I would like to share pics of my HMS Victory by Mamoli. The plans were crude so i spent more thinking planning and researching. Thanks to MSW. I still have to decide if i should use the 'green' strips as second planking below the water line, or use the copper plates from Model Expo.
did you glue the quarterdeck on yet? Or do the cannon barrels fit through the gun ports?
Kits owned: Mamoli Royal Louis, Mamoli Friesland, Mamoli HMS Victory 1:90, Occre Santisima Trinidad, Constructo HMS Prince
You could try getting a few rolls of that 5mm wide adhesive copper tape, might be cheaper than buying the plates and could still look ok (although you'd need a good sealer method to protect the hull after it is done).
 I have not thought about the cannons yet but maybe i should. I think i will try the 5 mm adhesive copper tape. Thanks for the suggestions, Mr . Demonborger!
Greetings
Well this looks like something special, welcome, I will follow your build with interest it's looking really good. Just enjoy your build
And I will enjoy watching it grow. Regards DAVID
Hi Hec and welcome to MSW. I'm also building this kit (link in my signature below). Be very careful about reading ahead and planning with this kit - the instructions have a habit of painting you into corners! If they haven't already done so that is. Check your QD cannons and install them BEFORE you glue the poop deck in place. The instructions tell you to fit them through the gunports - but they don't fit. As for "copper" tiling, I opted to go with the kit supplied green wood, painted copper and partially rubbed back. You can see the effect in my log - I think it looks okay, but proper copper tiles might be better if you feel inclined. I look forward to following the rest of your build - with a little (or a lot) of "bashing" this does make up into a nice model.
The only other tip I'd give you for now, is to buy a copy of "The Anatomy of Nelson's Ships" by C. Nepean Longridge. This is the "bible" for all Victory builders and has been an enormous help to me so far.
Hi Grant, thank you so much for your suggestions. Demonborger also hinted on the issue of cannons fitting under the poop deck. FORTUNATELY, i have not glued the poop deck yet! I have actually used the green strips on one side of the hull already, so might as well do it all throughout. If i am not happy with it, i think it should be easy to scrape. I have done so much bashing on the kit anyway, primarily because the translation issues and inadequate illustrations. The kit itself is good, but i think Mamoli should invest in better rendered plans with better English..
I was looking at "Anatomy of the Ship Victory by John McKay in Amazon  but the price of $300 (used) held  me back. I will consider Nepean Longridge for now. Thanks Grant!
Hec
Hec, I have to agree with you. Mamoli's plans are very basic & crude. I have got more useful information off other build logs & general research. I use the photos off the box lid as a reference and only refer to the plans to check sizes & measurements.
How have you found the quality of the timber supplied with the kit ? I have had to replace nearly all of mine because the poor quality.
Good luck with the rest of your build.
Dave.
Hi Dave, i had some issues with the timber but i used them anyway. It was no worse than the timber supplied in my first build - HMS Bounty by Amati. In the Mamoli kit, the first planking was a type of soft wood, which sort of worked for me considering my inexperience. By the way, where do you order quality wood?
Hec
Hec, I get mine from Modelers Shipyard here in Australia. Good quality and reasonable price. I found Mamoli's to splinter & split very easily.
Dave
Hec, I am always amazed when builders take on the Victory. Wish you well as you move along. BFN. Hopeful aka David Ps....I saw a 4' model of a model of the Victory in the Maritime museum in Barcelona, Spain. She was just sensational.
Edited by hopeful
Thanks, hopeful. I would not have dared take on the Victory without this forum.
Hec
Hec,
If you wish to replace any timber, then I would thoroughly recommend contacting Jeff Hayes at Hobbymill (one of the sponsors of this site). I bought some from him to scratch build a couple more of the ship's boats. Jeff's timber is excellent and his customer service is nothing short of outstanding.
The McKay book is useful, but if I could have only one, it would be the Longridge book. I have used it more than I have used the kit instructions, particularly now that I'm into the rigging stage.
This is an update of my hms Victory - mamoli. I used winsor & Newton acrylics, and Testor copper for the lower hull. I must have done four layers of copper paint. Initially, i tried giving it a slight sanding so the green would come out. I wasn't happy with it because it didn't look naturally 'algaeish'
Edited by hec
That's looking great Hec. Don't be afraid to be quite vigorous in rubbing back the copper if you want some of the green to show through. Alternatively, you can just go with a "fresh from the dockyard" look. Captain's choice as we say.
Did you manage to get a hold of a copy of Longridge?
Hi Grant, thanks for the compliment. I will be getting the Longridge book soon.
Hec
  • 3 months later...
Hec
good afternoon, how is the progress your build, ive not heard from you in a while?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hello hec
Welcome! Well here we go with something special. And another victory log that I will definitely follow. Keep the pictures coming, and simply enjoy your build. DAVID
