Dear friends,
I proud to present next version of rope making machine (video to come soon):
https://shipworkshop.com/products/tools/vr-31-rope-making-machine
VR 3.1 Rope making machine
(HD adaptable rope making machine. Former Ropewalk "Prosak")
What's new:
  • VR = Vertical ropewalk.
  • New version of former ropewalk "Prosak".
  • No need to reassemble for 3- or 4-stranded ropes.
  • Can be secured on both horizontal and vertical surfaces.
  • HD adaptable. Can be transformed into HD (Horizontal Design) machine. Not yet available.
  • There are notches on the machine that will help to mark screw holes for securing the machine.
Here is user's manual:
VR31.pdf
Edited by Alexey Domanoff
Chenged photo
How to remove unnecessary attached files to the post???? )
edit the post, and remove the files by clicking the garbage bin on the listed files/images
Carl
Thanks, bin icon has not been showed but I've guessed where it should be :-)
Alexey,
The last segment in the video (how to make hooks) was for me wasn't it? ;)
I have the new version and it works well.  After the 1st try failed I held the threads near the weight while they twisted (to avoid them intertwining) and all worked well!
Nice job Alexey.
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Its great to see that a horizontal version is coming soon. I have been using your older model in a horizontal configuration for a while now and it works great that way.
I'm curious how long a rope you are making horizontally.  With the vertical installation in my shop I'm limited to about 6'; that's more than enough for any one line I've ever needed on a model but is obviously much shorter than what one purchases. (e.g 5m from Alexey or 20ft from Syren).  The main advantage I see to longer lengths is less waste as it is cut for use.
Doug
Doug, with the workbench I have I usually end up with lengths of around 4 feet, which starts with strands of about 4 1/2 feet. I have an extension that I can clamp to the workbench to make 5 foot lengths, but I have rarely needed that length. There is a bit of waste with the 4 foot lengths, but I have used the excess for rope coils or block strops, so very little is thrown away.
Fair enough - thanks for the information.  I won't bother climbing onto the roof to get more height. ;)
Doug
He does make a horizontal machine..  https://shipworkshop.com/products/tools/ropewalk-planetary-3.1    I have the older model which is excellent and also the parts to convert it to the "newer' model for 3 strands and a center one but haven't set that up yet.
