quick indexes are being maintained, and I really do like them.   But when I look at the tags for the various indexes, they all snow a date of Nov 2023.    Are just the titles incorrect  and in reality the indexes are up to date?
Thanks
john
  • 1 year later...
I click on the 1501-1750 pdf and it opens but nothing happens when I try to click on the build that I want to see?
It looks like the file is downloaded?
I've also been having the same problem with that index for the last little while.
But even when it's working, I have found what I think is the quickest way to open any build log. Once I have found two or three build logs that I want to visit frequently, usually relating to the model that I'm working on at the time, I make a list of their names on a Word document. I name them anything I like - doesn't have to be the builder's handle. Then I turn each name on the Word document into a hyperlink that directly opens the build log. The forum website doesn't even have to be open first, the link will open it right at the page I want. It's literally only one click. If you want to, you can also create several different links for different pages within the same build log.
It only takes a few minutes to create the list and hyperlinks in Word and then it's incredibly fast to access the build logs.
Just an idea.
David
Current Build - St. Roch, Billing Boats; HMS Agamemnon, Caldercraft (on hold)
Previous Builds - Armed Virginia Sloop, Model Shipways; Constitution, Model Shipways; Rattlesnake, Mamoli; Virginia Privateer, Marine Model Co, restoration; Prince de Neufchatel, Model Shipways; Charles W. Morgan, Model Shipways; Pride of Baltimore II, Model Shipways, Bluenose, Model Shipways (x2); Niagara, Model Shipways; Mayfower, Model Shipways; Shamrock V, Amati; HMS Pegasus, Victory/Amati
  • 2 months later...
